HID Rock Lights Install
Discussion in 'Lighting' started by jberry813, May 5, 2011.
  1. May 5, 2011 at 3:07 PM
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Yes you read that right. HID rock lights. Count em, five 55 Watt HID lights. 25000 lumens of light…pointing at the ground. :eek:
    I’d been meaning to install some rock lights for a while now, but never really found quite what I was looking for. Night time wheeling is a whole different beast and extra lights always help. They also double as landing lights out at Pismo. :D
    I was strolling through my local Wallyworld and came across these small and inexpensive fog lights. They were on clearance for $13 a pair. So I bought the last 3 sets they had. The housings are all metal and the lenses are glass and they have a nice thick rubber grommet to keep out moisture and debris. Pealing back the rubber grommet you can see it uses a standard 55 Watt halogen bulb held in with a small single set screw
    My original plan was not to use HID bulbs, but since the lights were a standard H3 bulb and I had a couple of DDM kits leftover from a previous project, I figured I’d give it a try. The bulbs fit the housings perfectly with room to spare. I replaced the set screw with a slightly larger screw with a larger surface area to ensure it wouldn’t move around too much.
    Next I cut a small slit in the rubber grommet for the back of the bulbs and wiring and slid it back into its original spot. Wrapped it with some electrical tape to keep any extra debris out and call it done.
    I repeated that process 4 more times for a total of 5 lights. I actually had to order an additional set of HIDs as I didn’t have 5 on hand, so this was a bit of an ongoing project.
    The lights themselves are quite small and can fit in relatively tight spaces. Finding a spot to mount the lights was easy. Finding a spot for the ballast was slightly more challenging.
    The front two lights are behind the front bumper and shine directly in front of the front tires.
    The middle two lights are mounted in between the front and rear tires directly on the frame. Again my goal was to have them project in front of the tires but these lights really flood.
    The last one was mounted where my rear spare tire carrier used to be. I have a full sized spare in the bed of my truck and have no use for the old tire carrier so I unbolted it and put the last light in its place and facing slightly to the rear.
    Wiring was is pretty straightforward. I did run into one small snafu when wiring this up though. Five lights at 55 watts each is a total of 275 watts. Total current draw for that at 12 volts is 22.9 amps. I ran two strands of wire. Two lights (passenger side) on one strand, and three lights (driver side and rear) on the other. I figured at 22.9 amps I could use a single relay and a single 30 amp fuse. While this worked, it didn’t work for long. The fuse got super hot and blew after a few test uses. Unbeknownst to me, HID’s pull more than twice as much load when the bulbs are first heating up. Meaning instead of 22.9 amps it was drawing more than 46 amps when warming up. So I split it into two separate circuits.
    I had bought a small 6 circuit auxiliary fuse block a while back and this was as good excuse as any to finally put it to use. The fuse block is made by Blue Sea. Each circuit is rated at a max of 30 amps and the total block is rated at 125 amps. I ran a 4 AWG line from the battery to the fuse block with an inline 100 amp AGU fuse. The whole package bolted down to a piece of steel and mounted behind the factory fuse block.
    And now, the finished product. Get your suglasses ready :cool:
    The pictures really don’t do it justice but these things light up my entire street. Can’t wait for the next Pismo trip.
    jammer, Dalandser and BandanaBerg like this.
  2. May 5, 2011 at 3:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. May 5, 2011 at 3:13 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Damn Jason! nutty... atleast now you can clearly see all the mud flying up into your airbox! :D:D:D:D:D
  4. May 5, 2011 at 3:16 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Is that the chris4x4 "DAM!" of approval or the chris4x4 "DAM!" you'r an idiot. I can never tell.
    I'm seriously never living that one down huh? I'm working on a solution though. It involves a midget and zipties ;)
  5. May 5, 2011 at 3:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oh no. Thats Approval! Well done!!
  6. May 5, 2011 at 3:22 PM
    Sabre
    Sabre Well-Known Member
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    sick right up! i really like it
  7. May 5, 2011 at 3:39 PM
    PreRunnerSeth
    Apex, NC
    You just need to put a hamster in there with a tiny bucket.. :)
  8. May 5, 2011 at 6:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I can die happy now :D
    Thanks!
    Excellent plan B! He can bail through the deckplate.
  9. May 6, 2011 at 7:31 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    haha thats great! Ive had a set of those lights on my last taco, one for a backup light and one for a bed light. the backup light didnt last long, blew out and then got crushed crossing a dried out ditch...:eek:
    but the bed light always worked great. I always wondered what these would be like with HID's in them :eek: :cool: :thumbsup:
  10. May 7, 2011 at 11:17 AM
    ironman44bear
    ironman44bear "Toyota Mafia" MORE BALLS THAN BRAINS
    Billy
    Clovis,CA
    05 DC Taco 4x4
    Nice work OP, i'm gathering up parts to do the same..:D 1 rep for you sir:cool:
  11. May 7, 2011 at 11:39 AM
    booboy
    booboy Well-Known Member
    PaCiFiC nOrThWeSt
    2010 TrD SpOrT 4x4
    That's tight! Awesome job brotha!
  12. May 7, 2011 at 11:55 AM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    holy snaapppss... looks good brotha....
  13. May 7, 2011 at 1:45 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Thanks guys!!! :cool:
  14. Apr 14, 2012 at 9:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Epic WIN!
  15. Apr 18, 2012 at 11:32 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    WOW nice work. Super clean. Really nice size housing. I have a little bigger housing im retrofiting with 9W LED bulbs for reverse lights.
    1+ for you sir. Sick rig.
  16. Jul 23, 2012 at 5:37 AM
    Fati Tacoma
    Fati Tacoma Well-Known Member
    Epic. Nice set up here! What brand are the lights? I'm having trouble finding small lights with glass lenses and decent protection in the back like yours.
  17. Jul 23, 2012 at 5:49 AM
    taco4x4
    taco4x4 Well-Known Member
    Chad
    North Carolina
    2008 Tacoma 4 door trd off road
    3 inch Tuff Country Suspension lift, Removed the Mudflaps, Tinted windows, Nitto Trail Grapplers with 18x9 XD Monsters debadged and aftermarket grill. Fog light anytime mod. Hids in fogs and headlights and all led lights. Flowmaster 40 series. Bed pocket lights mod.. TRD Seat covers, Aries Bull Bar Plasti-Dipped Black with 2 Hella 700 converted HID.
    SWEET!!!
  18. Jul 23, 2012 at 6:51 AM
    Taco Man in HD
    Taco Man in HD DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
    looks great man!
  19. Jul 23, 2012 at 7:19 AM
    uneekvisions
    uneekvisions Active Member
    Steven
    Austin, Texas
    05 TRD Sport 4x4 Super White
    Revtek Susp Lift, OEM Skid Plate
  20. Aug 2, 2012 at 8:54 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Nice write-up! How are the lights holding up so far?
