Help polishing raw Aluminum
Discussion in 'Detailing' started by EVErsionDesigns, Jul 21, 2013.
  1. Jul 21, 2013 at 9:39 PM
    EVErsionDesigns
    EVErsionDesigns [OP] Well-Known Member
    '11 4wd TRD OffRoad
    Camburg UCA, 2.5" Icons, 2.0" Icon air bumps, TRD Intake, TRD Exhaust, TRD TT Wheels, OMF Beadlocks, BFG
    I had bead-locks installed on my wheels and I had them leave the rings "raw" because I didn't know what color i wanted to paint/powder coat them. Turns out i dont want to do either. I think it will look really good with a polished/mirrored finish.
    Problem is I don't know where to start. Been searching YouTube, but I want to see if anyone here has any insight.
    Any advise?
  2. Jul 21, 2013 at 9:42 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Mothers and a powerball mini if its easier than a buffing wheel maybe?
  3. Jul 21, 2013 at 10:04 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    These beadlocks probably have machine marks from cutting the finished dimensions on a lathe.
    You need to sand the machine marks out and keep staging up. Starting at P180 grit, then continuing as follows, using guidecoat every stage to make sure the grit before is gone:
    320
    400
    600
    800
    1000
    1200
    1500
    2000
    2500
    3000
    Polish until scratches are gone. Seal with ECS Automotive Concepts "Rust Prevention Magic"- it's an invisible wax restoration guys use on raw castings to keep them from flash rusting.
    Sounds easy, doesn't it?:rofl:
    Option 2: Sand with 180 and seal. They won't be mirror finish, but they will have that raw look.
    Option 3: Seal as is.
    Option 4: Take them to a shop that repairs alloy wheels. Get them machined & clearcoated
  4. Jul 22, 2013 at 6:51 PM
    EVErsionDesigns
    '11 4wd TRD OffRoad
    There are actually no machine marks, does that mean I can start with a lighter grit?
    Just one to go on the end of a cordless drill or should I get one to go on a pneumatic drill?
    Thanks for the feedback, guys.
  5. Jul 22, 2013 at 7:32 PM
    WHPLSH3
    Vance
    Alberta
    If there are no machine marks, start polishing and see how it comes up... you may be alright.
    I would use an electric drill. Pneumatic usually not torquey enough for how hard you have to lean on it, and cordless will run out of battery. A buffing wheel on a bench grinder would be the best...
    Get aluminum polish from a truck stop/shop- it will work the best.
    A dust mask, rubber gloves, and coveralls are highly recommended. You will be black from head to toe.
  6. Jul 23, 2013 at 4:48 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Mothers aluminum mag wheel polish and lots of elbow grease. That will get you the mirror finish you're looking for.
    I'm a big fan of the Power Ball, but it can get messy. The Power Ball will sling polish all over the place, but it is easier than doing the job by hand.
  7. Jul 23, 2013 at 4:53 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
