Help Identifying Dealer Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grivera, Oct 3, 2008.
  1. Oct 3, 2008 at 11:25 AM
    grivera
    grivera [OP] Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    "Model Description: DOUBLE CAB 4X4 Category ..........: G
    Year ............: 2008 Current Dealer ....: 800-19026
    Interior Color ..: FH42 FH42 Wholesale Dealer ..: 07012"
    The above info is a portion of what was e-mailed to me prior to me purchasing my Tacoma. The truck had 150 miles on it when I bought it and the salesman said it was traded from a far away dealer and thus incurred the mileage. Is there anyway to ascertain what dealership had the truck originally? I tried doing internet searches with the above dealer numbers and have had no luck.
  2. Oct 3, 2008 at 10:37 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    There's no way to find those numbers, unless you have somebody at a Toyota dealership that can help you. If it was only 150 miles away, call over to your dealers parts department, and ask 'em if they know which dealership is "07012". If they won't tell you, try another dealer, or tell 'em you're trying to return a part, and need to which one it came from.
  3. Aug 4, 2011 at 6:12 AM
    AIRTOY
    AIRTOY Toyota Parts Manager
    There is no way to tell what dealer by the code and the dealer codes are not even readily accessable to the dealership staff. I do know however all the dealerships in a certain area have dealer codes that are close in #. so 19026 and 07012 most likey are pretty far apart in fact most likely in different Toyota Regions.
  4. Aug 4, 2011 at 8:13 AM
    vtdog
    vtdog Well-Known Member
    NH
    Dont know if this helps but I believe the distance is about right: 07012 is the zipcode for Clifton NJ
