High Transmission Temp Warning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mulligandog, Aug 16, 2019.
  1. Aug 16, 2019 at 7:21 AM
    Mulligandog
    Mulligandog [OP] Active Member
    Greg
    FL
    2016 Blue Tacoma SR5 Double Cab
    2016 SR5 V6 RWD, 39,000 miles - I've read a bit on this and my daughter had this warning pop up the other day after driving about a mile, shutting it off, going into a store for 5 minutes and coming out. She turned it off and back on after I told her to and it went away and we haven't seen it again. I'm taking it in Saturday as a precaution and asked to have the Cam Position Sensor looked at, but am wondering if there are any other ideas from those who've dealt with it. She does drive it with the ECT on a lot, could that contribute? Any help or advice is appreciated as I'm new to the Taco world.
  2. Aug 16, 2019 at 7:27 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Tends to happen when rolling backwards in D and then hitting the gas. It's like a failsafe...several others have had the same issue including myself.
    Some discussion on it here, starting page 18
    https://www.tacomaworld.com/threads/3rd-gen-true-crawlin-thread.613915/page-18
    If she was backing out of a spot and put it into drive too quickly that could have also caused it.
  3. Aug 16, 2019 at 10:19 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Could be that the tranny fluid if low if you have the towing package.
    DAS Taco and synaps3 like this.
  4. Aug 16, 2019 at 10:28 AM
    Mulligandog
    Greg
    FL
    Any easy way to check that? I read there is no dipstick...but didn't actually look... and wouldn't you think we'd see it again? Not questioning your knowledge, I truly appreciate the advice, but I did think if it was low we'd notice it again. It's been a week now since she saw it and she drives it every day, usually much farther than that.
  5. Aug 16, 2019 at 10:30 AM
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    6MT
    shakerhood likes this.
  6. Aug 16, 2019 at 10:33 AM
    Mulligandog
    Greg
    FL
    Sorry, automatic.
  7. Aug 16, 2019 at 10:44 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Do you have the towing package?
  8. Aug 16, 2019 at 10:48 AM
    Mulligandog
    Greg
    FL
    That is a very good question...I honestly don't know, we bought it used, but believe so as it has both trailer pin connectors and the hitch. I have not checked for a trans cooler though so can't say for certain.
  9. Aug 16, 2019 at 10:50 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Just pop the hood and look in front of the engine radiator, should be a small one mounted in front of it which would be the trans oil cooler.
  10. Aug 16, 2019 at 10:52 AM
    eurowner
    eurowner Duke Sky
    Scoty
    If you have the trailer plugs, flat 4 and round 7, in the bumper next to the license plate area, you most likely have it.
    To check the level, the tranny has to be up temp and special tools used.
    Junkhead and Mulligandog[OP] like this.
  11. Aug 16, 2019 at 10:54 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    my guess is that she was backing out of a spot at the store, and while still rolling backwards put it in D and hit the gas pedal, thus stalling the truck and throwing the error.
  12. Aug 16, 2019 at 10:55 AM
    Mulligandog
    Greg
    FL
    This will be the first question I ask when I see her. Great insight on this, I hadn't seen it as a solution and I have this bad habit myself (guess who taught her to drive...).
    Junkhead likes this.
  13. Aug 16, 2019 at 11:18 AM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    Could be the CPS going. You have a 16, in FL, and in the dead heat of summer. That's when most CPS failures occurred back then.
    Junkhead and shakerhood like this.
  14. Aug 16, 2019 at 11:21 AM
    Mulligandog
    Greg
    FL
    That's good to know. I highlighted that for the service advisor tomorrow. Thanks!
    Friggin Fuego[QUOTED] likes this.
  15. Jul 20, 2020 at 12:30 PM
    TomDom
    TomDom Member
    Tom
    Hey what was the result of this? This just happened to me.
    cryptolyme likes this.
  16. Jul 20, 2020 at 7:02 PM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    Looks like another thread started and asked for a bunch of advice and then didnt give a shit about the rest of us knowing the outcome.
  17. Jul 20, 2020 at 7:05 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    It should be a rule to update a post with the outcome.
    They take from the collective, but don't ever give anything in return.
  18. Jul 20, 2020 at 8:21 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Yeah, that's annoying
    gearcruncher, Junkhead and Amanelot like this.
  19. Jul 23, 2020 at 2:01 PM
    TomDom
    TomDom Member
    Tom
    Update!!
  20. Aug 13, 2020 at 4:34 PM
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    Hoping for a reply! This just happened to me, shut the truck off and started it again and the message was gone. Trying to prepare for whatever is to come :annoyed:
