Help removing bedliner "How to"
Discussion in '1st Gen. Tacomas (1995-2004)' started by wild03, Dec 10, 2014.
  1. Dec 10, 2014 at 2:51 PM
    wild03
    wild03 [OP] Well-Known Member
    Florida
    98 Tacoma DLX 2.4L
    tach
    Hello,
    I want to remove the bedliner to take a look under, clean it up and patch the holes.
    I see plastic clips that seem to be holding it, but I don't want to force things and break them. What is the trick to remove the bedliner? thanks.
  2. Dec 10, 2014 at 2:52 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Is it a plastic drop in bedliner? Are you wanting to reinstall it later or sell it? If not, just yank it out.
  3. Dec 10, 2014 at 3:00 PM
    wild03
    Florida
    98 Tacoma DLX 2.4L
    tach
    Correct, plastic drop in. I want to reinstall it once I patch the holes that let water thru to the bed.
  4. Dec 10, 2014 at 3:08 PM
    T4RFTMFW
    Gotcha. My old plastic bedliner had no clips, and I'm not familiar with 1st gens so much so hopefully someone drops in with an answer.
    Shouldn't be too hard to figure out, just be careful!
  5. Dec 10, 2014 at 3:29 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    remove screws, push in and down while reaching behind it to pry it out from under the rail.
    once you get one side loose the other is much easier
    start at the tailgate where it has more flex and as soon as you get the first catch out, you will see what you need to do for the rest
