Help! Why? Blown 120A alternator fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bmcmahan, Jul 14, 2018.
  1. Jul 14, 2018 at 7:24 PM
    Bmcmahan
    Bmcmahan [OP] Member
    2011 Tacoma 2wd 4door pre-runner V6
    My husband was replacibg my battery and upon connecting the positive terminal the alternator (120A) fuse blew. I ran and got another fuse... again blew. What could be the cause?! How can we trouble shoot?!
  2. Jul 14, 2018 at 7:37 PM
    caribe makaira
    Caribbean, Puerto Rico
    Maybe..just maybe he attached the negative first then the positive closing the circuit...
    I remove battery by disconnecting the negative first then the positive.
    When I install the battery, I connect the positive first then the negative...but that's just me.
    TireFire likes this.
  3. Jul 14, 2018 at 7:45 PM
    Bmcmahan
    He actually did the negative then the positive as his usually way... could that be an issue? How?
    Thank you for responding!!! I need all the help I can get! :)
  4. Jul 14, 2018 at 7:50 PM
    Muddinfun
    Muddinfun Well-Known Member
    It doesn't matter which you hook up 1st. The problem is that he hooked up the battery backwards.
    EDDO, SocalTaco15, landphil and 2 others like this.
  5. Jul 14, 2018 at 7:51 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    Our batteries are a "F" the and the + and - are backwards from a standard battery. Are you sure the - post is next to the fender?
  6. Jul 14, 2018 at 7:51 PM
    Muddinfun
    Hopefully....... he didn't fry the alternator or any electronics.
  7. Jul 14, 2018 at 7:52 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    That’s a big fuse to blow without any fireworks/sparks.
  8. Jul 14, 2018 at 7:52 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    Check to see if alternator is shorted or a wire burnt there, might be that, then check battery polarity and voltage.
  9. Jul 14, 2018 at 7:53 PM
    Muddinfun
    The negative post has a - next to it. The negative cable attaches to the body.
  10. Jul 14, 2018 at 8:12 PM
    Bmcmahan
    We verified polarity immediately after and we were hooked up right.... however we just replaced the connects to the battery wires and after a lot of discussion, we think he did them backwards... so yeah it is probably all jacked up... we will be figuring it out in the morning.... and yes there were sparks! Ha..... I may be hitting you guys up tomorrow as well! Any suggestions for what we have in store?
    Sandman614 likes this.
  11. Jul 14, 2018 at 8:17 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Hopefully it's just the popped fuse and maybe a new battery.
  12. Jul 14, 2018 at 8:30 PM
    Bmcmahan
    Lord.... it is my prayer. My husband is beside himself over this one. Not like him , but this is potentially a huge screw up :(
    I will let you guys know... thanks again! You guys are awesome and I am excited to find this site!!
  13. Jul 14, 2018 at 8:31 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Shit happens to even the best of us. We get tired, overrun, etc.
    PzTank, EDDO and Bmcmahan[QUOTED][OP] like this.
  14. Jul 14, 2018 at 8:32 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Battery wires are ass backwards
  15. Jul 14, 2018 at 8:33 PM
    Bmcmahan
    Yep...........
  16. Jul 14, 2018 at 8:36 PM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    Hopefully the fuse prevented further damage.
    PzTank, Sandman614 and Bmcmahan[OP] like this.
  17. Jul 15, 2018 at 12:30 PM
    Bmcmahan
    Ok, got a new fuse and battery, corrected the connectors to the battery. Small miracle the truck started and will go into gear but the “throttle” will not work, pressing the gas pedal does nothing... any suggestions?
  18. Jul 15, 2018 at 12:30 PM
    Bmcmahan
    Oh and no radio... but nothing else obvious yet...
  19. Jul 15, 2018 at 12:57 PM
    Taco'09
    Taco'09 Well-Known Member
    You are going to have to chase more fuses and relays. Do you have a wiring diagram?
    outlawtacoma likes this.
  20. Jul 15, 2018 at 1:02 PM
    Bmcmahan
    We found the radio fuse blew but not the ecu-b fuse surprisingly. No we do not have a diagram....
