High voltage and oxygen sensor code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by heythereuthere, Dec 23, 2018.
  1. Dec 23, 2018 at 5:04 PM
    heythereuthere
    heythereuthere [OP] Active Member
    I am getting a high voltage bank 1 sensor 2 oxygen sensor code. Replaced oxygen sensor but check engine light still on. 2015 4x4 base with manual trans and 2.7 engine. 38,000 miles. Damp conditions also seem to affect the light as well.
  2. Dec 23, 2018 at 8:40 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Did you clear the code after replacing the sensor?
  3. Dec 23, 2018 at 9:15 PM
    heythereuthere
  4. Dec 23, 2018 at 9:29 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Did you replace the right sensor?
    Lester Lugnut likes this.
  5. Dec 23, 2018 at 9:37 PM
    heythereuthere
  6. Dec 23, 2018 at 9:50 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Have you checked for an exhaust leak?
  7. Dec 23, 2018 at 10:30 PM
    Lester Lugnut
    What was the brand and part number replaced?
    Code P0138 Common Diagnosis Mistakes
    Replacing the O2 sensor without checking any wires or clogged/damaged catalyst.
  8. Dec 24, 2018 at 5:49 AM
    heythereuthere
    Bosh sensor. Took it to Toyota and everything working correctly. Other than suggesting genuine Toyota part they were much help
  9. Dec 24, 2018 at 6:27 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    Bosch makes notoriously garbage sensors. That could be the culprit. Otherwise if you're only getting the code intermittently (you said wet weather is effecting it - how exactly?) then I would also inspect the wiring and connections.
    12TRDTacoma likes this.
  10. Dec 24, 2018 at 7:01 AM
    heythereuthere
    When it rains or snows. Light comes on and goes off when things dry out. Mechanic checked wiring. Said he didn’t see anything wrong. Had read that upstream sensor gives and false reading to the downstream. Has anyone heard or experienced that?
  11. Dec 24, 2018 at 8:23 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    IMO, if it acts up with moisture it is a sign of a wiring issue. I would check it closer. You might also want to put some dielectric grease (silicone grease) in the O2 connector at the harness to seal it. The 02 sensor works on a very narrow voltage window. Any wiring issues that create voltage reference issues will show up quickly.
  12. Dec 24, 2018 at 8:45 AM
    heythereuthere
    That is what my mechanic did. Light went off this morning. I’ll see next rain what happens. Just trying to get a jump on things just in case
  13. Dec 24, 2018 at 8:48 AM
    jv_74
    Jesse
    Filthadelphia
    If you check wiring/connections and can't find anything I'd bet that bosch sensor is the problem. I've had a bad experience with a brand new O2 sensor of theirs throwing a code in the past.
  14. Dec 24, 2018 at 8:58 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    Another thing to check, (I know it's obvious but just trying to troubleshoot), make sure the sensor is tight against its compression ring. I have had 02 sensors that were not completely tight cause issues.
  15. Dec 24, 2018 at 9:05 AM
    heythereuthere
    Just weird that with the light on according to Toyota everything is working fine
  16. Dec 24, 2018 at 9:06 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    Well, I would hope they did not tell you that with the light on!
  17. Dec 24, 2018 at 9:07 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    You can always swap sensors btw Bank 1 and 2. If the problem follows, you have a bad sensor. If not, start looking at the wiring.
  18. Dec 24, 2018 at 9:08 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bosch is trash for oxygen sensors. If and when the light comes back on, replace the sensor with a factory or OE equal (Denso).
    The upstream CAN cause false readings for your downstream but you only have 38K and the chances of that sensor being bad is really slim.
    Regardless, you are covered under 8 yrs. 80K federal emissions warranty and oxygen sensors fall under that warranty blanket, so you should not even have to be worrying about this sort of stuff right now. Go have dealer set your truck straight.
  19. Dec 24, 2018 at 9:25 AM
    heythereuthere
    They did. Light was on. They suggested waiting till the sensor failed since it was working properly or going to a Toyota sensor.
  20. Dec 24, 2018 at 9:28 AM
    heythereuthere
    I was told oxygen sensor was not covered under emission warranty. Two different dealers told me that.
