Hi Lift Jack Dangers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaCawd2007, Oct 19, 2021.
  1. Oct 19, 2021 at 7:49 AM
    TacomaCawd2007
    TacomaCawd2007 [OP] Well-Known Member
    2021 Toyota Tacoma TRD 4x4 Off-Road
    Using a high lift jack can be extremely dangerous, as most of us know. TW users, what do you suggest for new Hi Lift Jack users to know before they use it?
  2. Oct 19, 2021 at 7:54 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    Try it out in your driveway. Only go up 1-2 clicks over lifting your vehicle off the ground, then push your vehicle side to side or front to back to familiarize yourself with the concept that if it can tip it will. Sometimes far easier than most jacks you are familiar with.
  3. Oct 19, 2021 at 7:55 AM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    Spit on it before jacking, jk. In all seriousness I have one and I use it by lifting up my truck by the rock sliders to rotate tires, work on the suspension and whatever else. I've never had a problem, I occasionally just lube up the jack and inspect it from time and time. Once the vehicle is lifted I put it on jack stands because I don't trust that Jack for shit.
  4. Oct 19, 2021 at 7:56 AM
    Squatting Pigeon
    Squatting Pigeon Remember, bird watching goes both ways. Moderator
    North Texas
    TRD OR 4R | GR Corolla
    If you’re lifting from the side/sliders always open the door in front of the jack, especially on unlevel surfaces. The vehicle goes up at an angle and when it comes down you might ram the jack into the door.
  5. Oct 19, 2021 at 7:57 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Thats how you get the cool kid dents!
  6. Oct 19, 2021 at 7:59 AM
    Squatting Pigeon
    North Texas
    It’s the perfect spot for a jdm yo bandaid sticker too!
    Junkhead and Chunk[QUOTED] like this.
  7. Oct 19, 2021 at 9:08 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I bought one a year ago, tested it out on my off-road car when I got home. In the span of 10 minutes I smashed a finger and had the car almost fall on me twice!
    I returned it to the place where I bought it the same day.
    I carry a 2 ton floor jack in my tow rig and factory-style bottle jacks in everything else. I feel much safer using those.
    DAS Taco and jackn7 like this.
  8. Oct 19, 2021 at 9:10 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  9. Oct 19, 2021 at 9:13 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Remember that the lift 100% requires that the load being lifted be stable, because the jack isnt going to be doing it....
    So think about how the load (vehicle) can shift to cause the jack to cause 'a really bad day'.
    For example, lets say you jack up the rear of the vehicle with the hi-lift, which lifts the (2) rear wheels (which had the hand-brake on). Now the vehicle can roll forward or aft off the jack.
    Or same scenario, but you put the truck in 4lo first... HAHAHAH now it wont roll forward, right? Well it might not roll but the front diff can allow the truck rear to pivot left/right around the front axle.
    So stop and think HARD about what is keeping the vehicle stable, and if any of those stabilizing features are gone when you lift the wheels clear.
  10. Oct 19, 2021 at 9:14 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    And ALWAYS put your fingers in a possible pinch point while using...
  11. Oct 19, 2021 at 9:23 AM
    0xDEADBEEF
    He was putting the jack into place at that point, not lifting yet
    Superdave1.0 and Junkhead like this.
  12. Oct 19, 2021 at 9:24 AM
    0xDEADBEEF
    This applies with any jack really. Found that out the hard way with a scissor jack on a hill :laughing:
  13. Oct 19, 2021 at 9:25 AM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    My checklist for setup: Stabilize the base. Solid surface on the truck for contact. Chock wheels if needed. Pad between the jack and vehicle if it looks like it could pivot into vehicle. All parts of the jack present (never know what might rattle off someday). Read the instructions (I don't use it often enough to trust myself).
    Checklist for use: Nothing goes between the jack and the vehicle. Nothing goes between the handle and the rail during jacking operation ever (this is the smash point where people break bones and lose teeth. Imagine that handle slamming into the rail with the weight of the truck powering it). Nothing you don't care to smash goes under the truck once you decide to lower - treat it like it could just drop.
    vicali and 0xDEADBEEF like this.
  14. Oct 19, 2021 at 9:27 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
  15. Oct 19, 2021 at 12:24 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Find someone who knows the ins and outs of using a hi lift and take lessons.
  16. Oct 19, 2021 at 12:25 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Stand off to the side.
  17. Oct 19, 2021 at 12:28 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    slider adapters are really helpful lifting from rock sliders. otherwise they can get pretty slippery on muddy round tube.
  18. Oct 19, 2021 at 12:35 PM
    YellowSnow
    YellowSnow Chasing Pink Taco
    San Diego
    19 TRDOR
    KING/YOKOHAMA/RLD/RRW/RCI/BAJA/ROOFNEST
    I thought based on everything i've seen cruising the Mall, that these were only intended for Jeeps....:notsure:
    MadDaddy, Tacotsubo and Cereal_killer like this.
  19. Oct 19, 2021 at 12:36 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Normal people just don't strap them to their hoods and carry them 24/7.
    slander, Junkhead, Kev250R and 3 others like this.
  20. Oct 19, 2021 at 2:39 PM
    89hatcher
    89hatcher Well-Known Member
    spend the money and get a pro eagle jack.
