High mileage oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 80sforlife, Mar 27, 2022.
  1. Mar 27, 2022 at 1:56 AM
    80sforlife
    80sforlife [OP] Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    I have 78k and signs of the timing cover leak. Thinking of switching over to high mileage oil which I believe has additives to swell seals and help with small leaks. Any experience with high mileage oil? What brand are you using?
  2. Mar 27, 2022 at 3:56 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't consider 78,000 high mileage. I'm at 224,000 miles and use 5-30 synthetic that I buy at Costco. The last I bought was $25 for two 5 quart jugs. No leaks, and I still don't add any oil between oil changes.
    shotgunbilly420 and CusterFan like this.
  3. Mar 27, 2022 at 4:16 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The additives in high mileage oils are designed to swell rubber style seals to stop leaks. The timing cover seal is silicone that didn't get dispensed correctly by the robot at the factory. You can't make a seal that isn't even there, swell...
  4. Mar 27, 2022 at 6:18 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Idk, for some reason high mileage oil hasn't some additives needed for a good full synthetic oil that these engines need, its not recommended. At any rate 78k isn't high mileage imo.
  5. Mar 27, 2022 at 6:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    High mileage oil is more marketing fluff IMHO.
    fathomblue likes this.
  6. Mar 27, 2022 at 6:37 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I hope this doesn’t derail the thread but does anyone know if/when the dealership changes over to high mileage oil when servicing a Tacoma?
  7. Mar 27, 2022 at 7:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'm in for 'never'. :D
  8. Mar 27, 2022 at 7:02 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thats what I was thinking lol
  9. Mar 27, 2022 at 8:36 AM
    scottc
    scottc Well-Known Member
    Raleigh NC
    2019 TRD Sport 4X4
    KDMAX- Pro Tune TRD Exhaust
    For what it's worth, I have a friend with a couple high milage vehicles (08 Wrangler, early 2000's Chevy Lumina). Each used about 2 quarts between changes. After switching to high milage oil they both use about 1 quart between changes.
  10. Mar 27, 2022 at 10:58 AM
    80sforlife
    Sounds like it’s no use to switch to high mileage oil since the timing cover is a different kind of seal. I’ve been using Pennzoil Platinum 0w20 full synthetic. Are some oil brands more or less susceptible to leaking? Guessing it’s not a good idea to go up to a thicker viscosity? Maybe a synthetic blend is better, what do you think?
  11. Mar 27, 2022 at 11:04 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    0W20 is only available in synthetic... and I doubt going up in viscosity will stop or slow the leak. If you can't warranty it, then I would clean it off and monitor it. If it starts getting too bad, then there is always financial combustion...
    Disclaimer: I am only joking about the financial combustion comment!!!
    shakerhood and zoo truck like this.
  12. Mar 27, 2022 at 11:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Magic elixirs don't fix leaks. Mechanical repairs do.
    Keep it cleaned off and monitored, and the oil level monitored, as you decide next steps. It's not a gusher, so it should be safe to drive.
    Make sure it's not something else, like th power steering pump, making the mess.
    33yrsoftoys and RustyGreen like this.
  13. Mar 27, 2022 at 12:26 PM
    Red Alert
    Red Alert Well-Known Member
    CT
    2020 Tacoma SX 3.5 4x4 BRM AC
    Mobil 1 high mileage full synthetic minimized the oil burning (normal in higher mileage vehicles per Mercedes Benz) in my ML500. Was running smoothly when I traded it at 165K. It won't fix a timing cover leak though. If that's your issue it behooves you to have it remedied promptly.
  14. Mar 27, 2022 at 12:40 PM
    zoo truck
    None
    Sometimes those magic elixirs do help. Once had a power steering rack leak. I poured in a bottle of this lucus leak stop for power steering units leaking, and it did nearly stop the leak...at least for a good month before it starting getting worse again.
  15. Mar 27, 2022 at 1:00 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I use the Pennzoil High Mileage for my 2nd gen 4cyl with 213K on it...Just did a change yesterday..Got about 5.5 quarts out, put 6 in. Change interval was 7,600 miles this time...
    Interestingly they have relabeled the product as "Synthetic Blend" in the last year..I have a 1 Q container I use to measure out the 6th quart and it still says the old dino label.
    Amazon Bot
    Old Label
    https://www.amazon.com/Pennzoil-550045203-quart-5W-20-Mileage/dp/B01M65NJ6W
    New
  16. Nov 27, 2022 at 9:51 PM
    TreeFortRichard
    Brian
