Help: Front drivers side suspension squeaking
Discussion in 'Suspension' started by IDtrucks, Nov 21, 2010.
  1. Nov 21, 2010 at 9:19 AM
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    A little while ago i heard a squeaking from my drivers side front suspension area. At first i thought it was somthing with the engine but later realized it was in fact the suspension.
    What I know: It is only on the drivers side, it only happens when moving. It happens both when braking and not braking. It does not make the noise when the truck is parked and i bounce the front end. I checked the lug nuts and thoes appear to be all tightened. The steering does not seem jumpy or loose or broken in anyway. Everything drives like normal, there is just a loud squeaking noise.
    Does anyone know what this could be and if there is an easy fix?
    I have stock front suspension and the truck is a 99 x cab 2wd
  2. Nov 21, 2010 at 9:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dirt in the springs. Spray as good as you can with a pressure washer, and see if that helps. Only spray the coil.
    YotaKid likes this.
  3. Nov 21, 2010 at 10:46 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    maybe a stone stuck between rotor and the caliper on the brakes???or your pads are down to the skreech indicators????
  4. Nov 21, 2010 at 1:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    its a higher pitched squeak, not really a scratch or grinding sound. And the breaks were replaced about 3000 miles ago so thoes are not the culprit.
