Help with coolant leak under thermostat please
Discussion in '1st Gen. Tacomas (1995-2004)' started by TIKIB, Jan 4, 2018.
  1. Jan 4, 2018 at 2:15 PM
    TIKIB
    TIKIB [OP] New Member
    Blake
    Mustang, OK
    2001 Tacoma TRD V6 4wd Automatic
    2001 V6 155k leaking a lot of coolant. Seems to be coming from around the bolt directly under the thermostat housing. The bolt goes to the bracket that runs under the alternator. Is the leak coming from the thermostat or am I missing something.
    Crooklyncat likes this.
  2. Jan 4, 2018 at 2:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    There are leaks that would be hard to tell if they're coming from the thermostat or the water pump since the water pump is covered by a metal cover. More pics and / or a video might help to tell exactly where it's coming from. There's a good chance you're going to have to get in there to see what's going on.
    Running Board Man likes this.
  3. Jan 4, 2018 at 3:05 PM
    TIKIB
    Blake
    Mustang, OK
    That's what I was thinking. It started the day it got down well below freezing, today was the first chance I had to wash it out and take a look. Thanks for the help.
  4. Jan 4, 2018 at 3:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The color doesn't look like coolant but I suppose it could be very diluted 'green' coolant.
    In the area it is coming from, the likely culprit is the water pump is leaking. How many miles has it been since you changed the timing belt?
  5. Jan 4, 2018 at 4:01 PM
    TIKIB
    Blake
    Mustang, OK
    Yeah, it's diluted coolant. Not sure on the water pump. Bought the truck with 106k from a dealer. No notation on if the water pump and timing belt had been changed . Dealer hasn't done either one. Took it to my families mechanic after I bought it and he said it looked as if the timing belt was done. Of course there was no way to know if the water pump was done.
  6. Jan 5, 2018 at 5:15 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    I would say most likely a gasket is leaking at the mating surface. the gaskets have holes for the bolts. Hard to tell from that pic. I always rub a thin coat of black RTV on both sides of coolant gaskets before install even if the gasket is new. peace of mind.
  7. Jan 5, 2018 at 9:04 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If you are mechanically inclined enough to replace the timing belt, it will cost you around $260 to completely replace all three outer belts, the timing belt, the tensioner pulley, the idler pulley (that the timing belt goes around), the two cam shaft bearings, the crank shaft bearing, the water pump, and the thermostat. The price comes from the e-Bay reseller and is for all genuine Toyota parts.
    You'll hafta buy the crank shaft bolt direct from Toyota for (IIRC) about $8.
    There is an excellent video that shows, step-by-step, how to replace those parts from "Timmy" on YouTube.
    Steven G likes this.
  8. Jan 5, 2018 at 9:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Steven G and Xbeaus like this.
  9. Mar 29, 2018 at 5:24 PM
    Money.Makin.Manny
    Money.Makin.Manny New Member
    Manny
    2004 Toyota Tacoma SR5 4WD
    Did you ever figure out this issue? I just did my timing belt, water pump, thermostat and drive belts and happened to get this leak soon after.
  10. Mar 29, 2018 at 5:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Where is the top of the leak coming from - behind the H2O pump?
  11. Mar 29, 2018 at 5:34 PM
    Money.Makin.Manny
    Manny
    Same exact spot as in the picture.
  12. Mar 29, 2018 at 6:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That sucks - unfortunately I don't know if there's any way to figure out what happened besides opening it up again.
  13. Mar 29, 2018 at 6:16 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If it's leaking around the thermostat, why not just replace the thermostat and gasket? It would take you maybe an hour to do, the most time consuming part being drain and refill.
  14. Mar 29, 2018 at 6:39 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'd at least look at that too. The worry is that it's running down from the wp and isn't visible until it hits the thermostat area. Still easy fixes hopefully work first.
  15. Sep 23, 2018 at 7:13 PM
    DIYing
    DIYing New Member
    Are the shafts around thermostat screwed in before tightening nuts?
  16. Sep 23, 2018 at 7:51 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The studs? Yes they can be snugged up gently before the nuts are torqued down.
  17. Nov 9, 2018 at 8:42 AM
    lhbull
    lhbull New Member
    02 tundra v-8
    camper
    I found a leak on my 02 that the alternator bracket bolt screws into a coolant passage, leaked around the bolt.
    Took it out and used thread tape and sealer on the threads and no more leak.
    funkeedingus likes this.
  18. Nov 11, 2018 at 6:21 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I usually use aviation permatex on the threads that see water jacket areas, doesn't harden and seals real well.
  19. Mar 27, 2019 at 5:06 PM
    VIguy52
    VIguy52 New Member
    2001 Tacoma TRD 4X4 3.4L 5spd.
    Did you ever find the exact source of the leak or try something out that happened to work? Getting the same problem with no good viewing points.
