High pitched mechanical whistle while coasting in gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrooklynSculpt, May 28, 2016.
  1. May 28, 2016 at 6:40 AM
    BrooklynSculpt
    BrooklynSculpt [OP] New Member
    2008 taco sr5
    Hi all,
    I'm new here and I hope this is in the right place. My 2008 taco (v6 4x4 sr5 112k mi) is making a faint high pitched whistle while coasting in gear. It kind of sounds like cicadas. The sound is most noticeable at 30-40 mph and stops immediately when the clutch is depressed or when accelerating. I can't tell where it is coming from however the other clues point to drivetrain.
    Any thoughts on what this might be? I have to deliver some materials to nyc (3 hrs away) next week and I'm a little concerned that he this might become a larger problem.
  2. May 28, 2016 at 6:46 AM
    SandinmyTaco
    SandinmyTaco Gonna Catch'em All
    Fort Benning, GA
    2015 SR5 4x4 6 Speed SSM DCSB
    Prerunner to 4x4 Mod Wet okole seat covers Weathertech digital floorliners Yellow wire mod SCS F5s gunmetal 16" 4.5bs 265/75/16 Cooper ST Maxx ARE CX Camper Shell
    What are your RPM's at? Mine makes a high pitch whine around 2k until I shift or push the clutch in. It's done it since new. The dealer says it's fine but I def know when I am not really on the gas.
  3. May 28, 2016 at 7:53 AM
    BrooklynSculpt
    2008 taco sr5
    I haven't paid much attention to the RPMs. I'll check it out when I go out later today.
  4. May 28, 2016 at 8:02 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    My truck does the same. No idea if it's normal or not though.
  5. May 28, 2016 at 9:36 AM
    SandinmyTaco
    Fort Benning, GA
    So I just left my dealer I had them check fluid levels on the transmission they said it was fine but they topped it off, in the 10 miles or so I have driven it seems to have lessened a bit. Might want to just replace the fluid.:notsure:
  6. May 28, 2016 at 9:39 AM
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    mine makes a diesel turbo like sound when accelerating
  7. May 28, 2016 at 9:46 AM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Mine has always done this in certain scenarios: coasting downhill around 65 mph there's a whistling, going about 40 mph in 4th gear there is a pretty noticeable "Ooooooo" noise.
    When I still was under warranty I had the dealer look at it. They heard the noise, but found nothing wrong.
    50,000 miles and a fluid change (tranny and rear diff) have passed and nothing has changed, so I ignore it now.
  8. May 28, 2016 at 2:42 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    My '14 howls since new up to and including 60 mph on deceleration. Pisses me off!
