Help On Wheel Sizing - 18x9.5, -18 or 18x8.5, 0
Discussion in 'Wheels & Tires' started by Arcticdc5, Jun 6, 2022.
  1. Jun 6, 2022 at 9:00 PM
    Arcticdc5
    Arcticdc5 [OP] Well-Known Member
    I believe I found the wheels I want but are available in (2) sizes:
    18x9.5, -18 offset or
    18x8.5, 0 offset
    Looking to mount 265/60/18 tires to get as close as possile to 265/65/17 diameter and plan to have a 2" lift in the near future if that helps any.
    I don't mind a slight poke, but I am not willing to do a CMC on my Tacoma, also no cutting of the fender well either. Any insight is greatly appreciated on fitment of the two wheel choices above!
  2. Jun 6, 2022 at 9:05 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    For what it’s worth; I am running Black rhino(glamis)18x9 wheels with +12 offset and LT265/70/18 Toyo Opencountry ATIII. I have a lift. Before a lift I ran the same wheels with 265/65/18 and no rub.
    I’d go with the zero offset personally.
    But honestly your current wheels are awesome.
  3. Jun 7, 2022 at 6:07 AM
    Arcticdc5
    Thanks but these are the wheels I am planning to purchase - the Black Rhino Rapid. I just borrowed this picture online from the Tundra forum lol
    Superhulk LB[QUOTED] likes this.
  4. Jun 7, 2022 at 6:51 AM
    Superhulk LB
    Josh
    Oregon
    Lol. Wow. I didn’t even realize that was a Tundra.
    The 0 offset will have less poke than the -18 and be better at avoiding any rub with the tires. You will be at pretty much factory tire size, so there should be issues.
  5. Jun 7, 2022 at 11:05 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Go with the 0 offset. A 265 will look like crap on 9.5” wide wheel.
  6. Jun 7, 2022 at 11:09 AM
    Arcticdc5
    How about a 275?
  7. Jun 7, 2022 at 11:44 AM
    Superhulk LB
    Josh
    Oregon
    For reference. Here is a 265/65/18:
    E7EB2B10-D713-41DB-819B-044F02E36F63.jpg and here is a 265/70/18. Both are on an 18x9. A186933D-E111-4B8E-B440-9B3127F96D83.jpg
  8. Jun 7, 2022 at 11:45 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    why not
  9. Jun 7, 2022 at 1:10 PM
    Arcticdc5
    Looks pretty good - shocked that those are a +12 offset. Have any pics from straight side to show poke if any?
  10. Jun 7, 2022 at 1:29 PM
    Superhulk LB
    Josh
    Oregon
    These are both with a 265/65/18.
  11. Jun 7, 2022 at 1:49 PM
    Arcticdc5
    Looks pretty good! Any CMC, bumper trimming or any other fitment issues? What size lift are you on?
  12. Jun 7, 2022 at 2:45 PM
    Superhulk LB
    Josh
    Oregon
    The 265/65/18 had no rubbing even before the lift. with 265/70/18 I had to trim about 2” of the fender to avoid any rubbing when turning into a driveway.
    I am running about a 1.5”-1.75” lift up front.
  13. Jun 11, 2022 at 10:47 AM
    Swaine
    Swaine Well-Known Member
    2024 F-150 5.0 Lariat
    Looks sick!
