High pressure DI fuel pump gasket replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VelocitySk, Sep 5, 2022.
  1. Sep 5, 2022 at 5:56 PM
    VelocitySk
    VelocitySk [OP] Well-Known Member
    'Berta, in The Great White North
    2016 Taco Limited
    Hey guys, i need to replace my High pressure DI fuel pump gasket as it's leaking pretty bad. Ended up getting a gasket off the internet as my dealership couldn't seem to get one in... They also wanted 3.5 hours to replace and it sure doesn't see that bad looking at it.
    Just wondering if anyone has the proper procedure on swapping this gasket out? I'd just tackle it myself if i had something to go over first.
    Thanks, Db
  2. Sep 5, 2022 at 6:18 PM
    Bishop84
    Bishop84 Well-Known Member
    It's not 3.5 lol.
    Big thing is, assume the line has pressure in it, so crack the line with glove and eye protection.
    It will not have pressure as long as the truck isn't running, which is a duh moment.
    It simply unbolts, pay attention to the roller bearing orientation, but it can't be installed backwards.
    I'll go by memory
    1 disconnect battery
    2 crack lines to relieve pressure
    3 remove harness and line brackets, one is attached to the return line
    4 then remove the pressure line entirely
    5 unbolt fuel pump, the bolts are quite tight so be sure to have a good socket on them
    reverse
    tonered and VelocitySk[OP] like this.
  3. Sep 5, 2022 at 6:23 PM
    VelocitySk
    2016 Taco Limited
    Thanks Bishop, seems pretty damn easy. Thoughts on needing to torque anything? Also do i need to lube the rubber gasket to keep it from drying out at all?
    Db
  4. Sep 5, 2022 at 6:25 PM
    Bishop84
    No lube, and torque is 19ft lbs on the main bolts, most people don't have a torque wrench for that. Basically snug. Tighter than a spark plug as a reference.
    Don't go crazy on the 17mm fuel lines, but it doesn't hurt to re-tighten them after.
  5. Sep 9, 2022 at 6:43 PM
    VelocitySk
    2016 Taco Limited
    Swapped it out in like 30minutes… crazy they wanted 3.5hrs. I was amazed how dirty the indent where the gasket sits was. Sandy n dirty, so cleaned out well and reinstalled. Everything seems good after couple good drives today.
    Thoughts on why there’d be sandy mess in there? Motor has been out twice already under warranty due to leak on front of motor, timing chain area if I remember correctly . But they said they’d never had to of removed that at all.
    db
    Bishop84 likes this.
  6. Sep 9, 2022 at 7:03 PM
    Coondawg07
    Coondawg07 Master of none
    Alabama
    2016 DCLB BBP
    Good info, thanks Bishop. You never know when you’ll end up needing something like this.
  7. Jan 10, 2025 at 6:07 AM
    einstein2028
    einstein2028 New Member
    Michael
    2018 White Tacoma TRD Off Road
    Hey I'm curious where you found the gasket online? I have the same issue and cannot find the High Pressure DI fuel pump gasket anywhere!
  8. Jan 10, 2025 at 8:40 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
  9. Jan 11, 2025 at 7:34 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Doesn't Toyota have a new 10-year repair cost free program for the leaking High Pressure fuel pump? I'm sure someone will come by with that information.
    Or perhaps you are one of those folks like me that never wants to take anything to the dealer.
  10. Jan 11, 2025 at 7:38 PM
    Vlady
    Issy, WA
    Only when you smell the fuel
  11. Jan 11, 2025 at 7:53 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Toycoma2021 likes this.
  12. Jan 14, 2025 at 8:10 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I've posted in a few "hard start" type threads, trying not to revive old and dead ones, but haven't gotten much feedback. Glad to see this thread is active regarding the hpfp. Aside from being noisy, would a bad high pressure fuel pump lead to a hard start/stumble start? I'd assume the pump "losing its prime" could give me the issues I'm having. Here's a thread with videos of my exact symptoms:
    Rough Start Up - Engine Sputtering Video | Tacoma World
