Help!! Spindle lift question
Discussion in 'Suspension' started by Recurvehunter, Aug 6, 2020.
  1. Aug 6, 2020 at 7:12 PM
    Recurvehunter
    Recurvehunter [OP] Member
    North Alabama
    2009 prerunner (2 wheel drive)
    Installed add a leaf in rear. Mechanic installed 2 inch spacers on front today to level. Problem is he says b/c of the A arm he can NOT align tires now (removed the spacers) and Suggested a spindle lift.’
    Questions:
    1. What spindles do you recommend to get 2inches in the front
    2. I have bill stein shocks - if the spindle is labeled 4 inches, can i reduce the lift with the adjustments on the bilsteins? (To get level or slight rake w/front just a bit lower than back)??
    If there are other options, please suggest. Right now my front is way lower than back.
    Thanks in advance.
    Mg
  2. Aug 6, 2020 at 8:55 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    4” spindles will give you 4” of lift in the front. There is no way to reduce that. They increase track width also so that needs to be taken into consideration too. With just 2” of lift in the front your mechanic should have been able to get the alignment done correctly. Usually 2”’doesn’t cause that much issue( not to say that it couldn’t) but many have gone 2” with no issues. Which bilsteins are you running in the front?
  3. Aug 7, 2020 at 4:17 AM
    Recurvehunter
    North Alabama
    Bilstein 5100
    they were maxed out to get it level with stock rear. Not sure what’s going on.
  4. Aug 7, 2020 at 4:40 AM
    Clearwater Bill
    Billy
    Largo Florida
  5. Aug 7, 2020 at 4:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So you had maxed out 5100 and a spacer on top of that?
  6. Aug 7, 2020 at 5:23 AM
    gotoman1969
    This ^.
  7. Aug 7, 2020 at 7:49 AM
    Recurvehunter
    North Alabama
    i bought the truck and assume it had stock shocks on front. it had a noticeable rake so as part of the purchase i had the shop put bilsteins on it to level. it was level (or very close) with the bilsteins in the highest setting. I had the add a leaf on rear and intended to add the spacers to front - that's when things didn't work out. Can spacers NOT go on top of bilsteins???
    also the people at Head strong offroad are out til aug 17!! i'm looking for options !!!! thanks for your replies.
    matt
  8. Aug 7, 2020 at 7:58 AM
    Recurvehunter
    North Alabama
    mechanic said the A arm (??) wouldn't allow proper alignment. Am wondering if different shocks would overcome this but i'm doubting it. i don't want 4 inches higher in front. Totally lost on what to do.
  9. Aug 7, 2020 at 8:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    IMHO 5100 notches above 0 are a substitute for using the right spring to meet your objective.
    On your prerunner a spindle lift is the clean method, and you can still use the 5100s.
    But the burning Q is do you need lift at all?
    Seems removing the AAL and taking the 5100s down to 0 notch would have you bsck to stock. Then you can learn how to proceed after deciding if you really need lift.
  10. Aug 7, 2020 at 8:35 AM
    Recurvehunter
    North Alabama
    "NEED" - for sure i don't. this is for aesthetics 100%. Yes - if i remove the add a leaf, i'm back to level. Just always wanted to do a lift and this was planned to be it. I've pulled up a couple of webistes (rough country et) and think i'm going to see if i can call and get some advice. I like the spindle idea but don't really want 4 full inches.
  11. Aug 7, 2020 at 8:54 AM
    Recurvehunter
    North Alabama
    just got off the phone with a tech- Tells me a new set of upper control arms is the fix. gonna check a couple more places but am hopeful this is the case.
  12. Aug 7, 2020 at 9:38 AM
    gotoman1969
    How much total lift are you wanting?
  13. Aug 7, 2020 at 9:49 AM
    Recurvehunter
    North Alabama
    two more inches in the front. Back went up about 3" with the extra spring. i need 2" in the front to get back reasonable. ideas???
  14. Aug 7, 2020 at 9:58 AM
    gotoman1969
    If your wanting it level. And I see it’s a Prerunner. Set the front bilsteins to 2” and remove the aal and put a 1” block in the rear and call it day. Trying to get 4” in the front w/o using a spindle is a bad idea.
  15. Aug 7, 2020 at 10:07 AM
    Recurvehunter
    North Alabama
    Before adding a leaf, with front bilstiens at the highest setting, the truck was level. if i take the leaf out, it goes back level without a block and the back is stock (front is lifted a bit with bilsteins). I don't want 4inches lift in the front - 3" at Most. i just talked with toytec technician. He suggested a set of upper control arms, add the spacers, drop the bilsteins a notch. The new arms will then allow proper alignment. he's the second tech from different company today to suggest this approach. Does that sound reasonable?
  16. Aug 7, 2020 at 10:27 AM
    gotoman1969
    Do you want the truck level when it all said and done? Most of theses trucks done have more than an 1”’of rake. So if you do 2”‘in front and nothing in the rear you should be level and and really good alignment guy should have no issues getting the front into specs. Or if you want 3” in front I’d get toytec 3” coilovers preassembled and 2” block in the rear that’s what I have. But with 3” you will need the ucas in front. CA92A270-1E9F-47D4-ADBB-B381BB0A2BC6.jpg58CB8B11-C8A3-44AC-99AF-1BE489B1E016.jpg
  17. Aug 8, 2020 at 7:05 AM
    Clearwater Bill
    Billy
    Largo Florida
    Anything over 2", maybe 2.5" needs adjustable UCAs to align properly.
    If not going spindle, I'd still select a front spring that created the lift wanted and put the 5100's on 0
    I also suspect you'll find the AAL to create a harsher ride than an appropriate sized block in the rear would, especially with an unladen bed.
