Help getting lower control arm to drop enough for shock removal
Discussion in 'Suspension' started by OutbackHack, Jul 4, 2012.
  1. Jul 4, 2012 at 9:17 AM
    OutbackHack
    OutbackHack [OP] Well-Known Member
    Evergreen, CO
    2014 DCLB Heavy
    Stupid amount of extra heavy metal all over
    Wondering if anyone has any tips to help me complete my front 5100 shock upgrade. I've gotten as far as unbolting the top of the shock assembly along with the 2 bolts on the end of the lower control arm (near the wheel). I've also loosened the bolts at the root of the control arm where the alignment cams are. But I'm not sure how much loosening is required as I can't get the lower control arm to drop enough to totally remove tension on the spring.
    On the rear attachment point I've got the nut completely removed and the 2 alignment cams are floating free. On the front point, one of the cams is free but the other is stuck in place, but the entire bolt that goes through it is free to move. Hopefully this makes sense. Any suggestions for getting the LCA to drop further so I can remove the shock?
  2. Jul 4, 2012 at 9:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    First, you need to re install the center top nut on the shock shaft, and remove the 3 nuts on the perimiter.
  3. Jul 4, 2012 at 9:21 AM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    maybe a bottle jack pushing down?
  4. Jul 4, 2012 at 9:23 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    :facepalm:
  5. Jul 4, 2012 at 9:25 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  6. Jul 4, 2012 at 9:26 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Quick, replace that center nut and remove the three outside of it
    No - you didn't have to remove or loosen the main lower control arm bolts where the allingment cams are. There are two bolts under the lower arm that bolt to the knuckle. Take those out and you will be able to slide the steering knuckle over and then will be able to maneuver the shock out. You may have to twist it out letting the coil guide you like removing a big screw.
    Don't pull the knuckle too far out as you may pull your cv axle out of the slip yoke, but you'll have some play to get that coilover out.
  7. Jul 4, 2012 at 9:26 AM
    OutbackHack
    Evergreen, CO
    2014 DCLB Heavy
    I'm trying to use the "no spring compressor" technique. Isn't it correct to leave those 3 and just remove the bolt from the top of the stack for this approach?
  8. Jul 4, 2012 at 9:37 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    stupid idea
    go rent one from autozone or simular
    also looks like all your lca alingment tabs are completly folded over
    and if what u say is true about your alingment cam i bet your cam is frozen into the lca.....
  9. Jul 4, 2012 at 9:44 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    My local alignment shop charged me $30 to swap my coils it took him no time at all and i didnt pinch a finger loose an eye or break a sweat. The 1st time Ididit with an autozone comppressor and it was still quite a bit of work. Your just playin w fire. If you don't have $30 to have a shop do it you prob shouldn't even be lifting your truck.
  10. Jul 4, 2012 at 9:45 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i think using the one from autozone is more of a stupid idea that using the truck that is surrounds the spring on three sides
  11. Jul 4, 2012 at 9:50 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i have used this one from auto zone many many times
    never had a problem ive done 885x's and stock coils with them
    very safe if done correctly and in all of 5 minutes
  12. Jul 4, 2012 at 9:51 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    and barefoot too
  13. Jul 4, 2012 at 9:52 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :anonymous:
  14. Jul 4, 2012 at 9:52 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    For the "no spring compressor" method - there are three key elements here:
    1. You don't need to remove the alignment cam nuts. You've got them plenty loose already.
    2. You've gotta be supporting the LCA with a nice big sturdy stable floor jack so it can't go flying
    3. You need to remove the two (four on some older models) bolts that hold the lower control arm to the spindle/lower-ball-joint assembly.
    Be safe man. If you're doing it right, the jack will support the entire load and you'll never feel like you're loosening any bolts or nuts that are under load. This is the MOST IMPORTANT thing. If you're loosening a "loaded" bolt it'll feel tight, and something will go flying at high speed in a random direction when the last thread comes free. :eek:
    lo2hi likes this.
  15. Jul 4, 2012 at 9:56 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You removed the entire coilover right? That's how I did it - but that's a different disassembly technique than what the original poster is trying to do.
  16. Jul 4, 2012 at 10:09 AM
    OutbackHack
    Evergreen, CO
    2014 DCLB Heavy
    Done. Plus I removed the swaybar and the top nut on the shock after lifting it to leave the tension. However when I slowly drop the floor jack out of the way the LCA seems to be limiting the downward travel of the shock, the spring never gets completely unloaded and the top of the shock doesn't clear the hole in the frame.
  17. Jul 4, 2012 at 10:19 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    What's holding it back?
    Once the two bolts that hold it to the lower spindle/ball-joint are removed, and the bolt that goes through the lower shock eye is out, the unsupported lower-control-arm should be able to swing like a door all the way down until it's hanging vertically.
    If I were in your shoes at this point, and I couldn't figure out where the "hidden' tension was hiding, I'd jack it back up, put the center bolt back on the shock, remove the 3 bolts holding the complete coilover, and drop the entire coilover away and out. You don't want to be messing around with 500lbs of tension hiding there, just waiting for you to unexpectedly release it.
  18. Jul 4, 2012 at 10:19 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Whos the one that completely destroyed your cams?!? Good luck with that man....
  19. Jul 4, 2012 at 10:22 AM
    OutbackHack
    Evergreen, CO
    2014 DCLB Heavy
    Thanks. I'll try rebolting the coilover assembly back together and dropping the LCA again to try troubleshooting it some more without worrying about the spring releasing.
  20. Jul 4, 2012 at 10:23 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Does the lower control arm freely separate from the ball joint spindle?
    You may have rust holding it in place even after the bolts are removed.
    That would be a bit dangerous as rust is holding the tension and will let it go unexpectedly.
    In that case, I'd reapply the center nut to the the shock so that it's holding the shock.
    Then I'd hit the lower control arm with a hammer to cause it to separate from the lower ball joint. It won't go anywhere since not loaded by the spring. Then I'd jack the LCA back into place, use it to hold the spring pressure, remove the top nut and try again.
    Again, err on the side of caution here.
