high beam relay location help?
Discussion in 'Lighting' started by brutalguyracing, Sep 23, 2013.
  1. Sep 23, 2013 at 12:51 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    looking for location of high beam headlight relay location?
    seems my high beams are not working some times......
    sometimes I switch them on and it takes 30- seconds to 2 minutes to come on.....sometimes they never come on?
    so I wanted to replace the relay?
    thanks
  2. Sep 23, 2013 at 12:54 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did you check the socket itself to make sure it wasn't corroded to hell? My trailer lights were doing that because my truck's plug was corroded really badly.
    Free bump.
  3. Sep 23, 2013 at 1:24 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    no I didn't check anything as of yet
    I will do that as being ,you know at the beach n such sometimes
  4. Sep 23, 2013 at 4:11 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  5. Sep 23, 2013 at 6:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It's in the underhood fuse box. I believe it's labeled "dim" or "dimmer". There is a main headlight relay that supplies power to the dimmer relay, the dimmer relay rests at the low beam position, when you push the switch to the high beam position, the dimmer relay is energized and switches from low to high. There has been at least one member on here who has had one fail. I think you are on the right track.
  6. Sep 23, 2013 at 6:56 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Ok thanks for the help
    I will check under there tomorrow
