HELP! Transmission mount bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by SnowroxKT, Sep 7, 2014.
  1. Sep 7, 2014 at 9:20 AM
    SnowroxKT
    SnowroxKT [OP] Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    Yesterday while removing my sway bar (love it now, but thats another topic) I noticed all 4 of my bolts to which the manual transmission mounts to the rubber mount are gone! :eek::eek:
    Manual trans, 2.7L
    What size are these? M10? how deep? Sorry no pics..
    HansWorldTravels likes this.
  2. Sep 7, 2014 at 9:36 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    Shown as engine rear mounting, what size are these bolts?
  3. Sep 7, 2014 at 9:51 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Could be anything from a 14mm to a 17mm, not real long dont think..
  4. Sep 7, 2014 at 11:14 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    Crap, might just have to stop by the dealer tomorrow.
  5. Sep 7, 2014 at 11:22 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    Anyone know for sure?
  6. Sep 7, 2014 at 5:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    they're 14mm
  7. Sep 7, 2014 at 5:55 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    The head is 14mm. the bolt size is probably 8mm or 10mm. you should be able to get some at your local auto parts store. As I recall, they are only about 30mm long.
  8. Sep 7, 2014 at 6:11 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    Okay, thanks guys.
  9. Sep 7, 2014 at 6:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah I overlooked he was looking for thread size not head size, fucking metrics...
  10. Sep 8, 2014 at 2:54 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    M10 bolt btw. Drives with a lot less slop now, I figured I had a bad u joint and some major axle wrap, 4 bolts help a lot lol.
    And turns out one of my front u joints is bad too. Getting that fixed wednesday
  11. Sep 8, 2014 at 4:37 PM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Man just go to the dealer. I have been stoping there for all kinds of bolts and small doo dads that only they have. It will be $10 worth of stuff and no more guessing.
  12. Sep 8, 2014 at 5:50 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    I called and the dealer did not have them in stock, and could only get me a part number, or order them in in around a week. So yeah, glad I got it taken care of already by a sweet local Toyota Fabrication Shop (Green Tree Fab.) :rolleyes:
  13. Dec 13, 2016 at 1:37 PM
    STEVEO13016
    STEVEO13016 Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    I HAD THE SAME ISSUE... except I was missing 1 bolt... and whats strange is 2 out of the 3 bolts that were there were 14mm and the other one was 13mm... is that correct?
  14. Dec 13, 2016 at 4:42 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    Probably just means someone put a different bolt in that wasn't stock. I wouldn't worry about it.
  15. Jul 3, 2018 at 1:33 PM
    HansWorldTravels
    HansWorldTravels Well-Known Member
    Hans
    Colorado/NY/Germany
    '03 Toyota Tacoma 3.4L Ext Cab TRD
    Roll & Ram repairs on '95 Front end crash repairs on '03
    Wanted to confirm - 14mm flange head 10mm x 1.25mm x 25mm 10.9grade from ACE Hadware worked perfectly at about $1.50 each. Called Toyota & they couldn’t even come up with a part number.
    Waiting until I take out the front driveshaft for new universals to get the DS side missing one in & the lone bolt out to replace it.
    UncleT001 and SnowroxKT[OP] like this.
  16. Aug 4, 2021 at 12:59 AM
    UncleT001
    UncleT001 Member
    Terence
    Tacommmmaaaa 2020
    Lift tires
    Can
    do you have the exact measurements of the bolts ? Would really help
  17. Aug 4, 2021 at 8:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The guy above your post literally posted the exact specs.
    SnowroxKT[OP] and BeLance89 like this.
  18. Aug 4, 2021 at 3:11 PM
    UncleT001
    UncleT001 Member
    Terence
    Tacommmmaaaa 2020
    Lift tires
    My bad thanks
  19. Aug 10, 2021 at 6:43 PM
    DC92T
    DC92T Well-Known Member
    03 TACO 33" BFD's SLOWPOKE
    Suspension lift, towing package with air bags rolling on 33" BFG A/T's
    One thing to remember is Toyota, just like Honda even with their ATV's and Bikes uses the 1.25 pitch for the 8/10 and sometimes the 12mm in many cases. The typical hardware store will carry a 10mm x 1.50 as that is the standard metric pitch. Often people grab the wrong bolts and things go bad, just be aware that they use a fine pitch in many applications and finding that 1.25 pitch in larger diameters can be a bit more of a PITA...
