HELP identify this Bearing, can't find any info!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shalimar, Dec 22, 2015.
  1. Dec 22, 2015 at 2:50 PM
    Shalimar
    Shalimar [OP] Member
    I just recently purchased a 1995 tacoma, more like 1995.5 (the year they changed styles) its a 2.7 manual 4x4 with Manual locking hubs. I just replaced the front drivers side wheel bearing today, had it pressed in with machine etc etc however when taking the components off to get to the wheel bearing a bunch of needle bearings fell out and there was half of the sleeve all rusted away. What is this bearing called in order for me to order and replace? It sits inside the sleeve and the driveshaft goes into this ?? Bearing. Heres pics of the sleeve and the bearing and where the bearing is supposed to go. Im a newbie so please be nice lol! I called toyota parts and they had no idea, i took it into oreilys napa and showed them the part with no idea. So please someone with tacoma experience please help me out. My truck is sitting on the jack until i replace this bearing. Apparently it was bad for a long time and was the probable cause to my wheel bearing going out because there is still slack between driveshaft and sleeve with the new good wheel bearing on. Thanks for any help!
  2. Dec 22, 2015 at 2:58 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    go here and put in your vin number to find the bearing part number http://www.toyodiy.com/parts/q.html
    but be aware the words toyota uses to describe some part names makes them not easy to find
  3. Dec 22, 2015 at 3:01 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Well it's some kind of roller thrust bearing. :notsure:
  4. Dec 22, 2015 at 3:21 PM
    outwest
    outwest Member
    Rick
    2010 DB LB TRD SPORT
    1995.5-2000 Toyota Tacoma, Inner hub needle bearing.
  5. Dec 22, 2015 at 3:22 PM
    Shalimar
    I believe this is the part...? It says manufacturer does not make it, does that mean i have to order this online and wait forever? Anyone have any idea where i can go buy this in person? Its called inner hub bearing
  6. Dec 22, 2015 at 3:27 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Contact ECGS and see if they make a clamshell bushing replacement istead of the Needle Bearing
  7. Dec 22, 2015 at 3:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  8. Dec 22, 2015 at 3:58 PM
    keakar
    karl
    louisiana
    why are you listening to some aftermarket website?
    I told you how to get the Toyota part number so you can go get it at Toyota dealer near you but you don't seam to want to bother getting accurate info
  9. Dec 22, 2015 at 4:08 PM
    Shalimar
    I looked at that site and wasnt able to find the bearing, i also called toyota and they couldn't identity it, thats why i asked for anyone with experience with this part. If the Toyota dealer doesnt know, then i don't know what to do...?? P.s. im a newbie so go easy
  10. Dec 22, 2015 at 4:13 PM
    outwest
    outwest Member
    Rick
    I think this is it.
    90080-36071
    Tacoma 1995-2004 DLX, SR5 4 Cyl 2.7L, 6 Cyl 3.4L 3RZFE, 5VZFE; RZN161, RZN171, RZN191
  11. Dec 22, 2015 at 4:24 PM
    Shalimar
  12. Dec 22, 2015 at 5:56 PM
    keakar
    karl
    louisiana
    just because some minimum wage dufus behind the parts counter cant find it doesn't mean anything, always ask for a manager and make sure they show you a parts picture that shows the exact part location and all parts connected to it, so you need to go back and look at the pictures yourself with someone like a manager to help you.
    this should be the part you need
    http://www.toyodiy.com/parts/p_U_200404_TOYOTA_TACOMA_VZN195L-CRPDKAB_4303.2.html?hl=43501M
    43501M BEARING (FOR FRONT AXLE HUB INNER RH)
    WHEEL BEARING - Toyota (90369-54002) replaces 90080-36071, 90369-54001 $60.56 http://www.toyotaonlineparts.com/oe-toyota/9036954002
  13. Dec 22, 2015 at 6:38 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That's the one you want.
  14. Dec 23, 2015 at 10:59 PM
    Shalimar
    So for anyone who ever has this problem in the future i have found the answer. I talked to toyota and they sent parts diagram for my truck via my vin. looked at the parts diagram(which my bearing was not in) talked to mechanic and found out that the bearing i need Only comes with a new hub, which explains why no one at any parts dealer or online could find my bearing. I called 2 other toyota dealerships to confirm this and spoke with a local mechanic, all with the same answer, u need a new hub. toyota wanted $250 for a new hub(which obviously is above full price) and since i had already pressed in the new wheel bearing, i would have to get a new wheel bearing as well, which was $99 at Oreilys(yes i could have ordered one online for cheaper but the convenience of getting one that day at oreilys was the route i took). Now about my mysterious bearing, Lucky i found off road solutions and they just happened to sell the bearing i needed for my manual lockout hub for only $15. it was called the inner hub bearing. Doing research i still have only found ors to have this bearing sold separately from hub. I contacted mike at ors and he was extremely helpful and shipped my bearing right away. Thank you all for your time and help! What bs toyota doesnt make an aftermarket bearing and makes u have to replace the whole dang hub for a lousy $15 bearing, what a scam! Other than that i am very pleased with my tacoma!
  15. Dec 25, 2015 at 9:54 AM
    keakar
    karl
    louisiana
    you sure the new Toyota hub doesn't come with the new bearing and seals already pressed in it? it was my understanding that they came as a "complete" assembly, and that's why the price was so high.
    im glad you found a cheap bearing replacement for it and I agree, its silly for Toyota not to offer that part but maybe they just assume if it fails it would ruin the hub where it mounts making a replacement part unnecessary in their view
  16. Dec 25, 2015 at 12:45 PM
    Shalimar
    Yes the hubs press in the bearing and everything however u can easily buy the bearing and press it it yourself.
