HELP WITH WATER PUMP HOUSING CLEANUP!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by laker09champ, Feb 22, 2025.
  1. Feb 22, 2025 at 4:52 PM
    laker09champ
    laker09champ [OP] Member
    So in the middle of a timing belt on a 5vzfe. Trying to clean up this water pump housing. It had this nasty baked on paper gasket. Been scraping with a razor perpendicular to the surface for an entire afternoon.. Now that i took a pic and zoomed in it seems like the surface has these micro scratches or gouges on it in some areas. When I run my finger it feels smooth. Am I ok? Or did I f this up? Also do I need to leave it spotless in order for the new water pump to seal properly? Any help is truly appreciated! Thanks!!20250222_163206.jpg 20250222_164937.jpg
  2. Feb 22, 2025 at 5:24 PM
    jruiz555
    jruiz555 Well-Known Member
    When i replace engine parts, i always use an aluminum oxide sanding sponge, then clean it with brake cleaner. its normally very smooth after that and the silicon fills in the imperfections. make sure everything is very clean before you lay down the sealant, just my opinion.
    kinda looks like your leaking oil at the valve covers?
  3. Feb 22, 2025 at 5:39 PM
    laker09champ
    Thanks for your reply. So I haven't screwed this up? I wasn't planning on using sandpaper to smooth out the surface but I guess I could put some Sandpaper on a block to sand flat. I bought the aircabin man kit so i have the Aisin water pump with the metal gasket. Would it be a good idea to add a bead of rtv on the housing for a better seal? And yup. If i can get through this timing belt I need to fix my valve cover leaks.
  4. Feb 22, 2025 at 6:24 PM
    jruiz555
    The aluminum oxide is very fine, i wouldnt use sand paper. I use red gasket maker with the gasket, make sure you use the correct sealant.
  5. Feb 22, 2025 at 6:25 PM
    jruiz555
    The aluminum oxide sponge only preps the surface, u dont want to dig into it or scratch it.
    Are u sure the water pump is a metal gasket? I dont remember it being metal. Metal gasket is normally for manifolds and heads
  6. Feb 22, 2025 at 6:51 PM
    laker09champ
    I thought it was metal. I'll check and get back to you. Harbor freight has some fine grit aluminum oxide sponges. I'm going to give those a try.
  7. Feb 22, 2025 at 6:59 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    its fine, put the pump back on.....
    Superdave1.0 likes this.
  8. Feb 22, 2025 at 7:14 PM
    laker09champ
    Put it on as is? Even those scratches and some gunk left?
  9. Feb 22, 2025 at 8:44 PM
    slater
    San Diego
    can you feel it?
    doesnt look bad....
    or if not in a hurry...
    get some, stuff works amazingly, we use it to prep blocks & heads, removing exactly what your struggling with.
    I wouldn't stress on the scratches, or you could try polishing it out with a fine scratch bite pad, I wouldn't use san paper...
    https://www.oreillyauto.com/detail/c/motorcraft/motorcraft-remover-silicone/mot0/zc30a
    this chemical & plastic scraper, or carefully with a razor blade, even go over it with this chemical & just polishing it out with a shop rag...
  10. Feb 22, 2025 at 8:50 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    This
  11. Feb 22, 2025 at 8:58 PM
    laker09champ
    If I run my finger across it, I can't feel it. It's feels smooth to the touch. I'm not in a hurry. I just want to do this job right and not have to go back. I might have to order that chemical. I tried a crc gasket remover, it helped a little bit but, nothing to rave about.
  12. Feb 22, 2025 at 9:00 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Fine emery cloth. Attach it to a small block of wood, or use it just with your hand. It will smoothen out the surface and take off the remaining baked on stuff. I'm a mechanic and use it daily on head surfaces, water pump surfaces, etc.
  13. Feb 23, 2025 at 11:52 AM
    Glamisman
    Glamisman Well-Known Member
    I have used these for decades A little WD40 and very light pressure, you will feel when it is clean.
