HELP please!!! Tire shine stains on paint.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Goop_a_loop, Jun 26, 2016.
  1. Jun 26, 2016 at 11:05 PM
    Goop_a_loop
    Goop_a_loop [OP] Active Member
    2019 Tacoma TRD Off Road 4x4 Super White
    Hello, first time posting, although I've been following the thread for months as I was researching my recent purchase. I have a Super White 2016 TRD OR DCSB 4x4. I've had it for a little over a month, this weekend I had it washed, when I got home I decided to do a little extra detailing myself. I cleaned up the wheels and all the little corners and spots the car wash normally doesn't get. I finished by putting some Armour All extreme tire shine dressing on the tires. An hour or two later we went out on an errand, when I got out of the cR I noticed black spots had sprayed all over the side of the truck. I immediately realized it came from the tires and thought the tire dressing just hadn't set in yet. I grabbed some paper towels and a bottle of water and cleaned up as much as possible. The problem is there are light brown stains left behind in different places all of the doors and near the wheel wells. Most of it came off but the light spots stayed. They will not wipe or wash off at all. Has anyone had any experience with this?'b I did some googling and found some similar posts. Some people have said it's something in the tire dressing mixing with an anti mold agent in the tires and staining the paint. Recommendations have been, dish soap, winded, rubbing alcohol, buffing, gasoline, etc. I've tried all suggestions in very small spots near the rear of the truck and nothing will work. Some people have simply posted that I'm screwed. I hope this is not the case. My only hope is that all of the similar posts date back to 2006 at the latest, so in hoping maybe a solution has been made in the last ten years. Or maybe the dressing got into the wax from the car wash before it completely dried and that's why I can't seem to get it out? Any suggestions or tips would be greatly appreciated!
  2. Jun 26, 2016 at 11:45 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
  3. Jun 26, 2016 at 11:53 PM
    Kenjiro
    Kenjiro Well-Known Member
    2016 DCSB TRD-OR
    Try a paste or liquid wax. Not the spray on kind. Worked for me in the past
  4. Jun 27, 2016 at 4:31 AM
    themajewski
    themajewski Well-Known Member
    Adrian
    Newington, CT
    2017 TRD OR DCLB Quicksand
    5100 w/ Eibach Coils & HS 3AAL 255/80/17 AT3/W on Gunmetal TRD Pro Wheels
    I assume the spots are tiny/little. Get a Mr. Clean magic eraser and try that in certain spots. 90% sure that'll work to take them off. Apply wax/protection to areas after
    Rambo MARINE Recon likes this.
  5. Jun 27, 2016 at 5:50 AM
    Skorfab
    Skorfab Well-Known Member
    Adam
    1984 Toyota Pickup Truggy
    6.5" All Pro Lift, Hysteer, Got Propane Conversion Kit, 37x12.50x16.5 Trailworth Fab Recentered Hummer Rims
    DO NOT USE A MR CLEAN MAGIC ERASER!!! If all else fails use that as your last resort.
    Try getting a clay bar kit and if that dosent work a clean rag with a tiny bit of goof off might work.
    daohaus, 20tacoma17, FooBird and 7 others like this.
  6. Jun 27, 2016 at 5:52 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Sounds like it's just that grease from the tire pookey that's on your paint. It should come off. You could try washing the vehicle very well and clay bar the area.
    choupick, PROseur and Skorfab like this.
  7. Jun 27, 2016 at 7:12 AM
    George1441
    George1441 Much happier
    George
    2016 Chevrolet Colorado Diesel
    I use various tire dressings all the time, whether it be at the car wash or at home. Either way I make sure the tire surface isn't left dripping wet with the product. I always make sure the residue is wiped off. I see car wash places all the time just spray this stuff on leaving it dripping wet, hence the side of the vehicle getting sprayed down too as you drive off. Just like anything else, mud water or whatever you might drive through etc. some of the products I use I spray on a rag first, then wipe the sidewalls down. You get the shine without all the dripping residue etc.
  8. Jun 27, 2016 at 7:13 AM
    WMDtech
    WMDtech Well-Known Member
    Nate
    TN
    2018 TRD OR 4X4, White, DCSB
    None... sigh
    Goof Off. Takes off plasti dip over spray very well, I'd imagine it works for tire dressing.
    Rambo MARINE Recon and JayDubya like this.
  9. Jun 27, 2016 at 7:18 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Yea, do not use a magic eraser. That will scratch the hell out of the paint. Try a solvent to get the oil off it won't hurt the paint, then go over with a wax
  10. Jun 27, 2016 at 7:18 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    please don't make the recommendation to use a magic eraser on paint. It will scratch the hell out of it.
    http://www.detailedimage.com/Ask-a-Pro/can-you-use-a-magic-eraser-on-paint/
    It'll look like this.
    Agreed!
  11. Jun 27, 2016 at 7:22 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    ChadsPride likes this.
  12. Jun 27, 2016 at 8:00 AM
    themajewski
    Adrian
    Newington, CT
    I have never scratched my paint with a. Magic Eraser. I don't use it over a huge surface area and only for small spots, any fingernails under door handle, stuff like that.
    I have never seen scratches like that from a Magic Eraser. Looks like a Brillo Pad!
    I second the wiping down of any tire shine or anything like that to prevent it coming off.
  13. Jun 27, 2016 at 8:24 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    The magic erasers are melamine foam which is an ebrasive cleaner. The pysicaly structure of the foam allows for a misleading soft feel but it is essentially a fine sandpaper. If you're using it on your paint you are sanding away the clear coat, and depending on how hard you're using it you could sand away the paint underneath the clear coat.
    Ensemble88, Cavedog, choupick and 5 others like this.
  14. Jun 27, 2016 at 8:27 AM
    xola3que
    xola3que Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
    x2
    Alfred likes this.
  15. Jun 27, 2016 at 8:27 AM
    DrFunker
    DrFunker Well-Known Member
    Yes, magic eraser bad.
    Rambo MARINE Recon and Lawfarin like this.
  16. Jun 27, 2016 at 9:03 AM
    Skorfab
    Adam
    Wtf am I looking at?
    kgilly, FeraNatura and Lawfarin like this.
  17. Jun 27, 2016 at 9:05 AM
    themajewski
    Adrian
    Newington, CT
    Correct, I now understand that. I think it must be pressed very hard to provide deep scratches like the ones in the picture. It doesn't require a lot of pressure to take the stains/dirt/scratches off. I don't use the whole sponge, just the very edge and press lightly. I usually do this before I wax the car so I reapply the necessary paint coverage that may have been taken off.
  18. Jun 27, 2016 at 9:09 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    @DrFunker is a strange man.
  19. Jun 27, 2016 at 10:36 AM
    SothernTaco
    SothernTaco Well-Known Member
    Danny
    Tomball
    Turd Gen
    I've used this on many of my vehicles over the past 4 years or so. Works great. Just make sure you get a nice applicator pad. Clean the area well before using and again after your done. Also, don't go putting a lot of elbow grease into it when your applying it. Use small amounts and repeat until blemish is gone.
    Edit: Note sure why this picture is gigantic...my apologies.
  20. Jun 27, 2016 at 11:04 AM
    Goop_a_loop
    Thanks so much for replying. Sorry for the absence of photos. I will try and take a few after work today. So far I have tried the magic eraser in a small section towards the rear of the truck. That didn't work. I've tried windex and rubbing alcohol, even went over it with the scratch dr while I was taking care of a few light scratches from a trail drive. That didn't work. I'm going to pick up that rubbing compound tonight and give it a shot, after that maybe a clay bar.
