Help with new tire size
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Feb 13, 2016.
  1. Feb 13, 2016 at 5:56 PM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Trying to figure out what size tire I can fit at stock height. Want a little taller and wider then the 31x10.5x15 I have on now, and I want to go bigger then a 15" rim.
    What about this tire size?
    285/70/17
    Will it fit stock height?
  2. Feb 13, 2016 at 6:13 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    That will fit if you never plan to turn your steering wheel. That's basically a 33" tire. Lots of rubbing.
  3. Feb 13, 2016 at 8:58 PM
    smmarine
    Melbourne FL
    33 is a bit bigger. I know the 1st gen will fit 32s, just not sure if I can fit this.
  4. Feb 13, 2016 at 9:09 PM
    mountain mike
    mountain mike Woodsbum
    the backwoods...
    2003 DCSB 4x4
    just what I need to do what I want
    Forgive my quick diversion, but ToyoTaco02, how are your three lights mounted? This is what I want on my 03 DCSB and cannot find a good picture or explanation of how to do it from someone who has had success with it. Will you please pm me some pics and/or description? Thanks in advance. Sorry for the thread jack but this is perfect timing for my next project.
  5. Feb 14, 2016 at 11:00 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    even with a 31x11.5 you would rub a little due to the increased width. going up in diameter would make it rub sooner. spacers/pinch weld if you get the 285/70, maybe even mud flaps at that point.
  6. Feb 14, 2016 at 8:34 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yip they'll rub if ya just slap em on and go.
  7. Feb 14, 2016 at 8:39 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    2nd gen 275 70 17 with stock wheels some rubbing, 4.75 BS no rubbing...
    I think you can get a 265 70 17 with min problems....
  8. Feb 15, 2016 at 7:19 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    If you are changing wheel size to 16", you should be able to fit the OEM 265-70-16 tire without issues.
    Good luck.
  9. Feb 15, 2016 at 5:06 PM
    Assforkr
    Assforkr Well-Known Member
    MA
    03 taco
    265/75/16 will rub on full turn especially with an aggressive tread tire. You can pull off the mudflap and use a heat gun to melt the wheel arch back a bit. I went wth grabber at2s and the rub was definitely there. Also very close to the frame with potential for rub.
  10. Feb 15, 2016 at 5:33 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I have 265/75/16 on my truck, no lift, does fine even when out wheeling
  11. Feb 15, 2016 at 7:02 PM
    Ritchie
    Uhm... OK.
    OP,
    You'll be fine with no lift and 265-70-16's.
  12. Feb 15, 2016 at 7:05 PM
    Ritchie
    I ran 265-75-16's for quite a while. No rubbing, period.
    Good luck.
  13. Feb 15, 2016 at 7:09 PM
    Assforkr
    MA
    03 taco
    Sometimes the AT tire tread makes a difference. Grabbers definitely rubbed at full lock, just got them a month or two ago.
  14. Feb 15, 2016 at 8:58 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    pretty sure he doesn't want stock size, which you are suggesting :)
    @smmarine it all depends on the tire and tread if/how much they will rub.
  15. Feb 16, 2016 at 5:04 AM
    Ritchie
    ... yeah, my bad. I meant 265-75's.
    Good catch, thanks.
