High Performance 4.0 V6 Motor?
Discussion in 'Performance and Tuning' started by VABUCKAROO, Jul 7, 2012.
  1. Jul 7, 2012 at 4:41 AM
    VABUCKAROO
    VABUCKAROO [OP] Active Member
    Locust Dale, VA
    Having built a nice 350 Chevy motor years ago, I'm trying to find out if it's possible to build a high out put 4.0 V6 Taco motor. Better cam, pistons, etc. I have run acroos 22R perf., but nothing for the V6.
  2. Jul 7, 2012 at 4:46 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  3. Jul 7, 2012 at 7:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    ^^^ That was just a dumb link dude...
    Yes. There are forged internals for the 1GR(4.0). I have been running Pauter Rods, and CP Pistons for quite a while now. ARP head studs, Cometic head Gaskets, Dual valve springs with Titanium retainers. Just recently started having my block sleeved, and a forged crank to go with everything.
    www.Dezod.com New to the 1GR, but definitely not to Toyotas.
    www.lceperformance.com Long time Toyota engine builders as well. Those are the two which I would talk to.
    As for cams, that is really expensive because no one can get cores for our cams. So you have to send them off to a place called Web Cams. They are in Cali. The weld new material onto the current lobes, so you retain your base. Then they grind them to get the numbers you are after. However, they charge $1800 for all four cams.
    If you have any further questions, post up, and I will help where i can.
  4. Jul 7, 2012 at 8:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Camel51 likes this.
  5. Jul 7, 2012 at 11:54 AM
    VABUCKAROO
    Locust Dale, VA
    What I'm thinking I would like to be able to do is build a new block with better pistons, rings, con rods, heads, and cams. Have everything polished and honed. I'd like to use factory EFI, trans and t-case. I'd be happy with output around 300 HP. If I have to change tranny, I'd like to use a 5sp Auto. Possible a Ford truck C6.
  6. Jul 7, 2012 at 11:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Factory trans will hold that no problem.
    I gathered that you would like new internals from your first post. Have you looked up either of the two links?
    Are you planning on staying N/A, or going F/I?
  7. Jul 7, 2012 at 12:09 PM
    VABUCKAROO
    Locust Dale, VA
    Looking at staying with factory FI. May be after market injectors. Definately will do headers and better exhaust.
  8. Jul 7, 2012 at 12:13 PM
    subwayaz
    subwayaz Well-Known Member
    Tucson,Az
    2012 Accesscab; TRD
    Super Charger, Catback Exhaust,Side Wind Shades, & Carbon Fiber Dash Kit
    There are some nice possibilities here. I'm sure it can be done.
  9. Jul 7, 2012 at 12:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You must be meaning N/A (naturally aspirated). For F/I I was referring to Forced Induction.
    To get to 300 HP, while staying N/A, you will have to run high compression pistons. Those are the same numbers that the guy in the link was striving for.
  10. Jul 7, 2012 at 3:03 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    With all these new internals on your Built motor, what are you doing with your oil system (pump, pickup, etc)?
  11. Jul 7, 2012 at 4:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Being that my truck is a 4x4, it already has the deep oil pan. Compared to the shallow one which is on some PreRunners and all XRunners. So that is taken care of with little effort. ;)
    Unfortunately, there are no aftermarket oil pumps available. Say for higher rpm operation. So cannot change that. As well, I am limiting my max rpm to 6k, from factory at 5500.
    Our engines have oil squirters, which is a nice plus, since it helps cool the pistons as well as add extra lubrication.
    Basically, the only things I will be doing as far as oil goes, is use Redline 10w-40 or 15w-50. With half a bottle of their engine break-in oil at every change. Got to keep the ZDDP count up.
    To help keep the oil cool, a Setrab oil cooler, used with a Greddy thermostatically controlled sandwich plate. Picked that up from www.240sxmotoring.com
  12. Jul 7, 2012 at 4:06 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    supercharge it and get 300 hp for a lot less headache and easier
  13. Jul 7, 2012 at 7:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Some people like the raw N/A power. I won't stop him. Do as your heart desires my friend.
  14. Jul 7, 2012 at 7:27 PM
    2000GTacoma
    Snow Hill NC
    whatever floats his boat
  15. Jul 7, 2012 at 10:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Howeeeeeeeever.......you could always install forged internals. Do like 2000GTacoma said and install a TRD s/c. Buuuuut, send off the s/c to Steigmier to have them do the Snakebite upgrade on it. Kind of like what a guy I know did.
    It will make that TRD s/c boost 1 BAR, and make you pinch a hole in your seat every time you drive. :D
    It is the only real way to get maximum power out of the TRD s/c. :thumbsup:
  16. Jul 7, 2012 at 10:34 PM
    theduck911
    Max
    Locked and Geared!
    This "snakebite" upgrade sounds interesting:cool:
  17. Jul 8, 2012 at 8:49 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    yes elaborate on said upgrade if you could haha
  18. Jul 8, 2012 at 9:00 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only person I know to have had the "Snake Bite" done, was a guy who guys by Sparkys Tacoma.
    He sent his blower in to Stiegemeier, to have the front drive reconfigured, and thus it really upped the boost. 16 psi, when he first installed it.
    http://www.stiegemeier.com/frontdrive.html
    I am not sure what all work he had done though. I know he did the port and polish, ported throttle body, and front drive. Not sure about anything else.
  19. Jul 13, 2012 at 5:23 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
  20. Jul 13, 2012 at 5:31 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Supercharge and only get 300??? Thats a damn shame, waste of parts and money. you can get 300 going N/A all damn day on the 4.0
    Internals, management and the right turbo/super and 600 is very attainable.
