Help with fog light drl wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaDad79, Aug 28, 2022.
  1. Aug 28, 2022 at 6:25 AM
    TacomaDad79
    TacomaDad79 [OP] Member
    Joe
    08 Elec Blu Double Cab Base 4x4, TRD sport pkg
    I'm posting this in hopes someone can give me guidance. I purchased a pair of led fog lamps which have a halo drl option. There is a separate power wire for the drl and i dont know where to run it or what to tap into. I would like the drl to come on during the day only while the truck is running. Any help is appreciated. Thanks.
  2. Aug 28, 2022 at 7:47 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    How handy are you with wiring?
    The most convenient ignition source I see in the engine bay is the alternator IG feed wire (Light Green) (powered by the IG1 No2 fuse 10A hot in run & start), it goes through connector EB1 (Pin3) in the engine compartment fuse box.
    Not sure how much current those lights take but I would run them to that wire through a 3 amp fuse (if they take more than 3 amps you will need to use a relay).
    I would use a wire tap or solder and heat shrink, don't do the twist n tape.
    If you would prefer to use a fuse tap you would have to go to the interior fuse box (WIP 30A, WSH 10A, or BKUP LP 10A would probably be the safest to tie into here)
    Location of the connector and wire on my truck for reference.
    TacomaDad79[OP] and TnShooter like this.
  3. Aug 28, 2022 at 11:42 AM
    caribe makaira
    Caribbean, Puerto Rico
  4. Aug 28, 2022 at 1:11 PM
    TacomaDad79
    Joe
    Such good replies, I wish I was more competent at reading wiring diagrams though. It's like a foreign language to me. I will try to go to the interior fuse box with a fuse tap. The wires that came with aren't very long so not sure if that will work though. The lights didn't come with any instructions , go figure. Thanks so much!
  5. Aug 28, 2022 at 5:06 PM
    caribe makaira
    Wires from the DRL part of the added lamps go to the relay pin 87.
    Relay pin 30 & 86 connects to the add-a-fuse which in turn goes in the engine bay fuse/relay box to any circuit there where it can fit without problems when closing the cover to the box. This connection provides juice to the actuation coil of the relay (think switch) and fused power.
    Relay pin 85 goes into the cab. This part could be a bit tasking, you need to identify the connector on the back of the cab relay/fuse/ecu box. This connector ahs only 3 wires going to it. You only need to tap into the green with red stripe. I recommend using a posi-tap type. This wire controls the DRL/TURN relay. When the low beams are selected the Body ECU cuts the ground signal to this wire turning OFF the DRL feature of the turn signals.
    Anything else, ask away...
  6. Mar 13, 2024 at 2:48 PM
    Braketest2
    Braketest2 Well-Known Member
    Jim
    2019 TRD Off Road
    AFE Y-pipe, 2.5 inch catback CAI 3 inch Dobinson's lift
    Would you know if I could take out my LED/DRL fogs and use the H11 assembly and be able to utilize the OEM fog wiring? Thanks!
