Help me, please.
Discussion in 'Suspension' started by Waboma, Jan 14, 2017.
  1. Jan 14, 2017 at 4:16 PM
    Waboma
    Waboma [OP] Member
    Wayne
    Albuquerque, NM
    06 Dbl Cab TRD 4x4
    So I installed a leveling kit and tightened everything down to what I thought was tight enough... it wasn't. The sway bar link on the drivers side came loose and tore into the cv boot (or at least I think that's what it is). I'm stuck in durango on mlk weekend and am not really sure how to fix this. So my questions are 1 is it the cv boot that actually is torn in the picture. 2 Is driving back 212 miles back home dumb and I shouldn't attempt it. 3. Autozone has a universal boot in Stock and I could get that to replace it, but is that a good idea that it's not specific for a tacoma. Thanks everyone.
  2. Jan 14, 2017 at 4:20 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You can't get a fix? Only places closed here for MLK are banks.
  3. Jan 14, 2017 at 4:22 PM
    Waboma
    Waboma [OP] Member
    Wayne
    Albuquerque, NM
    06 Dbl Cab TRD 4x4
    Do you have a recommendation for a shop in durango?
  4. Jan 14, 2017 at 8:20 PM
    quick17
    quick17 Member
    2017 quicksand tacoma trd
    allpro rock sliders
    just tighten the loose parts wipe the boot best you can with a towel then wrap it with duct tape .then you can fix it when you get home
  5. Jan 14, 2017 at 8:34 PM
    Joe D
    Joe D .
    Sorry man, it sux.
    That is the CV boot. Looks like the point of it is keeping the CV clean & keeping lubricant on it.
    If I couldn't get parts to fix or find a shop and needed to get home I'd sure put a bandaid on it (duct tape or something zip tied in place) & drive it home. I'd avoid as much contamination as I could.
    Taco Fan and Waboma[QUOTED][OP] like this.
  6. Jan 15, 2017 at 4:06 AM
    Waboma
    Waboma [OP] Member
    Wayne
    Albuquerque, NM
    06 Dbl Cab TRD 4x4
    Cool, thanks guys. I appreciate the help. I think I freaked out a little quick before being able to research it properly. Thanks again for all your help.
    Joe D likes this.
  7. Jan 15, 2017 at 4:17 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just drive it. I drove my last Tacoma 275000 miles with a torn boot. I intend to drive it to failure, then replace it. It never broke.
    Pjf1119 and Waboma[OP] like this.
