Hit ac button, immediate squealing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dennisi01, May 15, 2018.
  1. May 15, 2018 at 11:33 AM
    Dennisi01
    Dennisi01 [OP] Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Hey, 2010 tacoma here. Its hot out, i hit the ac button and major squealing under the hood. Compressor shot?
  2. May 15, 2018 at 11:37 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    As soon as i hit the ac button it screams loud. Stops screaming as soon as i turn it off. Is it safe to run for a few? Im afraid of bustjng the belt
  3. May 15, 2018 at 11:39 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    compressor locked up or clutch has failed
    TRDSport10 and scottalot like this.
  4. May 15, 2018 at 11:42 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Is this a possible diy?
    TomTwo and scottalot like this.
  5. May 15, 2018 at 11:46 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    There are threads about replacing the pulley/clutch. Should verify by opening hood and looking at the AC clutch while someone turns the button on. The center should go from stopped to spinning.
    scottalot and TireFire like this.
  6. May 15, 2018 at 11:46 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    could always change the belt first to see if that's the issue only $20 or so
  7. May 15, 2018 at 11:46 AM
    Chris24
    Greensboro, NC
    I just replaced my clutch, it wasn't terrible. Compressor is more involved and requires replacing a few other things and evacuating/recharging the entire AC system. Compressor replacement from a shop will run around $1k.
  8. May 15, 2018 at 11:48 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    FREE: open hood and look at the AC clutch while someone turns the button on. The center should go from stopped to spinning.
    honda50r likes this.
  9. May 15, 2018 at 11:49 AM
    BillsSR5
    bill
    2014 SR5
    ouch how many miles on your truck when this happened? your in the south so u must use it often
  10. May 15, 2018 at 11:51 AM
    Chris24
    Greensboro, NC
    Toyota had to replace it once at 40k miles under warranty right when I bought the truck...and I had to replace again at 105k. I barely ever use my AC, lol.
  11. May 15, 2018 at 11:53 AM
    BillsSR5
    bill
    2014 SR5
    wow, I barely use my AC too only when the passengers start to complain, mines got 95k miles hopefully I don't need to do any AC work im off warranty
    Chris24[QUOTED] likes this.
  12. May 15, 2018 at 11:56 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Ugh. Ok will check when i get home. What would spinning vs not mean?
  13. May 15, 2018 at 11:57 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Surprised only one person said the pulley.
    Taco 422 and BillsSR5 like this.
  14. May 15, 2018 at 11:57 AM
    BillsSR5
    bill
    2014 SR5
    I think if spinning the clutch is engaging working
  15. May 15, 2018 at 11:58 AM
    BillsSR5
    bill
    2014 SR5
    jup x2
  16. May 15, 2018 at 12:00 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    There's a pulley(ring) wrapped around the clutch(center). When the A/C is off the clutch is not spinning(think of a tire not spinning) but when the A/C is on the clutch should be spinning(cycling on and off). The squeal may be because the clutch is locked up and we it engages the pulley it makes the pulley stop.
  17. May 15, 2018 at 12:02 PM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Pulley meaning the clutch?
  18. May 15, 2018 at 12:03 PM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Gotcha, which is bad for the belt i imagine. Christ the second i hit 100k stuff begins to happen.
    Sandman614[QUOTED] likes this.
  19. May 15, 2018 at 12:04 PM
    BillsSR5
    bill
    2014 SR5
    there are pulleys that the serpentine belt wraps around these also have a tendency to wear out and need replacement they start to chirp
  20. May 15, 2018 at 12:04 PM
    BillsSR5
    bill
    2014 SR5
    don't say that im at 95k miles
