Hidden strobes 3rd gen
Discussion in 'Lighting' started by 5nahalf, Mar 11, 2021.
  1. Mar 11, 2021 at 8:22 PM
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I posted a bit in the "what have you done to your 3rd gen thread"
    But I can make a more in depth thread here.
    So, first things first. My life was saved by someone who stopped to check on me, less than a minute after the ambulance picked me up I blacked out, I woke up in the hospital surrounded by people shuffling around trying to figure out whats happening, I couldnt breath and my airways were blocked. They stuck a tube down in my mouth and I passed out again. If the people who stopped for me didnt, I would of died right there in the middle of the highway.
    Ive always stopped for people in need, but now its more of a duty for me to help others in need.
    When stopped my biggest fear is getting hit by someone not paying attention, Ive already had the car I was helping with hit by a drunk driver, and I want to limit the chance of getting hit so I set out to put strobes in my truck.
    I didnt like the normal light bars in the front and rear windows, and I didnt like the idea of drilling holes in my headlights and tail lights to install hide-a-way strobes.
    So I went on strobes n more to see what options there were. I found this, its a 6 channel strobe controller. It has 24 flash modes, steady burn, and the normal on/off. It doesnt have a switch box or anything, so I can control it with OEM style switches to make it seemless.
    Once I got my controller, I needed to figure out where I am going to put strobes, then it dawned on me. The turn signals! I can hook the controller to the turn signals. I just need to figure out how to stop voltage from backfeeding from the controller into the turn signal circuit. This is where puppypunter came in. He designed some harnesses for me that are plug and play, and include diodes to prevent backfeeding. My harnesses should be to my house either saturday or monday. But here is me testing the strobe controller on one of my turn signals.
    This system would be perfect for any of you construction guys, plow, fire and rescue, and police that use your personal truck sometimes. Its 100% reversible, 100% hidden, and retains use of all lights for their normal functions.
  2. Mar 12, 2021 at 6:45 AM
    Tacospike
    Two Trucks
    This is cool
    Toy_Runner and 5nahalf[OP] like this.
  3. Mar 13, 2021 at 10:59 AM
    caribe makaira
    Caribbean, Puerto Rico
    You could have a 2/4 circuit strobe controller and tap the front & rear and/or left & right from inside the cab.
    helix66 likes this.
  4. Mar 13, 2021 at 11:06 AM
    5nahalf
    Erik
    Minnesota
    Yeah, at some point I may upgrade my controller to something with a few more options. Right now its more of a proof of concept.
    Gorillazrus likes this.
  5. Mar 13, 2021 at 11:32 AM
    caribe makaira
  6. Mar 13, 2021 at 11:38 AM
    5nahalf
    Erik
    Minnesota
    Ah, I see what your saying now. Maybe for the next version I will work with puppypunter on something that just plugs into the cab like that.
    helix66 likes this.
  7. Mar 13, 2021 at 12:21 PM
    caribe makaira
    Strobe feed can be 2 wires for front & rear or left & right.
    helix66 and 5nahalf[QUOTED][OP] like this.
  8. Mar 15, 2021 at 2:07 PM
    5nahalf
    Erik
    Minnesota
    Front all done, Thinking of backing the truck part way into the garage after work to finish putting in the rear harnesses and get my lengths for extensions all measured out so I can start building those. Im waiting on some split loom to show up, so Ill just make the rear extensions but not install them.
    scouterjan and MGMDesertTaco like this.
  9. Mar 15, 2021 at 3:50 PM
    caribe makaira
    So the cab harness tap is a no-go for ya?
    5nahalf[QUOTED][OP] likes this.
  10. Mar 15, 2021 at 4:10 PM
    5nahalf
    Erik
    Minnesota
    Have not tried yet. I got these harnesses from puppypunter today. Im going to play around with the c10 plug another day, but I will stick with the puppypunter harnesses I got since I can chose any of the tail lights to be a strobe.
    We might explore the c10 for a harness for people who dont want to run wires to all 4 corners.
    whatstcp likes this.
  11. Mar 16, 2021 at 9:37 AM
    5nahalf
    Erik
    Minnesota
    Started building my extension harness yesterday that goes from the controller to the rear lights. Got the wires all measured and cut, I crimped on the plugs, then went to put the plug on the other side only to find out I crimped both ends of the same wire.... I made a loop :(
    So, took that apart and tried again. Now I have the extension harness for the strobes all done, thursday my split loom should be in and tonight I will be picking up some more power wire for the reverse lights. I also had to order some more waterproof plugs to finish the mirror signals.
    So, shooting for saturday or sunday for a video showing both front and rear, then mirrors when meso finishes the new v5 mirrors.
  12. Mar 17, 2021 at 12:48 AM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    what am i looking at here? what are the two inputs going into? are there diodes in there? can that section being tapped into get really pulled from the truck to be worked on on a bench?
  13. Mar 17, 2021 at 6:53 AM
    5nahalf
    Erik
    Minnesota
    So the c10 plug is on the back of the cluster, its pretty much the turn signal relay. You can intercept the turn signal wires there to insert your strobe signal. You cant remove that section of wire to work on outside the truck, but you can get both male and female c10 plugs from the dealership to make the harness.
    hirod[QUOTED] likes this.
  14. Mar 17, 2021 at 8:21 AM
    caribe makaira
    Like Erik wrote, it's an added harness to intercept the circuits. Here another "view" with 5 pin relays.
    Towing turn & stop are not "intercepted" but can be...
    Relay module (so many choices)
  15. Mar 17, 2021 at 4:51 PM
    5nahalf
    Erik
    Minnesota
  16. Mar 18, 2021 at 12:20 AM
    caribe makaira
    $9.00 relay module
    $25.00 Strobe module
    project box for relay module
    helix66, 5nahalf[OP] and hirod like this.
  17. Mar 30, 2022 at 8:03 PM
    Athena32
    Athena32 Systems Engineer
    Nate
    Colorado
    2021 Tacoma Super White DCSB OR 6MT
    Reviving an old-ass thread, but do you happen to have the correct part numbers?
  18. Mar 30, 2022 at 8:13 PM
    5nahalf
    Erik
    Minnesota
    I think its 90980-12767 and 90980-12766 but im not 100% on that.
  19. Mar 30, 2022 at 8:15 PM
    caribe makaira
    Read #7 again...:burp:
    5nahalf[OP] likes this.
  20. Mar 30, 2022 at 8:52 PM
    Athena32
    Nate
    Colorado
    Didn't realize those were the part numbers on the diagram, thanks :)
    I might actually attempt this... seems like it's somewhat low-effort and low risk as long you build the harness and add diodes so that the flasher doesn't backfeed into the instrument cluster.
