Help removing stripped/sheared bolts
Discussion in 'Technical Chat' started by jtnyc, Apr 5, 2013.
  1. Apr 5, 2013 at 10:10 AM
    jtnyc
    jtnyc [OP] Well-Known Member
    I was removing the bed rail bolts to install my new tonneau cover, but I had these 3 bad bolts :mad::
    This one still has the head on, but won't turn. I tried to score a line, but it still won't turn. The bolt itself feels really soft and the material keeps stripping. Unfortunately, I went out and bought a bolt extractor from Harbor Freight (or easyout/Grabit) but the extractor head broke off inside the bolt.
    This one the head sheared off, leaving just the bolt stem in the rivet nut (?) I thought maybe the extractor head broke off the other one because it was a cheapy from Harbor Freight, so I went down to ACE and bought the Grabit (a lot more expensive), but the extractor head broke off in the stem too.
    This one is from the tool box. The head sheared off, but I can see the back of the bolt stem. I tried turning it with a vise grip, but it won't turn. Having stripped the other bolts, I didn't want to do any more damage to it by shearing off the rear end too.
    Any suggestions would be awesome!
    Thanks
  2. Apr 5, 2013 at 10:15 AM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    Die grinder? The first two pictures arent showing up.
  3. Apr 5, 2013 at 10:18 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Grind the head of the bolt off if it has a nut and not in threaded blind hole.
    Grind the head to a useable shape
    Drill and use extractor, drill and drill and drill
  4. Apr 5, 2013 at 10:38 AM
    jtnyc
    I guess I can probably grind off the rivet nut... maybe put a new rivet nut in? Any idea what size it is? I know the torx head is a T-30
  5. Apr 5, 2013 at 10:52 AM
    huntdd
    huntdd Member
    Vacaville
    08 Prerunner sport SR5 AT w/tow
    After trying to remove the bolt by center punch. drilling, and easy-out. I drilled out the nut on the bed rail and used a longer same diameter bolt and put a lock washer and nut on the inside of the bed rail. I used stainless allen head bolts. I also replaced all bed rail bolts with same.
  6. Apr 5, 2013 at 11:56 AM
    jtnyc
    was hoping to retain the original nut if possible... but looks like I may have to drill it out like you did. thanks
  7. Apr 6, 2013 at 8:25 PM
    jtnyc
    Updated the links for the first 2 pics. Hopefull they show up now.
  8. Apr 7, 2013 at 12:36 AM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    Cutting wheel.
