Help removing exhaust tip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GumShoe, Mar 1, 2022.
  1. Mar 1, 2022 at 8:08 PM
    GumShoe
    GumShoe [OP] Well-Known Member
    New Mexico
    MGM 2016 Tacoma SR V6 4x4 DCSB
    I didn't even want the exhaust tip on in the first place but I guess painting it may just be the next best option if I can't get it off.
  2. Mar 1, 2022 at 10:43 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
  3. Mar 1, 2022 at 10:51 PM
    chazmen
    chazmen Well-Known Member
    JT
    Plan on installing one on mine. Any suggestions on what to apply before so I'm not going through this in the future ?
  4. Mar 1, 2022 at 10:52 PM
    P51Mustang
    P51Mustang Well-Known Member
    I would use some Kroil let it soak in and use a chisel at the slit. If not pencil grinder and some patience.
  5. Mar 2, 2022 at 3:57 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    That looks pretty clean, and the rust isn't too bad. The easiest way to remove that without damaging either part is a small chisel a hammer and patience. First slowly work the chisel at a 90° angle into the slits to start prying them out slightly. Once you get some separation, slowly work the chisel around lightly prying and working across the flap to the next slit. Then work the next flap. If you have 2 opened up slightly, you may start getting it to wiggle. If not then work the next flap. Eventually the pipe will wiggle so you can work it off. If you plan on putting it back on again, coat the pipe in a quality high temperature neverseize before install. It will help on later servicing.
    GumShoe[QUOTED][OP] likes this.
