Hill start assist control
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaHammer, Mar 17, 2016.
  1. Mar 17, 2016 at 6:45 PM
    TacomaHammer
    TacomaHammer [OP] Well-Known Member
    Hammer
    Park City, UT
    2016 Silver Sky Off-Road
    When I am on a steep grade and go to accelerate, I'm assuming the HAC kicks in and that is what is making this noise. But is it suppose to make the clicking noise? I can't figure it out, I'm still trying to understand the HAC feature because I have never dealt with this before in a vehicle.
  2. Mar 18, 2016 at 3:58 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    auto or manual?
  3. Mar 18, 2016 at 4:02 AM
    TacomaHammer
    Hammer
    Park City, UT
    It's auto
  4. Mar 18, 2016 at 4:03 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Do you roll back any
    shakerhood likes this.
  5. Mar 18, 2016 at 4:04 AM
    keithert
    keithert Well-Known Member
    On my Frontier there was a switch to enable hill start. How does it activate on the 16 Taco? Is it 4wd only? On the Nissan it was helpful in steep roads because it could be used in 2wd.
  6. Mar 18, 2016 at 4:06 AM
    Aussiek2000
    2016 Offroad AC
    My truck is an auto as well. The hill holding assist thing just works automatically. I stop on a hill and let of the brakes and it doesn't roll back. When I take off, there is no noise.
    Boosted_Carrera likes this.
  7. Mar 18, 2016 at 4:26 AM
    TacomaHammer
    Hammer
    Park City, UT
    Yes, when I go from brake to gas it rolls back and makes the noise.
  8. Mar 18, 2016 at 4:28 AM
    TacomaHammer
    Hammer
    Park City, UT
    I'll go test it again later, maybe there is something that I'm missing. I'm just not use to this feature and have never had it in a previous vehicle. I've driven a 71 bronco until this point.
  9. Mar 18, 2016 at 5:53 AM
    Shaunsquatch
    Shaunsquatch Well-Known Member
    Shaun
    Louisville, KY
    2020 Tundra
    Definitely no noise. If I am on a hill and let off the brake the truck will just sit there. Push the gas pedal and away it goes. The manual does say not to use it for more than 2 seconds, don't know if that is related.
    Aussiek2000 likes this.
  10. Mar 18, 2016 at 5:56 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    on really steep hills
    that is what it does. it doesn't hold you in one spot, it holds, then creeps, then holds...etc
    all the time the brake controller is going apeshit
    on mild hills it doesn't kick in at all....but real steep, yep, this is what goes on.
    normal
    bubbakingaroo and hr206 like this.
  11. Mar 18, 2016 at 6:28 AM
    TacomaHammer
    Hammer
    Park City, UT
    I should have clarified better. I appreciate the insight, smaller slopes don't have this problem. It's the real steep hills where I'm seeing this, and I have a stoplight on a very steep hill down the road I live on. Thus this has happened more frequently. Thanks!
    xxtavixx likes this.
  12. Mar 18, 2016 at 7:43 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    in this case Hill Start Assist is not active, this is your automatic tranny holding you. hill start assist is noisy
  13. Mar 18, 2016 at 7:49 AM
    keithert
    From the manual and comments here it sounds like the hill start is automatic. No switches like in the Frontier.
  14. Mar 18, 2016 at 7:52 AM
    Shaunsquatch
    Shaun
    Louisville, KY
    2020 Tundra
    Interesting, I guess I didn't know there was something other than the transmission holding it ever. Thanks!
  15. Mar 18, 2016 at 8:43 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    yup it's automatic. I was looking for it for a few weeks and was like...umm, mine must
    be missing or broken or deactivated.
    nope. went and found a real steep grunt and went up it and stopped and let off gas. it crept back 2 inches then brake controller
    went into overtime, stopped me, waited, crept me back, waited....it is a true 'assist' and not a 'I'll pin you right here forever'
    and you know it is active by the chattering [unless you have stereo blasting]
  16. Mar 18, 2016 at 8:53 AM
    whwv
    whwv Well-Known Member
    2016 Quicksand DCLB TRD Off-Road Tacoma
    If you are not shifting out of "D," but just coming to a stop and starting again, the HAC isn't kicking in.
    Some excerpts from the manual:
    Operating conditions of hill-start assist control
    When the following four conditions are met, the hill-start assist control will
    operate:
    ●The shift lever is in a position other than P or N (when starting off forward/
    backward on an upward incline).
    ●The vehicle is stopped.
    ●The accelerator pedal is not depressed.
    ●The parking brake is not engaged.
    ■Automatic system cancelation of hill-start assist control
    The hill-start assist control will turn off in any of the following situations:
    ●The shift lever is moved to P or N.
    ●The accelerator pedal is depressed.
    ●The parking brake is engaged.
    ●Approximately 2 seconds elapse after the brake pedal is released.
    ■When shifting the shift lever
    ●On vehicles with an automatic transmission, do not let the vehicle roll
    backward while the shift lever is in a driving position, or roll forward while
    the shift lever is in R.
    Doing so may cause the engine to stall or lead to poor brake and steering
    performance, resulting in an accident or damage to the vehicle.
  17. Mar 18, 2016 at 10:10 AM
    cbreze
    cbreze Well-Known Member
    Jim
    Bend, Oregon
    '12 T4R, '74 LC, '88,'98 04' pickups.
    Have this on my 4runner and think it kind of lame. Not sure if it's the same, but kind of sounds like it on the Tacoma. Mild hills it works fine after you firmly depress the brake pedal then back off it will hold the truck. On steeper hills it will roll back and make the clicking noise. I don't like to sit on a hill with my foot off the brake as it seems I'm less in control. So I don't use it much. Feel safer keeping my foot on the brake and would not trust it on a very steep hill AT All. Could be more useful with a manual shift I would think.
  18. Mar 18, 2016 at 10:29 AM
    OnceARunner
    OnceARunner War Eagle!
    Georgia
    2016 DCSB TRD Sport Tacoma
    What the excerpts you posted describe is precisely coming to a stop and restarting again. That is when it is useful. It's not meant to hold you there, just give your foot time to move from brake to gas without rolling backwards into the car behind you.
  19. Mar 18, 2016 at 11:04 AM
    whwv
    Yeah, I should have read a bit closer... Might as well just ignore that post...
    One thing I've noticed is that if I am on a hill and move from P to D and don't touch the pedals the truck will hold it's position without making the clicking noises. However, if i am trying to parallel park on a steep hill I will get the clicks. I'm thinking it's because I haven't come to a complete stop and therefore the HAC hasn't engaged.
  20. Mar 18, 2016 at 4:20 PM
    jmaack
    Justin
    Helena Alabama
    Your noise is normal. My 14 does same.
