High Output Alternator for 3rd Gen Tacoma (350 amps+)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ionvoid, Jan 26, 2022.
  1. Jan 26, 2022 at 9:54 AM
    Ionvoid
    Ionvoid [OP] SharkyTheTaco
    Maxim
    Lafayette Colorado
    2017 TRD Off-road DCSB
    2.5 King shocks, Dirt KIng UCA's, snorkel, TRD 17" Bronze Wheels, 285/70/17 KO2s, lightbar, bed rack, rooftop tent, 5 subwoofers on 2800 watts RMS, upgraded tweeters and door speakers.
    Hey everyone, I am looking for a very high output alternator for a 3rd gen Tacoma. Looking for something above the 350 amp range. I am making a very powerful car stereo system for my Tacoma. I already have 5 subwoofers pushing 1000 watts rms. With my amps being capable of drawing 1600 watts rms. I am planning an upgrade on my door speakers, and possibly the subwoofers as well. Looking to be pushing around 3200 watts rms minimum. That would be a draw of 270 amps from the battery at rms not peak. Peak amp draw could be around 600 amps. Plus I have my Light bar and planning on getting a winch.
    I will post some photos of the subwoofer setup in a bit. I have a 2017 TRD off-road short bed double cab. All subwoofers are hidden away behind and under the rear seats. All work was done by me.
  2. Jan 26, 2022 at 9:56 AM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Sub'd for pics of 5 subs. I'd sure hate to be your neighbor lol.
  3. Jan 26, 2022 at 10:00 AM
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Had 4000 rms in my old frontier. Stock alt with 2 batteries and big 3. No dimming and loud as hell. Had a pair of sundown x10"s in a ported box and an active front stage on about 600 rms. I would do the big 3 and take it from there
  4. Jan 26, 2022 at 10:10 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  5. Jan 26, 2022 at 10:12 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    What town are you in?
    I want to make sure I DON'T pull up next to you at a light... !!!!:eek:
    ridefreak, Mark77 and tonered like this.
  6. Jan 26, 2022 at 10:18 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I think a better question is what amps are you using? Wattage ratings are very deceptive and if your not paying a ton of money the ratings are straight up lies.
  7. Jan 26, 2022 at 10:22 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Mark77, eurowner and IssaGreenTaco like this.
  8. Jan 26, 2022 at 10:22 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
  9. Jan 26, 2022 at 10:26 AM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    Not OP, but curious what the big 3 are if you don't mind.
  10. Jan 26, 2022 at 10:30 AM
    swissrallyman
    swissrallyman Well-Known Member
  11. Jan 26, 2022 at 10:32 AM
    Key-Rei
    Key
    Florida
    Big three refer to the big three primary current carrying conductor wires of the electrical system:
    Alternator to battery, battery to starter starter to ground.
    Big three upgrade is a common car audio phrase but it benefits all systems by having better stronger electron paths.
    Technically there's more on the Tacoma, in addition to those listed there's also frame to body, battery to primary fuse box.
    Original harness vs upgraded "big three" harness, each one of those wires is larger than the original 3 combined.
    Rainoffire, eurowner, Kev250R and 3 others like this.
  12. Jan 26, 2022 at 11:04 AM
    Ionvoid
    Maxim
    Lafayette Colorado
  13. Jan 26, 2022 at 11:09 AM
    Ionvoid
    Maxim
    Lafayette Colorado
    The amps I am using are the Rockford Fosgate P500X2 and the Skar Audio RP800-1D. The Skar amp is capable of over 800 watts rms at 1 ohm and the Rockford can push around 370 watts rms to each channel at 2 ohm, so around 740 watts total for the Rockford.
  14. Jan 26, 2022 at 11:10 AM
    Key-Rei
    Key
    Florida
    Tacodog, .jake, 10ECTACO and 4 others like this.
  15. Jan 26, 2022 at 11:14 AM
    Ionvoid
    Maxim
    Lafayette Colorado
    I like bass lol
  16. Jan 26, 2022 at 11:15 AM
    Finn-2187
    Thanks, that's super helpful. Is that a pre-built harness anyone can buy or is it custom?
    Key-Rei[QUOTED] likes this.
  17. Jan 26, 2022 at 11:18 AM
    Ionvoid
    Maxim
    Lafayette Colorado
    I’m in Erie Colorado.
    Ill have to look into the big 3, seems like a less expensive route.
  18. Jan 26, 2022 at 11:19 AM
    Key-Rei
    Key
    Florida
    A little of both, I'm not sure if it's exactly the same for a 3rd gen as I have a 2nd but I suspect it would work @deanosaurus makes them he has a thread about it too. They come as individual wires you have to install and loom them together as you see fit. Great quality cables very happy with the kit.
    Finn-2187[QUOTED] likes this.
  19. Jan 26, 2022 at 11:21 AM
    Key-Rei
    Key
    Florida
    Just remember hearing damage is permanent and irreversible. :thumbsup:
    Pwakchop, hoagie8, hiPSI and 7 others like this.
  20. Jan 26, 2022 at 11:24 AM
    Ionvoid
    Maxim
    Lafayette Colorado
    My hope is by the time I’m in my 60s-70s technology will have advanced enough so they can create hearing aides that will solve my hearing problems.
    But I listen around 110-120 db right now for extended periods of time, so I will most definitely have hearing problems.
