Help with AC problems.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudFlap, Aug 9, 2019.
  1. Aug 9, 2019 at 6:34 PM
    MudFlap
    MudFlap [OP] Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Air conditioner in 2012 has been getting weaker last couple years. Not blowing as hard it seems. I would have to drive almost 3 hours with the AC at max blowing high to get cold enough to make me want to turn it down. Finally last week, the high speed on the blower STOPPED working. A Google search led me here and I'm seeing when resistors go out people are left with high speed only working. With mine, only high speed stopped and the others are fine. Will the resistor cause my problem?
    I'm also wondering why my AC is blowing from the defrost vents when I have it set to front vents only. It causes annoying condensation and I'm THINKING because my air flow is being split, that this is the reason why my air has been seeming weak. My truck didn't do this.new, it only started last summer.
    In short, will a resistor cause a loss of only high blower speed? And why is my air flow not going to the correct vents?
  2. Aug 9, 2019 at 7:55 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Looks like you have a bad blend door actuator. You will likely need to replace it along with your resistor and the pigtail that plugs into it.
    wilcam47 likes this.
  3. Aug 9, 2019 at 8:02 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    might need a top off on your R134, the blower problem sounds like a resistor...
    b_r_o likes this.
  4. Aug 9, 2019 at 8:05 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I would say both of these based on your symptoms
    wilcam47[QUOTED] likes this.
  5. Aug 9, 2019 at 8:24 PM
    MudFlap
    Tim
    2012 TRD Off Road
    I also need to add that when I turn the knob to select the other vent settings, the air is redirected and changes as it should. It also seems to change between outside and recirculate as it should also.
    I could be wrong, I know I dont know a lot about AC systems but adding more R134 doesn't seem to fit. The AC is blowing cold, it's just not blowing very hard.... even when the blower high speed was working.
  6. Aug 9, 2019 at 8:30 PM
    wilcam47
    Will
    Bourbon state
    possible, my Nissan titan was brand new and AC never really was cold from the start. I decided to check the pressures, bout a top off can, and guess what it was a the bottom of the green band for the temp. I topped it off above the green band and talk about work! it froze you out in no time. Also...may not be the issue but its easy to check.
  7. Aug 9, 2019 at 9:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Look for an obstruction in the air path, check the cabin filter.
    Take the blend door servo off and turn the hinge, make sure it has its full range of movement. The servo motor itself can break easily, it may be broken already
    Find the threads around here that describe the blower motor/resistor/ harness repairs
    Get some manifold gauges on the a/c system and make sure its operating correctly
    MudFlap[OP] likes this.
  8. Aug 10, 2019 at 12:01 PM
    Muddinfun
    Muddinfun Well-Known Member
    If the blower doesn't work on high, the problem is not the resistor. On a properly working truck, you can take the resistor out and throw it in the wood chipper and the fan will still blow on high.
    Go buy a Mcdonalds breakfast. When you're done, use the plastic knife to pop out the heater/AC control panel. Unplug the fan switch connector and look for burnt terminals.
    TexasWhiteIce, Jeffch and MudFlap[OP] like this.
  9. Aug 10, 2019 at 12:11 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Food and panel tools all in one! Kinda, :thumbsup:
    Skyway and Muddinfun[QUOTED] like this.
  10. Aug 14, 2019 at 7:17 AM
    fredlyzone
    fredlyzone Member
    Fred
    Austin, Texas
    2010 Tacoma PreRunner 4x2 TRD Off Road w/JBL
    Bilstein 5150, Stereo upgrade
    Where do I find out about these resistors? I have the problem where the fan only blows on high!
    *** UPDATE.
    I found the info about the resistor fix on another thread here. My plug to the resistor pack was just slightly discolored and disconnecting/reconnecting actually made things work. I went ahead adn bought a new (updated) resistor pack and pigtail off Amazon for $20. I cut and soldered the new pigtail but the kit came with crimp connectors. The new resistor pack looks a lot more solid state then the factory on. Fairly easy to install except getting that back screw out and back in. Hopefully I will not need to do this ever again!
  11. Aug 18, 2019 at 6:30 AM
    MudFlap
    Tim
    2012 TRD Off Road
    Just do a Google search on it, you'll wind up back here in no time.
    fredlyzone[QUOTED] likes this.
  12. Aug 18, 2019 at 6:32 AM
    MudFlap
    Tim
    2012 TRD Off Road
    You was correct Sir! Thanks for that! Now I need to find a control panel and then find out if the pin in wire harness is toast as well....
    Muddinfun[QUOTED] likes this.
  13. Aug 18, 2019 at 7:01 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I bought a kit at AutoZone that was a resistor, pigtail connector and butt slices for under $30. and I haven't had in issue since. Took about 30 minutes. Stagger the butt splices so the harness doesn't look like a snake with a fresh kill in it.
    There are several threads on this...
  14. Aug 18, 2019 at 7:09 AM
    MudFlap
    Tim
    2012 TRD Off Road
    Just found a control panel on Ebay for 72 bucks from a junk yard in the north east somewhere.... I checked the prices with Toyota sites (part number 55900-04070 for those that have this problem in the future) and of course Toyota is high as giraffe coochie. Cheapest I found new from Toyota was 300 range.
    Now I'm scared as hell my wire harness will have to be replaced too.... anyone have any tips with this? Can a burned out pin be repaired? Should I consider cutting off and splicing in another plug?
    Muddinfun likes this.
  15. Aug 18, 2019 at 7:11 AM
    MudFlap
    Tim
    2012 TRD Off Road
    This is what it looks like....
    Partychief67 likes this.
  16. Aug 18, 2019 at 7:14 AM
    Larzzzz
    Larry
    MA
    Ouch! Look at the face of the plug where it inserts, there's a number. It's friggen tiny, but there's a number on it.
    You can more than likely buy the connector body and repair wires to fix it.
    That number will make it easier for them to ID it in the diagram.
  17. Aug 18, 2019 at 8:50 AM
    MudFlap
    Tim
    2012 TRD Off Road
    Where would I find that at? At a Toyota dealer? Autozone?
  18. Aug 18, 2019 at 9:05 AM
    otro_taco_negro
    otro_taco_negro Well-Known Member
    Dylan
    Tacoma, WA
    2015 TRD Sport DCSB
    Sub'd. my AC always blows through the windshield vents too, been looking for a fix but haven't found one yet.
  19. Aug 18, 2019 at 10:43 AM
    Muddinfun
  20. Aug 18, 2019 at 2:21 PM
    Larzzzz
    Larry
    MA
    The connector body is a dealer item afaik.
