HELP! Mice/Rats $Hitting on my cabin Filter.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday2013, Jul 21, 2024.
  1. Jul 21, 2024 at 10:14 AM
    TacoTuesday2013
    TacoTuesday2013 [OP] Member
    In my 2013 Tacoma, I keep finding acorns and rodent droppings on top of my cabin filter.
    I’m cleaning out the air box and replacing the filter every month.
    I can’t figure out where they’re getting in though. From what I can tell the air intake is somewhere in the fender????
    Anyone run into this and have a fix?
    Thank you
  2. Jul 21, 2024 at 10:17 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    dpele, Jimmyh and wilcam47 like this.
  3. Jul 21, 2024 at 10:19 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Take off the plastic wiper cowl. You will find the air intake on the passenger side above where the cabin filter is. Get some small (1/8-1/4) steel cloth/mesh and cover the hole with it. Ensure you secure it well.
    Also, you may want to cover the inlet to the engine air filter to keep them out of there.
    I've had good luck using dryer sheets, and peppermint oil to keep them away from wiring. When you wash your truck, wash the engine bay and clean up as much of the plenum area as you can.
    wilcam47 likes this.
  4. Jul 21, 2024 at 11:31 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  5. Jul 21, 2024 at 11:47 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Where do you park?
  6. Jul 21, 2024 at 12:50 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  7. Jul 21, 2024 at 1:12 PM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
  8. Jul 21, 2024 at 1:25 PM
    soggyBottom
    soggyBottom Well-Known Member
    Is this the same on the 3rd gen?
  9. Jul 21, 2024 at 1:52 PM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    99.5%
  10. Jul 22, 2024 at 3:07 PM
    wanderingjay
    wanderingjay New Member
    PNW
    2012 Access 4x4 L4
    Is it rats or mice? Droppings bigger than a grain of rice = rats, droppings smaller than a grain of rice = mice.
    If you're parked in the same spot a lot, you'll want to deal with the source problem. Exclude them from the AC and they'll just go cause problems in other places. (Still exclude them from the AC, just don't stop there.) Depending on your situation & risk to pets/etc you can try traps (cheap snap traps work good on mice, only trap I've had luck killing rats with is bucket trap) or use wire to tie bait blocks up under your hood when parked. I haven't used bait poison because it's not suited to my situation, but if you go that route I probably wouldn't drive with it in there. Either traps or poison you'll want to get specific for whichever critter you've got, and follow whatever directions to exclude non-target animals. Also make the area around where you park less hospitable for them: remove as many nearby sources of food, water, and shelter as you can.
    I get both up in my engine bay when I'm camping, mice way more often than rats. Once, a chipmunk that chewed through the tubing for my windshield wiper fluid, which was at least the cheapest and easiest fixable thing it could've chewed through. Poison's a no-go because it takes more time to work than I'm spending camping at a particular spot. So I've tried just about every other suggestion on the internet. Dryer sheets, mothballs, essential oils. If they work at all, they're definitely not 100%. A copper kitchen scrubber pulled apart and stuck on top of the cabin air filter has kept mice from nesting there, but not rats, who just pull it out. I'm about to be adding hardware cloth over the air intakes, which is long overdue, but won't stop other stuff getting chewed.
    If getting rid of them in the area you park isn't possible for you, the best solution I've come up with is mounting snap traps using velcro. Kind of a redneck hack tbh but it works great on mice. Doesn't work on rats, I guess they're too smart or wary, I'm resigned to just crossing my fingers about them. But I think rats are more an issue parked in one spot consistently than parked in various spots briefly. If it's rats at your home parking I'd go nuclear, whatever it takes to get them gone, because they only multiply.
    Wishing you the best of luck, rodents are a real PITA.
  11. Jul 26, 2024 at 9:42 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I covered my vent entry in the cowl - but found they moved into the air filter of the V6....
    Had to also add a screen to the intake air entry. They went all the way into the airbox on the engine and pooped there too!
  12. Jul 26, 2024 at 9:54 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    They also love to get under the V6 plastic engine cover and chew on injector wires and water hoses so take a look as those can get expensive.
    Look up Mouse Blocker that you can mount under hood to get them out of there or if in a garage they have a plug in one floor mounted that covers larger area.
