HELP... Replacing rear wheel studs with longer ones...??
Discussion in 'Wheels & Tires' started by Eesh, Oct 16, 2012.
  1. Oct 16, 2012 at 10:23 AM
    Eesh
    Eesh [OP] Well-Known Member
    Regina, Sask., Canada
    trd Sport
    Does anyone know how I would go about replacing the rear OEM Studs with Longer wheel studs? How do I take the assembly apart??
    My problem is that I don't have enough room behind the wheel stud plate and the rear drum casing to get the stud through the hole.
    Does the wheel stud plate come off?? I'm having trouble with the rears not the fronts. The fronts are done.
  2. Oct 16, 2012 at 10:24 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
  3. Oct 16, 2012 at 10:27 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    put a lug nut on a few turns and hit it with a hammer
    try that first....
  4. Oct 16, 2012 at 10:29 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
  5. Oct 16, 2012 at 10:44 AM
    Eesh
    trd Sport
  6. Oct 16, 2012 at 10:47 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  7. Oct 16, 2012 at 10:51 AM
    Eesh
    trd Sport
  8. Oct 16, 2012 at 10:58 AM
    Eesh
    trd Sport
    Thats not what I was hoping to hear but I have to replace an axle seal anyways I guess.
    :crapstorm::crapstorm::crapstorm::crapstorm::crapstorm::crapstorm::crapstorm::crapstorm:
  9. Oct 16, 2012 at 11:29 AM
    Eesh
    trd Sport
    But even if I pull the Axle shaft.... how does that give me any extra room???
  10. Oct 16, 2012 at 11:38 AM
    TacoVerde
    TacoVerde Well-Known Member
    Sean
    So Cal
    09 PreRunner
    URD short shifter, OBX racing pedals and titanium/carbon fiber shift knob, Rear speaker mod, Taco bed mat, Bed extender, taco door sill protectors, Black TRD floormats, AFE stage 2 CAI, Doug Thorley Header and Catback, Glassworks Unlimited front fenders/bedsides, Engage front LT kit,2.5x8 King co's with resi's, dj straps
    I may be wrong, but can't you just drill a hole through the backing plate and punch the stud through the hole?
  11. Oct 16, 2012 at 1:01 PM
    Eesh
    trd Sport
    Is this possible? and if so...what would I plug the hole with afterwards?
  12. Oct 16, 2012 at 8:09 PM
    Eesh
    trd Sport
  13. Oct 16, 2012 at 9:23 PM
    Eesh
    trd Sport
    I just want to know if there is anyway I can take the rear wheel stud plate off the rear axle???? 412093B.jpg
  14. Oct 17, 2012 at 7:10 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
    why not just get spaces? that would be alot less trouble?
  15. Oct 17, 2012 at 8:23 AM
    Rebel Taco Man
    Tyler
    Western Kentucky
    he said his wheels wont fit due to having high positive back space, therefore some spacers takes the place of having longer studs? im assuming, why wont his wheels fit? are they not made for the truck?
  16. Oct 17, 2012 at 11:08 AM
    Rebel Taco Man
    Tyler
    Western Kentucky
    thats what my idea was for, cause why else would he be needing new wheel studs? unless one is broke... idk just my .02 thought id save him some trouble of tearing his whole rearend out just for 6 little studs....
  17. Oct 17, 2012 at 3:34 PM
    Eesh
    trd Sport
    UPDATE
    Ok, so I was laying in bed last night and I thought..."what if I take 3/16 off the lugs extended lugs" (The extended lugs are just about 1 inch longer than the factory ones.)
    So first thing this morning I did just that to see if I could get them in without having to get everything pressed out and BINGO. They fit!!
    I needed longer wheel studs to accomodate the 1/2 spacer I used. I didn't need it on the back but I used it on the front so I said screw it I'll put them on the rear as well.
    Everything ended up working perfect.
