HELP! Missing nut for lower strut assembly bolt
Discussion in 'Suspension' started by Zombie Runner, Mar 30, 2012.
  1. Mar 30, 2012 at 10:18 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I was checking my truck over at lunch and saw that I am missing the nut that goes on my lower strut assembly bolt. the only thing holding it in place right now it the bolt and the weight of the truck :eek:
    I found the part number but my yota dealer doesnt have it in stock...
    If anyone knows the correct size I am going to see if lowes has something that will work.
  2. Mar 30, 2012 at 10:20 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    its the nut that attaches the LCA to the strut
  3. Mar 30, 2012 at 10:33 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Goto yota dealer buy nut. Or hd buy grade 8
  4. Mar 30, 2012 at 10:35 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    i called and they said they didnt have it....I also dont know what size i need...thats why Im asking, hence the reason I made this thread :facepalm:
  5. Mar 30, 2012 at 10:37 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Call the dealer. If you have a part number they should be able to tell you size. Then go buy a nut that size/thread pitch
  6. Mar 30, 2012 at 10:37 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    You could take off the other nut from the other strut in your driveway, bring it to home depot in a 2nd car, then compare sizes until you find the right one for the one that is missing.
  7. Mar 30, 2012 at 10:43 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    zip tie it in there so it won't fall out with at least 2 criss crossed zip ties and one on the threads
    Just take it easy until you get a new one.
    Those bolts are a PITA to get out when the trucks on a lift so I doubt it's going to walk itself out.
  8. Mar 30, 2012 at 10:43 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    dealer didnt have size, just part number
    thats probably what I'll do tonight.
    obviously not my truck...
    this
  9. Mar 30, 2012 at 10:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yea the guy said he can probably have it in tomorrow but I am doing a 5k mud run in the morning and I want this shit fixed asap
  10. Mar 30, 2012 at 10:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    Fight nicely kiddos :laughing:
  11. Mar 30, 2012 at 10:48 AM
    XXXX
    sKiP
    05 Prius
    just throw any old grade 8 bolt/nut/washers in there with a similar diameter. as long as your not wheeling nothing will get messed up if the bolt diameter has some slop.
  12. Mar 30, 2012 at 10:48 AM
    XXXX
    sKiP
    05 Prius
    :brianr:
    *runs and hides*
  13. Mar 30, 2012 at 10:48 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I posted that picture just for reference. Im am a prerunner, therefore I dont have cv's :cookiemonster:
  14. Mar 30, 2012 at 10:50 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Same thing happened to me with the rear shocks a while after installing my lift. I'm guessing when we put on the billies we probably hand tightened them down and didn't torque them cause the bottom nuts were missing on both shocks. I can't remember off hand but I believe it was a 12 or 14mm bolt on the back shocks. Not sure if it's the same size bolt on the front shock though. Not much help I know :eek:
  15. Mar 30, 2012 at 10:50 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    whats funny is that the washer is still there just sitting on the bolt...haha
  16. Mar 30, 2012 at 10:52 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
  17. Mar 30, 2012 at 10:53 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    im pretty sure the front is 19mm after looking through chris's sticky. Im gonna swing past lowes on the way home.
  18. Mar 30, 2012 at 10:53 AM
    XXXX
    sKiP
    05 Prius
    that is funny...I bet the nut just fell off if that's the case.
    I might be able to check the thread now.
    *walks to warehouse looking for large nutz to try on bolt*
  19. Mar 30, 2012 at 10:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    That isn't going to work.
    OP
    Nuts are cheap. *snicker*
    Just stop by Lowe's or HD and grab one 16mm fine and one coarse thread. And one 14mm fine and one coarse thread. Screw one on to see what fits, return the other three. If you have calipers, measure the outside dia. It will cut the guessing game down.
  20. Mar 30, 2012 at 10:55 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    chris4x4 where are you?! haha
