Help troubleshoot: "Trac Off" + "Check Engine" light = Disabled Cruise Control
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vuTron, Nov 17, 2017.
  1. Nov 17, 2017 at 1:37 PM
    vuTron
    vuTron [OP] Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    I am aware that if you do not fully tighten your gas cap, no clicks, then it disrupts the pressure inside and causes engine error. This results in the "trac off" and "check engine" lights to appear on dashboard, which causes your cruise control to be disabled. This problem usually self corrects itself by tightening the gas cap and after 2-3 days of driving the problem goes away.
    Now, I know 100% I fully tightened the gas cap. But, I still get this warning light problem as of recent. Anyone else get this problem? Any work around solutions? Do I have a bad sensor? Just trying to gather info before going to dealership. Thanks in advance.
  2. Nov 17, 2017 at 1:39 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    get codes read at a parts store......could be ALOT of things.
  3. Jun 15, 2018 at 4:36 PM
    fuelhead
    fuelhead Active Member
    Dennis
    2017 TRD Off Road
    Grill and wheels so far
    good luck, I have the same issues, they threw on a new fuel pump, it had a low fuel pressure code, pressure test on the pump showed eratic pressures, truck runs like a top, but the lights wont stay off. A reset last for one start and drive, stop and shut off ignition cycle and they reappear when you start it again. Toyota tech thoroughly perplexed
    Pabobfin likes this.
  4. Jun 16, 2018 at 12:45 PM
    elistan
    elistan Active Member
    2017 TRD OffRoad V6 manual.
    For me, it was a missing oil fill cap. Go figure. o_O
  5. Oct 11, 2018 at 2:16 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    @fuelhead, I know this is an old post, but were you ever able to get this problem solved? I'm having the same issue, CEL codes are showing fuel pressure regulator. They are telling me it's the evap canister, which they've ordered. Not sure if I believe that it will fix it...
  6. Sep 16, 2019 at 12:55 PM
    Pabobfin
    Pabobfin Member
    Bob
    2014 Tacoma 4 door short bed
    none
    Mine just started doing this.
    Question:
    What damage can happen while driving until I get a shop to give me the codes?
  7. Sep 16, 2019 at 2:12 PM
    vuTron
    SF Bay Area
    @Pabobfin
    I am no mechanic, but I don't think you are damaging anything.
  8. Nov 17, 2019 at 5:09 AM
    JD56
    JD56 Member
    JD
    2013 Double Cab TRD 4X4
    Stock
    Am now driving with no Cruise Control and both the CEL and Trac off lights on.
    I visited numerous Auto Parts store to have codes checked and all had something to do with brake control and emission codes.
    As well as other codes which each were different.
    I have tried injector cleaner with no help.
    Also checked the gas cap..which the O ring looks fine and the cap clicks as designed.
    Am I to resort to taking the problem to the dealer service dept and right them a blank check?
  9. Nov 17, 2019 at 5:48 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    You could take it to the dealer and have them tell you what's wrong and then decide if you want them to fix it or take it home and try yourself .
    Chew likes this.
  10. Nov 17, 2019 at 5:56 AM
    JD56
    JD56 Member
    JD
    Stock
    I could but, from what posts about this has indicated that all the dealers are guessing.
    I'm surprised there is no Technical Service Bulletin (TSB) on this.
    Or is there one?
  11. Nov 17, 2019 at 6:24 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    You can't believe everything you read on the net. Yeah some dealer service centers have clowns, but many just do their job and fix vehicles. You're guessing here, the dealer will not be. You won't know there's a TSB until you take it to the dealer. You have a 6 year old truck; yeah at some point, you'll have to make repairs.
    BTW; if you're really in a 6 year old Tacoma, you're asking for help/guessing in the wrong section ;)
    Lt. Dangle likes this.
  12. Nov 17, 2019 at 8:02 AM
    JD56
    JD56 Member
    JD
    Stock
    With all the issues regarding the dash warning lights I would assume there had to be a TSB on the issue.
    I'm aware of the talents at the dealership service end hence the training they are mandated to take.
    But, there seems to be a large cloud over this issue with no clear resolution.
    Thanks for the response Chew.
    Its appreciated.
  13. Nov 17, 2019 at 8:14 AM
    Lunabird
    Lunabird Well-Known Member
    I have the same trac off light and check engine light. Got it scanned and it’s reading as a camshaft sensor error.
    I’m still trying to trouble shoot on my own, as I have a low battery reading 10.9v.
    Or could be rats
    Or just a bad sensor
  14. Nov 17, 2019 at 9:07 AM
    JD56
    JD56 Member
    JD
    Stock
    Have had the scanning process done last week and the following popped up.
    P0333..KNOCK SENSOR low voltage (tighten fuel cap that wasnt loose and added injector cleaner and for the record, read that if the battery was disconnected that would clear the lights...didnt clear them.
    C1241 & C1242..VEHICLE STABILITY CONTROL SYSTEM
    (brake system)..have not done anything with these codes.
  15. Dec 1, 2019 at 8:36 AM
    JD56
    JD56 Member
    JD
    Stock
    Wala!!
    Turns out the wiring to my knock sensor was chewed up by rodents.
    $5-6k repair...thankfully it is covered by me car insurance.
    Still in the shop and awaiting the pickup from the dealership.
    Hopefully..
    Dodged a bullet on this one.
    shakerhood likes this.
  16. Dec 1, 2019 at 10:55 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Damn tree-rats! Shoot those MF'ers!
  17. May 1, 2021 at 6:32 PM
    Ncska21
    Ncska21 Well-Known Member
    Nils
    New England
    17 Pro
    Anyone have this issue with error code P0456, evap leak... I gave the fuel cap a real good clean and tighten and pull negative lug but nothing. Same deal, Trac Off + Check Engine + no cruise control. Night prior to getting the check engine I drove for ~10min with cap open... Any ideas thanks
  18. May 1, 2021 at 7:58 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Connect a scanner and clear the code. The code should take 2 trips to return if the issue remains. But you should be able to see it pending on the scanner if you're impatient.
  19. May 1, 2021 at 8:23 PM
    NotSoQuicksand
    NotSoQuicksand Well-Known Member
    2019 TRD Sport x4
    Disconnecting the battery for 10min will give you a nice reset
  20. May 2, 2021 at 7:04 AM
    fuelhead
    Dennis
    2017 TRD Off Road
    Ncska21 likes this.
