HHA ATC, HHLP ATM, or HHH ATM Add a Fuse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Airlnkr, Mar 16, 2021.
  1. Mar 16, 2021 at 8:52 AM
    Airlnkr
    Airlnkr [OP] Member
    Derek
    2019 Magnetic Gray TRD Sport
    Remote Start TRD Nerf Steps
    2019 Taco TRD Sport
    Just got a new taco...Trying to get all my parts lined up for when my new TRD Pro Grill and Lights come Thursday. I was in autozone yesterday and came across a Bussmann HHA ATC, HHLP ATM, and and HHH ATM Add a Fuse. Which one is the correct one? Also is their certain fuses I should use (Bussman, etc.) besides the factory for when I connect it in the fuse box?
  2. Mar 18, 2021 at 7:11 PM
    Airlnkr
    Airlnkr [OP] Member
    Derek
  3. Mar 18, 2021 at 7:52 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    For led lights a normal blade fuse which I think is technically an atc fuse will work perfect. Always fuse to protect the wire size you’re using
  4. Mar 18, 2021 at 8:05 PM
    DrummyTaco
    DrummyTaco Feeeesh
    Outer Banks
    2017 Tundra Platnium, 2017 SR5 DCLB 4x4 (rip), 1996 reg cab 4x4, 1997 xtra cab 4x4
    If you’re looking to use an add a fuse to power your switch, there’s a small fuse box under your dash. It uses low profile mini fuses (APS)
    Airlnkr[OP] and CLVol1255 like this.
  5. Mar 18, 2021 at 8:05 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    http://assets.bluesea.com/files/resources/reference/20010.pdf
    save this in your files on your phone. Great reference guide. I would never use glass fuses in my truck fwiw so skip the glass fuses and next up is the blade fuses or ato atm up to 30a then you’ll use maxi or ANL. that guide shouod lead you. Most LEDs are going to use less than 10a per even the brightest and most led light bars 30inch and below are gonna use anywhere from 20a-50a. Learn OHMs law for DC electrical
    Airlnkr[OP] and eurowner like this.
