Help!!! What year transmissions will fit my 01
Discussion in '1st Gen. Tacomas (1995-2004)' started by flyjasfly, Nov 9, 2018.
  1. Nov 9, 2018 at 3:58 PM
    flyjasfly
    flyjasfly [OP] Member
    2001 Red Tacoma Crew 3.4l TRD Off Road
    i have an 01 Tacoma 3.4 v6 TRD off-road, automatic with a bad transmission. What year transmission from 4-Runner or Tacoma will match up to my 01? It’s an A3040E. I bought a ‘99 same model transmission but was told it won’t fit.
  2. Nov 9, 2018 at 4:17 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    01-02 are the same
    flyjasfly[OP] likes this.
  3. Nov 9, 2018 at 4:21 PM
    flyjasfly
    4-Runner and Taco? And is there a way to modify the 99 transmission to fit?
  4. Nov 9, 2018 at 4:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    I would think that the simplest solution would be another A3040E but I can't specify what years they were in.
    Or if the electronic controls could present an issue.
    Maybe @gearcruncher would have some insight on that for you.
    gearcruncher likes this.
  5. Nov 9, 2018 at 4:36 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    4Runner and Tacoma A340E are different. The A340E was used on many many different cars, from the Toyota Supra to the Isuzu Bobtail Truck.
    You have to use a Tacoma A340E. The 4Runner A340E has a longer output shaft and different tail section.
  6. Nov 9, 2018 at 6:37 PM
    flyjasfly
    So I have to find an 01 or 02 Tacoma transmission. I’ll keep looking.
  7. Nov 9, 2018 at 6:39 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Not necessarily. You just need a 1995-2002 Tacoma PreRunner A340E. Keep in mind 1995-1997 had a cable driven Speed Sensor, while the 1998-2002 had a digital VSS.
    While you can use a 1995-1997 A340E, you’ll have to convert it to a digital signal. 1998-2002 is what you need.
    Also, try www.car-part.com
    Where are you located?
    flyjasfly[QUOTED][OP] likes this.
  8. Nov 9, 2018 at 7:05 PM
    flyjasfly
    Thanks. Ok. i was told it was a “manual kickdown vs a digital.” I wasn’t sure what they meant.
    I have a 99 transmission from a 4-Runner. What do I need in order to convert it?
  9. Nov 9, 2018 at 7:59 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    They mean electronic & is what 03-04 Tacomas are. It's possible to convert 03-04 to work in your 01 but you have to change a few parts. Easier to just find the correct one if you can.
  10. Nov 9, 2018 at 8:16 PM
    flyjasfly
    So the 99 I have should work?
  11. Nov 9, 2018 at 8:18 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    If it's from a Tacoma it should but your post above said it from a T4R?
  12. Nov 9, 2018 at 8:41 PM
    flyjasfly
    It’s from a 4-Runner. It’s a 30-40LE. So is mine. Just a different serial #. First pic is mine. Second is the one I bought.
  13. Nov 9, 2018 at 9:04 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Sell it. You have to swap the output shaft which requires tearing down the entire transmission. Not for the faint of heart.
    The 4Runner has a completely different tailsection and longer output shaft. The Tacoma A340E is completely unique. You cannot use the 4Runner transmission.
    The Lexus SC400 A340E has the same tail section design, but a different driveshaft flange.
  14. Nov 10, 2018 at 4:44 PM
    Rosbrughjb
    Rosbrughjb Member
    Wrightsville beach, nc
    2002 tacoma, 2012 hilux
    More than i can type on this tiny keyboard.
    I have one out of a 98 I can sell
  15. Nov 28, 2022 at 10:54 AM
    Wooprdr
    Wooprdr New Member
    @flyjasfly
    Did you end up attempting the install on the 4Runner trans into the Tacoma and did it work?
