Help! Wheel "wobble" with new rims.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scubamike, Nov 12, 2017.
  1. Nov 12, 2017 at 8:59 AM
    scubamike
    scubamike [OP] Well-Known Member
    Fort Bragg, NC
    2017 Quicksand Tacoma TRD Sport 4x4
    PIA 350 yellow LED diving lights, blacked out all emblems, custom color matched grill, hood deflector, bed liner, LED's all around, front bull bar
    2017 Tacoma TRD Sport. Double cab, short bed.
    So I removed the stock rims and replaced with ones I purchased from 4 Wheel Parts. Old rims were 17's, so replaced with 17's. Old stock rims had an offset of 30, new rims have an offset of 0.
    Installed at a local shop, high speed balanced and fit with no issue.
    Starting at about 40mph and getting increasingly worse as I reach 60mph is a really odd "wobble" that shakes the steering wheel. Feels like it's coming form the front end.
    Took truck back to shop, he pulled the wheels and balanced them again, and checked to make sure weights were still on properly.
    Wobble is still there. WTF???
    Nothing has been done to the suspension and everything was fine and "wobble" free until the new rims.
    Oh yeah...tires are still the same. They are the Toyos that came with the truck (only 17k miles)
    Thanks for any help/input.
    Pics are old rims and new rims.
  2. Nov 12, 2017 at 9:20 AM
    sju350
    sju350 Well-Known Member
    Joe
    TN
    18 Tacoma TRD Smokin Edition
    I had the same thing happen to me, take it somewhere where they Road Force balance the tires. It went away immediately
    Herniator and OnHartung'sRoad like this.
  3. Nov 12, 2017 at 9:22 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    ^SJU350’s suggestion first^^^
    Alignment? Also check to see if both of the front tires are truly “round”. I had this problem and the wobble would vary - it was affected by when both front tires were in “sync” with each other.
    Another check to see if it’s any one of the front wheels is to do a front right to rear rotation and then drive it, and then do the same with a front left to rear rotation.
    Mr-Paul likes this.
  4. Nov 12, 2017 at 9:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    See if the wheels are hub centric or lug centric. If lug centric, you can get little rings that go around the hub to fill the gap.
    Mr-Paul and Justanotherhemi like this.
  5. Nov 12, 2017 at 9:31 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Sounds like a balancing issue if you are getting the wobble at 30 mph + I would go back to the shop to get it looked at. I once had a wheel throw the stick on weights used for balancing immidietly after leaving the tire shop. Truck wobbled at speed. Went back and the tech cleaned the area and re installed new weights
  6. Aug 13, 2018 at 8:44 PM
    seadog99
    seadog99 Well-Known Member
    So, curious how this turned out. I don’t have wobble due to unbalanced tires but the extra offset causes many irregularities in the road to cause the steering wheel to “wobble”. I’m currently running 17”x9” 0mm offset rims with 285/70r17 tires. When I had the same tires on 17”x9” +18 offset they were rock solid. However, those rubbed the UCA.
    Curious what kind of luck folks are having with 17”x8” 0mm offset rims. It seems most folks just live with the instability caused by the wider stance, it’s driving me nuts.
  7. Aug 13, 2018 at 9:03 PM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    This. I took off my aftermarket wheels and two of them were hub centric with spacers. When I put my stock ones on I forgot about the spacers. Had everything torqued down and couldn't get the wobble gone. Did a face slap when I realized my mistake.
    Triple check you don't need spacers with those rims so they sit proper on the hub.
    Mr-Paul and seadog99 like this.
