Hitch drop 3" or 5" stock 2019 Sport
Discussion in 'Towing' started by EricTaco326, Oct 3, 2019.
  1. Oct 3, 2019 at 7:20 AM
    EricTaco326
    EricTaco326 [OP] New Member
    Eric
    2019 Calvary Blue Taco Sport Double Cab Long bed
    I am looking at the B&W Stow and Go hitch balls. My 2019 Taco Sport is stock and I don't plan lifting it. The stow and go's come in a 3" drop and a 5" drop. Any input or experienced suggestions?
  2. Oct 3, 2019 at 9:32 AM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    Whatever it takes to get the trailer as level as possible. I have several hitch mounts for different trailers.
    Trailer tire size also effects the drop, your boat trailer with 15" tires require less drop than a yard trailer with 8" tires.
    I would back the truck to the trailer, then use trailer jack and level to see how much below the hitch you are.
    synaps3 and EricTaco326[OP] like this.
  3. Oct 3, 2019 at 10:16 AM
    EricTaco326
    Eric
    I appreciate that, I have not bought a utility trailer yet so I was just hoping some guys had a little impute and I could get a common opinion. I may have to go grab my buddies trailer and see how it measures out. Thanks!!
  4. Dec 2, 2019 at 6:42 PM
    Wood Butcher
    Wood Butcher Well-Known Member
    2015 Pyrite Mica Tacoma TRD OR DCSB
    Can’t speak to your 3rd gen, but I have a 2015 DCSB OR with stock suspension. I have a 3.25” drop ball mount that is perfect for my single axle 10’ utility trailer. Unless you’re pulling a really small trailer the 5” drop will likely be too low.
    joe25rs likes this.
