Help me choose what lift and tires.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BIGW0RM, May 2, 2022.
  1. May 2, 2022 at 8:13 AM
    BIGW0RM
    BIGW0RM [OP] Well-Known Member
    Hello All,
    I recently picked up a 2021 Tacoma offroad. I would like to get a lift and some tires for it. Back in 17, I had a Tacoma SR5 with blisten 5100's and some 285/75/16 Ko2's on stock 16" wheels with spacers. It rubbed and I had to trim some fender well which I wasnt happy about.
    This time around, I would like to try something new. I will also like to try a better sized tired (seems I should have got 285/70/16).
    I am thinking about purchasing some 17" 4runner TRD pro SEMA wheels for it. I like how they space the wheels out without use of a spacer. I'll need some new tires for it too.
    But what tires and lift to get? I know I do not want to use blocks of any kind for the rear. I also do not want to use any front leveling spacers.
    My son continues to tell me KING SHOCK or nothing. But what do you guys suggest? My budget is 2-3K for the lift.
    Thoughts and suggestions most welcome as I am not that well versed in the Tacoma mod world.
    Thank you!
    This stance is basically what I am looking for...
    JoePun and Thomasf94 like this.
  2. May 2, 2022 at 8:17 AM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Look into Bilstein 6112/5160 with an icon AAL. The top clip setting should give you the stance you want
    71tattooguy likes this.
  3. May 2, 2022 at 8:32 AM
    BIGW0RM
    Thank you for the suggestion. Is this the icon AAL you are talking about?
    https://www.bilsteinlifts.com/shop/...-expansion-pack-add-leaf-96-18-toyota-tacoma/
    Is the 6112/5160 combo a major improvement over the 5100 I use to have on my SR5? I realize its much bigger and has reservoirs. But does that really make a big difference on ride quality and or articulation? And what about control arms? Should I get those?
  4. May 2, 2022 at 8:37 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yup anything over 1.5'' and I'd recommend control arms. They probably don't ride too different, but the 6112s/resi rears will just handle that much more abuse before shock fade on washboard forest roads/hard wheeling. No difference in articulation.
  5. May 2, 2022 at 10:26 AM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    I'm running Icon extended coilovers, UCA, AAL and shocks with 16x8 wheels and 285/75R16 tires. Suspension was ~$2700.
  6. May 2, 2022 at 10:39 AM
    BIGW0RM
    Thank you. That's a nice stance. And in my budget! Is that a better solution than 6112/5160 combo with AAL?
  7. May 2, 2022 at 12:04 PM
    Rivermaniac
    Rivermaniac Well-Known Member
    Kings or nothing …..
    Thomasf94 likes this.
  8. May 2, 2022 at 2:55 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    welcome aboard
  9. May 2, 2022 at 3:10 PM
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    hit up @Crikeymike and get dobinsons on the truck I've had mine on my '21 Taco for 15k miles and no complaints. No need to spend KINGs money and wait months
    Crikeymike likes this.
  10. May 2, 2022 at 3:12 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Welcome!! Don’t listen to all the jackasses on here :anonymous: 6112’s 5160 great set up IMO LIKE other member has said. Can’t go wrong with icon either.
    Buttskevin21 and 33yrsoftoys like this.
  11. May 2, 2022 at 3:51 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Bilsteins 6112 & 5160 w/ icon add-a-lift springs are nice? Upper control arm should be consider, along front drop kit , sway bar relocation kit, maybe a rear drive shaft drop kit? And bump stops!
    I Ironman sells a complete lift kit. You still may need front drop kit and relocation sway bar? You may want to talk to them?
    Most people like the 33’s , but I think the 32’s fit better , better mileage and cheaper then the 33’s.I still had to do a chop. On my 2019 TRD. BFG’s are consider the most popular, proven!
    Stay away from spacers kit , cheap for a reason.
    Fox , Icons, & Kings and a few others, consider the top of the line! Best I think to visit a few off roads shops, talk to guys of what kind of off roading you may be doing first! If any near by?
    Most 2-3 inch lift will take you most places?
    Money , the more available, the more choices anyone can make!
    I think if my limits of $$$$ were higher? Most likely I would have gone to Fox or Kings?
    Then again, if I had more $$$$, maybe I would not be buying Tacoma? But something else? Lol
    Aloha
  12. May 2, 2022 at 4:01 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    @bigworm, It's the 285 width size that is rubbing, not the 70 or 75 height. 265/75/16 or 265/70/17 will not rub.
  13. May 2, 2022 at 4:07 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Kings and Volks, or you could still get the 4Runner wheels if you want to be more OEM.
  14. May 2, 2022 at 4:10 PM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    I have the same 17" Sema wheels with 275/70/17, with a 2.5 inch lift and UCAs, and had to trim a little bit at the rear of the wheel well. The truck you posted will almost certainly rub without trimming. I'd buy the Toytech kit, UCAs, trim a bit and put on 275/70/17s. I wouldn't recommend going any bigger on that wheel, due to its width.
  15. May 2, 2022 at 4:39 PM
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    How will you use the truck is the first question before you ask about lifts and tires.
  16. May 2, 2022 at 8:26 PM
    BIGW0RM
    Thank you all for the replies. Looking into the Kings, there is no way. Too long of a wait and just too much money. Leaning towards the 6112/5160 combo with a AAL. Wheel wise, I found there is a trd pro sema replica wheel (on this forum) that are much wider with 0 offset. So I might go that route. Tire wise, I might just do the 275. The 285/75/16 on the SR5 where huge, heavy and they rubbed alot even with the 5100 kit lift.
    Truth be told this was my sons truck, I am driving this truck now because my on joined the US Army after 2 years in college. Hes almost done with basic and then he starts his advanced training soon. He got his college credits but wanted to serve. So I am going to pimp this truck out a little and give it back to him once he completes his advanced training. He doesnt know that. But thats my plan. After his advanced training, he will be stationed in upstate NY unless he gets deployed to Europe.
    So I know he would want 33's or bigger if he could. But I would rather have a clean functional setup with minimal chopping if any. So I am fine with 275's. I just need to figure out what exactly to get so I can get it ordered and installed.
    Fedup13 likes this.
  17. May 2, 2022 at 8:42 PM
    Lava-road
    2019 trd-off road
    You got my vote for the 6112 , 5160, AAl. Please consider SPC upper control arm, add the front drop kit , sway bars relocation kit, and get new bump stops to match the lift. Yes those numbers will add up! 32’s be fine, He can always go bigger later?
    That is the set I have on my 2019 Tacoma TRD. For the 6112’s please go 5/4 heights, they say a more comfortable ride. I did a 5/6 , but I cannot compare, all I know this works for me!
    I did my basic at Fort Campbell Kentucky 1971. I can still remember most of it. Made a lot of friends. There was four of us from Hawaii, our Drill Sergeant, almost every detail (so call volunteers ) when he need 4 of them, would call , “ I need the four PINEAPPLES…and off we went…lol
    Aloha
    Kolohe07 and BIGW0RM[OP] like this.
  18. May 2, 2022 at 9:26 PM
    BIGW0RM
    Thanks for the advice. What is the front drop kit?
    and if one does 5/4, doesn’t that lower the front? I’m trying to keep it level. So if I did 5/4, would the rear be ass up with the aal?
    I basically want a small lift that doesn’t require me to change everything out and fit a 32” tire now that you guys have educated me about the 285 vs 275.
    There sure is a lot to lifting trucks vs my sports car world modding. Good lord there are so many things one must do to get good results. lol.
  19. May 2, 2022 at 10:01 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Probably no information on the subject available. Like asking where do I find a book by Hemingway in a library.
  20. May 2, 2022 at 11:40 PM
    Lava-road
    2019 trd-off road
    The front drop kit, drops the front DIFF , lower drive shafts angles to maintain stock height. Cost varies $30-$50. Recommended. Bilstein shock the 6112s has a height adjustments rings , I order mine preloaded
    Usually you want the driver side one ring higher to balance the level , because of the weight of the driver.
    When ordering preloaded they set it? If not then you can set when you received it.p, you will need to compress the springs.
    You may want to call “Shock Surplus” they were really helpful. Answer all my questions and they Ship to Hawaii. They keep you informed about the shipping, they did for me.
    Expect some tire rubs fender trimming , 275/75r/17 BFG AT on 17x9 rims w/ 12 off set. I also order the cab mount chop plates (need to be weld on) $30.00 Some Tacoma owners will have no problems ?
    With any lifts? Expect some issues, hopefully yours will go well!
    I found the factory ride for the streets was great. But off roads , too soft for my style, the firmness of the 6112s ,5160 was a great improvement. But at times I wish I could adjust the stiffness to a bit softer?
    Good luck , let’s us know when done?
    Aloha
    BIGW0RM[OP] likes this.
