Help: T-Case to Transmission Seal leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Aug 15, 2013.
  1. Aug 15, 2013 at 12:32 PM
    TacomaJPP
    TacomaJPP [OP] To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Guys,
    I've always seemed to have a wet spot on the seal between my T-Case and transmission. Last night I had the truck parked in the driveway and saw two nickel sized blobs of gear oil. It appears the oil is leaking from the bottom portion of the joint (I'll snap some pics later and post).
    What is involved in fixing this issue. Here are some questions:
    1) It appears that the seal is actually just an RTV type of substance, no actual rubber/foam/paper gasket is present. Is this true?
    2) If it is an RTV type seal, what sealant should I use.
    3) Besides droping driveshafts and removing the cross-member are there any pitfalls to taking the T-case out? Should I be concerned with what gear it is in prior to removal, meshing issues etc?
    4) Anything else I should know?
    Thanks.
  2. Aug 15, 2013 at 1:56 PM
    gearcruncher
    Canadain bumper technician
    are you saying the transfer case has to come apart ?
    There is a " how to " thread in the sticky section .
    doesnt matter what gear the transfer case is in .
    high heat RTV silicone should be used
  3. Aug 15, 2013 at 2:52 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
  4. Aug 15, 2013 at 8:50 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Snapped that pic on my phone and couldn't tell how terrible of a pic it was. Will snap another in the morning.
  5. Aug 16, 2013 at 4:05 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
  6. Aug 18, 2013 at 7:00 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    1) No. The transfer case must separate from the transmission.
    2) I looked. I even looked through the thread that has a compilation of "how to's" and none exist, not even how to remove transmission for clutch replacement...unless I missed it - I checked twice.
    3) Ok.
    4) Thanks.
  7. Aug 18, 2013 at 7:16 AM
    Round II
    Round II Member #12005
    Remove all that you need to access all the bolts, remove all the electrical connectors, separate from the trans, clean up the mating surfaces, and reseal with Ultra grey. Now just reverse the order. I did all this laying in the driveway.:cool:
  8. Aug 18, 2013 at 7:27 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    This ^ the T case is pretty easy to remove just make sure you apply a liberal amount of Ultra Grey to the mating surfaces.
  9. Aug 18, 2013 at 9:39 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Thanks guys.
  10. Aug 20, 2013 at 4:46 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    That void between the transmission and transfer case should be empty. It it's leaking into that space it could be the output seal on the trans.
    Wyoming09 likes this.
  11. Aug 21, 2013 at 7:04 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Thanks for that. Interesting indeed. I will be sure to pick up that seal and extra gear lube.
  12. Aug 21, 2013 at 9:09 PM
    GLD01
    GLD01 Well-Known Member
    Jamie
    Denver, CO
    Tacoma SR5 TRD
    Toytec lift coils w/Bilstein 5100's; OME Dakars w/Bilstein 5100's; Camburg UCA's; Gray wire mod; Deck plate mod; Cooper Zeon LTZ 265/75 R16 tires
    ^^This. Sealing the mating surfaces would just be a bandaid on a potentially bad situation. It should be bone dry inside the cavern that exists in there. I would be highly suspicious of the output seal of the transmission.
  13. Aug 21, 2013 at 10:33 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Of course, before removing the x-member, support the tranny with a jack stand. :D
  14. Aug 22, 2013 at 4:10 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Are my teeth a viable option?
  15. Apr 13, 2018 at 8:44 AM
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
    What ended up being the verdict on this seal leak? T-case to transmission and the output seal need to be replaced? I have the same thing going on. Been monitoring it for awhile, not so much a 'leak', no drips on ground at all, but it is wet.
  16. Apr 13, 2018 at 9:18 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Not that I know the specifics of how this particular situation ended. I'm in the same boat.
    It's either going to be a leaky Tranny output seal or a leaky TC input seal.
    Ive checked both fluids for the past 2 years. And in my case I've never needed to top off gear oil... But the moment i do, I'm ordering both seals.
  17. Apr 13, 2018 at 9:23 AM
    virvak2
    Kyle
    Castle Rock
    '13 TRD Off-Road
    Yeah im with you on that.. although I do need to do a transmission flush and been curious if its worth doing a full flush at a dealer and having them do the seals at the same time, but im sure price will skyrocket at that point.
  18. Apr 13, 2018 at 9:26 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Input shaft seal is a common leak on 1st gens. That's my guess.
    I've done that seal before. It can be done by yourself. Kind of a pain but not too bad.
  19. Feb 22, 2019 at 12:36 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Before even getting anything done, you should degrease that to see exactly where and what is leaking.
  20. Feb 22, 2019 at 10:21 PM
    1997tacomav6
    Denver
    More than likely the transmission rear seal or t-case input seal.
    I just did a clutch job and replaced both of those seals because everything was pulled apart.
    If you have a MT, Every clutch job should include these 2 seals and the rear main seal being replaced
