Help me figure out how to get rid of this awesome Trail Master lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco-bender, Sep 13, 2017.
  1. Sep 13, 2017 at 3:20 PM
    Taco-bender
    Taco-bender [OP] Well-Known Member
    Tucson AZ
    2010 Tundra 4x4
    Hi there,
    I posted some questions in the "What have you done to your Tacoma today? 1st Gen Edition" tread regarding a Trail Master 6" lift and what needs to be done to get rid of it a go back to a UCA setup.
    I an effort to not get that thread off track I figured I'd go ahead and start this one and keep this mess all in one place.
    Also, this is my son's truck and he'll be going TDY for about 3 months on Saturday. I decided that I'll just do this project as a surprise for him while he's gone so I'll start gathering the needed parts and try to have the conversion done for him before he gets back. It'd be nice if he could actually take this thing out and do some wheeling as it's a really nice truck (except for the lift).
    So, if anybody has done this before and can save me a bit of parts research, well, that would be greatly appreciated.
    Below is currently what was said in the other thread.
  2. Sep 13, 2017 at 3:20 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
  3. Sep 13, 2017 at 3:23 PM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    sub'd, i have no help to offer... just here to figure out what the hell kind of setup this is lol
  4. Sep 13, 2017 at 3:30 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    Lol... It's apparently the most awesome 6" lift you can do. The mighty Trail Master drop bracket kit. Rave reviews everywhere you read.
    rngr, Dalandser and beertimecontinuum like this.
  5. Sep 13, 2017 at 3:36 PM
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
  6. Sep 13, 2017 at 4:31 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
  7. Sep 13, 2017 at 4:38 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    Question: my stock '00 Prerunner should have the same front suspension as a '98 4x4, correct?
    So, I should be able to use my truck as a reference for measurements and what not while working the '98, correct?
    Also, anyone in AZ have a cross member they might want to get rid of? I'll cut it out if need be.
  8. Sep 13, 2017 at 4:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  9. Sep 13, 2017 at 4:59 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I see the pic of the suspension set up but what about any pics of the front end? Like of the cross member?
    Dalandser likes this.
  10. Sep 13, 2017 at 5:06 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This. That will help give you advice.
  11. Sep 13, 2017 at 5:58 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    Here's the best I can do for the moment. I'll have to drop the skidplate to get something better but no can do right now.
    All 4 of the original LCA mount points are intact so that's a blessing.
    Here's the left side rear LCA mount with the drop bracket bolted in place.
    Here's the left side front LCA mount with the drop bracket bolted in place. Horrible pic but you can see it right above the CV boot.
    Question:
    From looking, I'm going to assume that the missing crossmember is in FRONT/AHEAD of the front diff? If so, have a friend that builds long travel, high end, custom buggies (think Glamis dunes) from scratch that should be able to fab up a crossmember with little effort.
    I can't really see anything that goes directly under the diff, which would make sense to me.
    I really need to get the skid plate off to really see how everything is set up
    Dalandser[QUOTED] likes this.
  12. Sep 13, 2017 at 6:02 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
  13. Sep 13, 2017 at 7:02 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    Okay, found a couple of older pics when the skid plate was off. Not the best but shows things a bit better until I can get the plate off.
    Looks like it's going to be quite the chore. :frusty:
  14. Sep 13, 2017 at 9:03 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If your friend can fab up some good mounts for skid plates and stuff you might actually end up on top!
    MagicMexican likes this.
  15. Sep 14, 2017 at 9:55 AM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
  16. Sep 14, 2017 at 10:10 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    At one point in time a new crossmember could be had from Toyota in exchange for your 1st born. This was helpful to a few folks because all of the part was "there" as opposed to some portion being left on a donor frame. Main point, 1st see what is left on your frame. Also IIRC there was some adapter used for the power steering lines. This still left the pressure line under stress so give it a good look see when things are apart.
    A good fab guy should have no prob with this one way or the other.
  17. Sep 14, 2017 at 10:31 AM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    Yeah, we'll see how it goes. He's a pretty busy guy so I'd like to try and find a stock cross member first. If I can't find one within 30 days I'll hit him up for the fabrication. I'm definitely going to have him do the welding though. I can get everything ready and tack a new cross member in place but my welding is not the best.
  18. Sep 14, 2017 at 11:11 AM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    Thanks Dirty. Will do on the PS lines and thanks for the tip.
    It's going to be another week or two before I get it on stands and start tearing it down. I'm curious to see what was cut out and what's left. I'll be taking some pics and posting here as I go along.
  19. Sep 14, 2017 at 3:42 PM
    SanClemTaco
    SanClemTaco Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    Crossmember on my truck was never cut, the crossmember in question is the rear one where the steering rack mounts.
    If this has been cut I'm not sure I can help. A new one would need to be fabricated and steering rack mounts found and remade
  20. Sep 15, 2017 at 5:04 AM
    Indy
    Indy Master of all I survey.
    Get a copy of install instructions from trailmaster, start at the end and work backwards.
    tony2018 likes this.
