Higher Lug nut torque 4th gen?
Discussion in '4th Gen. Tacomas (2024+)' started by 2020TacomaGuy, Dec 25, 2023.
  1. Dec 25, 2023 at 10:40 AM
    2020TacomaGuy
    2020TacomaGuy [OP] Well-Known Member
    2020 4x4 DCSB SR5
    In "early technical information " Gen4 thread
    Lug nut thread listed as 97 lb/ft....Pretty sure Gen 3 is around 83lb/ft
    Is 97lb/ft correct?
    If so, why?
    Thanks
  2. Dec 25, 2023 at 2:01 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Probably a different stud.
    shakerhood likes this.
  3. Dec 25, 2023 at 2:05 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Same thing crossed my mind too.
  4. Dec 25, 2023 at 3:09 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    M14 studs versus previous M12
    taco terror likes this.
  5. Dec 25, 2023 at 9:56 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    sanchez, Lord Helmet and shakerhood like this.
  6. Dec 26, 2023 at 10:26 AM
    chazmen
    chazmen Well-Known Member
    JT
    Happen to know if the 4 Runner SEMA PRO 17" will fit the new Tacoma's?
  7. Dec 26, 2023 at 10:39 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^You'll need to drill out the lug holes to accept the M14 lugnuts (which have a proportionally larger shank).
    The tire will stick out a bit over 2" per side and probably rub on the fenderwell plastic when steered.
    You'll also need to get hubcentric rings to center the wheel on the 4th gen's smaller hub pilot.
  8. Dec 26, 2023 at 10:40 AM
    chazmen
    JT
    Much appreciated.
  9. Dec 26, 2023 at 10:49 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I torque my aftermarket lugs for my SCS wheels to 95. Never had an issue.
  10. Dec 26, 2023 at 12:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^FYI the 4Runner and GX460 owner's manuals specify a lower 76 ft-lb torque for aluminum wheels after 2014. Why? Nobody knows.
  11. Dec 26, 2023 at 12:53 PM
    fourfourone
    Seems super low to me. Never understood why it's so low on these trucks. Maybe it's the wide 6 lug bolt pattern?
  12. Dec 26, 2023 at 1:18 PM
    2020TacomaGuy
    2020 4x4 DCSB SR5
    Thanks for the replies
  13. Jan 1, 2024 at 9:17 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    76 lbf-ft is pretty standard across the board for Toyotas with the M12x1.5 nuts and aluminum wheels.
    Some steel wheels or truck applications go higher, but if someone asked me about what the spec is on a Toyota, 95% of the time you’ll be right if you say 76.
    (My point is that 76 is the norm, anything else is “higher,” not that 76 would be lower than expected.)
    Jeff
    Malvolio likes this.
  14. Jan 4, 2024 at 1:06 AM
    perf0rmance
    perf0rmance Active Member
    2017 Cement 4Runner TRD PRO
    I’m guessing that the torque value is higher has the lugs are now m14 vs m12 on the previous gen
