Help-Oil Filter too tight!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HMA, Jul 11, 2023.
  1. Jul 11, 2023 at 9:35 AM
    HMA
    HMA [OP] Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Taco Surveying Machine '22 Lunar Rock
    I foolishly took my '22 to the dealership for the free oil change / tire rotation at 10,000, did it myself at 500 and 5000. Doing it today and the fucking filter is way over-tightened. I put a torque wrench on it and it clicked at 40 lbs. It feels like the plastic is about to give if I pull any harder. Anyone got any tricks? I already spent 2 hours on the phone bouncing from person to person with the fucking dealership.......
  2. Jul 11, 2023 at 9:37 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I would take the word help out of the title - this is usually reserved for emergency situations. Ie stuck on the trail or roadway.
    if you have the correct size wrench, and have tried that, id try a strap wrench. That can grip the main housing.
    Barsoom and Chew like this.
  3. Jul 11, 2023 at 9:41 AM
    HMA
    Hal
    Bainbridge, Ga
    Thanks. I didn't think of that. I tried to edit my title, but couldn't figure it out. It is sitting in my driveway with the oil and filter drained and i have to be on a construction site in 2.5 hours if that makes a difference.
    winnipegbeachtacoma90 likes this.
  4. Jul 11, 2023 at 9:46 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  5. Jul 11, 2023 at 9:48 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Put the drain plug back in the filter housing, fill oil, and go. The old filter will be fine until you have time to deal with it.
  6. Jul 11, 2023 at 9:48 AM
    soggyBottom
    soggyBottom Well-Known Member
    After going to the dealership, I got mine off with a breaker bar.
    I've heard of a lot of people breaking the plastic filter housing. The new ones are inexpensive. Put a breaker bar on it and be prepared to buy a new one if you crack it when pulling it off.
    Kolohe07 likes this.
  7. Jul 11, 2023 at 9:51 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    this is what I did with girlfriend's 4R, I wasn't real proud of it at the time, but I knew I'd really be up shit-creek if I broke the housing and had to park it to go get a new one. I also made the next oil and filter change early.
  8. Jul 11, 2023 at 9:52 AM
    BillyE
    BillyE Well-Known Member
    I'd fill it back with oil and take it to the dealer to fix it.
  9. Jul 11, 2023 at 9:58 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    This happened with my fiancé's Prius, serviced by some Jiffy Lube-esque place before I met her.
    It was so tight that no tool could get it off. I even shattered the oil filter housing tool that I purchased straight from Toyota. I had a 1/2" breaker bar on it, and it destroyed the tool at the connection to the breaker bar.
    I ended up having to cut a chunk of the housing off with a Dremel, and then pounding the piss out of the thing with a chisel and hammer.
    I was dumbfounded that one of these could be this tight. It's as if they put it on with a powerful impact or something.
    Once I broke the housing free it came off fine. It was just getting that initial friction released.
    If that hadn't worked I was going to remove the metal part of the system from the engine block itself, and just get a new one of those.
    I do all of our oil changes now, and the filter housing goes on very gently nowadays.
    Best of luck in your repairs.
  10. Jul 11, 2023 at 10:07 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I think of these housings like old school spin-on filters; they seem to tighten down (not sure if it's heat, heat cycles, pressure, etc) so hand tight and then regrip and snug it only an 1/8 or 1/4 turn. No tools to tighten at all, as it tightens itself on, will be way to tight.
    Canadian Caber and MR E30 like this.
  11. Jul 11, 2023 at 10:15 AM
    HMA
    Hal
    Bainbridge, Ga
    I've got a good tool. I bought it in '11 for the wife's 4 Runner. I think it came from Doorman. I plan to tap it strategically, give it one more try with the breaker bar, then go buy a ratchet strap tool. Thanks. I've bought Tacomas and 4 Runner from 4 different dealers in the S.E. I bought this one from Tallahassee, Fl. I will never do business with them again.
  12. Jul 11, 2023 at 10:15 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Option A - put oil back in it, order a new filter wrench and housing, try again when you receive both. The wrench for better grip, the housing so that you aren't stranded if you completely fubar the works.
    Option B - put oil back in it, take it to the dealer and put it on their dime if they fubar the housing.
    akimmel, Toy4me and Chew like this.
  13. Jul 11, 2023 at 10:16 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I had the same issue OP, I kept applying pressure until it cracked. Still didn't come off. I had to take mine off in pieces.
    I now have the aluminum one, and haven't had any issues.
    Barsoom and MR E30 like this.
  14. Jul 11, 2023 at 10:21 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i bought a spare filter cover, just in case. 18 ft lbs is the correct torque, mine bottoms out right at that.
    i had the opposite when i did my first oil change. went to loosen the drain cap and the whole filter turned.
  15. Jul 11, 2023 at 10:22 AM
    Vabunch
    Vabunch Well-Known Member
    Jeremy
    Capron va
    17 tacoma trd or dcsb & 96 tacoma scsb
    Order the aluminum oil filter housing and get that plastic junk off of it for starters and try doing it with the motor hot next time
  16. Jul 11, 2023 at 10:29 AM
    HMA
    Hal
    Bainbridge, Ga
    Got it off! Did strategic taps for a few minutes. I used a torque wrench. It was over 60 lbs...... I was prepared to break it and buy an aluminum one. I'm amazed how much torque that thing just took..... I don't see any cracks! The little tab thing was +- 1/2" past the mark! Dumbass must have used an impact.... Thanks for the support. Also: Motor was hot.
  17. Jul 11, 2023 at 10:32 AM
    yerblues
    yerblues Well-Known Member
    Parks, AZ
  18. Jul 11, 2023 at 11:00 AM
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    One more for the motivx filter tool. My first oil change required a breaker bar. Torqued to spec from that change on and no issues since. 18 flbs for filter, 10 flbs for the filter plug.
    Donniet53 and zoo truck like this.
  19. Jul 11, 2023 at 11:09 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    No, they didn't. Next time cool the engine a bit
    koditten likes this.
  20. Jul 11, 2023 at 11:19 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2018 TRD Sport 4X4 DCSB
    duuude. A firsthand story..
    I worked at jiffy in high school during the summers, probly 2009-2011 timeframe. They buy these cheap off-brand oil filters, and I remember a specific smaller filter (fit certain import cars, i think) that never fit its prescribed model quite right. The fix was to intentionally WAY overtighten it so it didnt leak. I think 3 or 4 cars got blown bc of oil leaking out and seizing the engine. Not knocking folks who work at these places, but I will never ever ever take anything of mine to a quick change place, never.
