Help pls. Howling noise Fan clutch or idler?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a400ryan, Feb 17, 2016.
  1. Feb 17, 2016 at 8:25 AM
    a400ryan
    a400ryan [OP] Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    Looking for help on my 2009 Tacoma TRD Off Road. 155000 kms bought used cpl years ago.
    New to forum and posting. Couldn't pin point issue from searching
    Noise is a howling and or slight squeak. Will change with RPM
    Fan will turn easily when cold
    Belt has some wear/tear but overall seems ok. Any wet spots seen is wd40
    Fluild levels checked
    Video as follows
    https://m.youtube.com/watch?v=Zk9VTPGeDCQ
    I was hoping video would express noise better
    Looking to do this fix myself
    Not sure if it's an idler pulley or fan clutch ?
    Any help or thoughts appreciated.
  2. Feb 17, 2016 at 10:22 AM
    LITACO
    LITACO Well-Known Member
    Rob
    Long Island
    2006 DCSB 325,000 Miles
    ARMOR- CBI Moab 2.0 front bumper, Bud Built Mid Skid, Bud Built Trans skid w/cross member, BAMF rear diff skid, Armortech gas tank skid, OEM front tin skid, Icon Lca skids, Demello off-road round tube sliders bolt on but tack welded for strength, Body Armor 4x4 rear bumper, CHASSIS AND SUSPENSION- New frame from Toyota September 2016, One piece rear driveshaft by supershafts of long island, BAMF cab mount chop plates, 5100 front shocks with toytec 3 inch lift coils w/top plates, All-Pro expo leafs, 1.5 inch blocks + 3 degree shims, Daystar rear bumpstops, 5100 extended travel rear shocks, spc light racing uca's, Toytec steel braid rear brake lines, synergy 1.5 wheel spacers, front sway bar relocation blocks, Minor front fender trim, hammer pinch weld mod. PERFORMANCE MODS- TRD Cat back exhaust with Thrush welded muffler, TRD CAI with Updated AFE filter, Air Flow Snorkel. WHEELS AND TIRES- M/T Sidebitter wheels 16X8 4.5 B/S with Falken wildpeak atw3. LIGHTING MODS- Black Bezel headlights brand X resealed before install, 6k LED headlights by Opt7 silicone glued into headlight, 3k hid foglight conversion, 4 inch Hella optilux 6k, 31inch led bar resealed before installation, Fog light bulb reverse light mod, LED interior lights. SOUND SYSTEM- Pioneer head unit with ipod interface (stock unit is junk), Rockford speakers all around, Pioneer 10 inch sub behind rear seat. ACCESSORIES- Armor Tech Hi-Lift Bed mount, OEM Bed mat, Weather Tech floor mats, Wet Okole front seat covers, Cobra 19 CB with Firestick, Home made bolt on antenna mount near tailgate, Ultra Gauge EM, Avital remote start for North East winters.
    Mine just hit 204K. I'm having the similar noise, idler pulleys.
  3. Feb 17, 2016 at 2:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds more like a pulley to me also.
  4. Feb 17, 2016 at 2:33 PM
    rtgreene10
    rtgreene10 Well-Known Member
    Fl cracker
    4x4 turd
    sounds like my idler after a weekend of mudding.
    Grab and jiggle the idlers to see if they feel loose.
  5. Feb 18, 2016 at 12:14 PM
    a400ryan
    2015 SR5 DCLB
    Idlers feel secure.
    The belt does show wear and tear so going to replace that for sure. I'm thinuking it's idler pulley, just don't want to be replacing one and it's not that one or doing them all when not needed.
    Thanks for feedback.
  6. Feb 18, 2016 at 1:36 PM
    rtgreene10
    Fl cracker
    4x4 turd
    Could be dirt in the bearings. Idilers and belt are pretty cheap.
    I buy the full kit from gates. Saves a little money from buying individually.
  7. Feb 19, 2016 at 5:56 AM
    a400ryan
    2015 SR5 DCLB
    I'm thinking to do belt, idler and possibly pulleys myself. Read it's not too much of a job.
    Want to get upper and lower ball joints done by my mechanic friend, might just get him to do all at once
    Any experience on doing the belt/pulley ? I don't want to take apart the fan and shroud ing
  8. Feb 19, 2016 at 8:11 AM
    rtgreene10
    Fl cracker
    4x4 turd
    They're easy. The tensioner is easy to get to from underneath.
    My Idilers and belt took maybe an hour. Don't remember.
  9. Feb 19, 2016 at 7:16 PM
    a400ryan
    2015 SR5 DCLB
    Problem fixed. After I removed belt I spun an idler that sits between the power steering and drive clutch. Could hear it when spun freely
    One issue was Piston ring selling me wrong belt at first, was too long.
    Thanks for replies
  10. Feb 24, 2016 at 1:49 PM
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I listened to your video, but couldn't really hear it. Did it sound like a growling noise? I have one that seems to match the engine rpm ever since I replaced my alternator.
  11. Feb 24, 2016 at 10:07 PM
    a400ryan
    2015 SR5 DCLB
    Mine would match engine speed as well. Would get more with more RPM. Mine sounded like two pieces of metal rubbing ?
    Once I removed my belt I could spin by hand all idlers, power steering, alternator etc and easily narrowed it down to one idler.
