Help finding the source of a coolant leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by c0bra, Aug 21, 2023.
  1. Aug 21, 2023 at 11:26 PM
    c0bra
    c0bra [OP] Well-Known Member
    I am trying to track down a coolant leak on my 03 Tacoma 5vz-fe with 115k miles.
    I first noticed a few drops on the mechanical pulley tensioner at the bottom of the engine. I had to do my valve cover gasket and decided to take a deeper look and find the highest point at which I can see evidence of a coolant leak. I can see dry crusted red stuff as far up as the camshaft position sensor bracket located at the front of the engine behind the black plastic cover. However I can't see anything else in this area as the source so I am stumped. Everything is covered by this black sheet metal piece behind the large cam pulleys.
    -The water pump was replaced along with the timing belt 15k miles ago with OEM and does not appear to be leaking around the seal or directly below it
    -The throttle body (2 rubber hoses) were not leaking
    -The top central coolant hose was not leaking nor was the gasket where it enters the engine
    -I saw no coolant pooled under the intake manifold on top of the engine
    -No coolant at the rear of the engine as far as I can tell.
    I understand there is a "bypass pipe" that runs around this general area?
    Any ideas?
  2. Aug 22, 2023 at 12:36 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah the bypass pipe runs in the valley between the heads and can be inspected by pulling the lower intake manifold which is going to require the fuel rail to be removed with it unless you can get a tiny camera in there from the front or back covers at the end of the valley where there’s some insulation. Pulling the intake isn’t too bad though and the fuel rail doesn’t need to be removed separately I think - ie it can remain on the injectors and be taken off along with the lower intake. Look up how to’s on replacing knock sensors - it’s like the same procedure.
    c0bra[OP] likes this.
  3. Aug 22, 2023 at 12:45 AM
    c0bra
    Is it possible that coolant can leak from that bypass pipe area to the front of the engine? From my research it looks like people mostly see the leaks in the rear when it leaks there.
    I don't have a small camera but I already have the whole intake off so it's only one more step to remove the lower intake manifold I guess.
  4. Aug 22, 2023 at 2:31 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The fast easy way is with a Cooling system Pressure tester !
    Makes trouble shooting so easy! I use mine often.
    Most parts stores loan or rent these out.
    Good luck!!
    Stout890 and cruxofthebisquit like this.
  5. Aug 22, 2023 at 7:37 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah it would most likely fill up the valley and drain out the back if you kept refilling it.
  6. Aug 22, 2023 at 11:08 PM
    c0bra
    I found the coolant leak - it appears to be the coolant bypass pipe that runs under the lower intake manifold. There is red crusty stuff everywhere.
    It looks like I need to order:
    -Bypass tube gasket
    -lower intake manifold gaskets (2)
    -coolant
    I am having a hard time finding the bypass tube gasket. Is it FIPG or an actual gasket? Would it be a bad idea to make a gasket for this instead of using the problematic FIPG again?
    Dalandser likes this.
  7. Aug 22, 2023 at 11:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    See post 6 - Dirty Pool has a deep knowledge of these trucks and I resealed mine w/ RTV when I swapped an engine and it's been doing good.
    https://www.tacomaworld.com/threads/smoke-coming-from-back-of-engine.716853/#post-25513256
    c0bra[QUOTED][OP] likes this.
  8. Aug 22, 2023 at 11:34 PM
    c0bra
    Post 6 is my post? Or am I missing something?
  9. Aug 22, 2023 at 11:35 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Bivouac and c0bra[QUOTED][OP] like this.
  10. Aug 22, 2023 at 11:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @c0bra here's a video of the install on that from a guy that only follows the FSM in his videos:
    https://youtu.be/_G_zqDC9kFM?t=254 if you click it, it should go right to the part, but if the link isn't linking to that time, it's right about 4:10
  11. Aug 22, 2023 at 11:56 PM
    c0bra
    Oh I've seen this dude's videos. Thank you!!
    FIPG is just silicone? Or is it something special? I have had good luck using Yamabond and Permatex also sells some cooling system specific sealant. https://www.permatex.com/products/g...mp-thermostat-rtv-silicone-gasket-maker-5-oz/
    Also, another question...
    Since I had to remove the fuel injectors to get to this point, I want to replace the seals since they will possibly leak if I reuse them. I found this kit - https://theinjectorshop.com/product...ter-seal-kit-for-toyota-tundra-3-4l-2000-2004
    Any other suggestions?
  12. Aug 23, 2023 at 12:01 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    FIPG (Form in Place Gasket) is Toyota's own "brand" if you will, of RTV.
    I use Permatex.
    Looks like a pretty good deal. I had found these when I had my engine apart but I think you found a better one.
    Fel-Pro Fuel Injector O-Ring Set - ES70600
    https://www.oreillyauto.com/detail/.../v/a/8218/automotive-truck-1998-toyota-tacoma
  13. Aug 23, 2023 at 1:16 PM
    c0bra
    I purchased new OEM gaskets, factory coolant, as well as the fuel injector seals from the link I provided above.
    I did a bunch of research on sealants, and apparently the correct FIPG for this joint exposed to coolant is Toyota 1282b (as opposed to the common 103 type), which is costly and hard to find. I will be using this, which is a specially designed RTV for ethylene glycol contact with a plenty high temperature rating: https://www.permatex.com/products/g...mp-thermostat-rtv-silicone-gasket-maker-5-oz/
    Still somewhat tempted to make a gasket and use that in conjunction with the RTV but maybe I will just stick with the RTV only as it did last 100k miles.
  14. Aug 23, 2023 at 5:55 PM
    Glamisman
    Glamisman Well-Known Member
    While you are in there replace the knock sensor harness. It is an known “issue” sometimes and is cheap enough to replace.
  15. Aug 23, 2023 at 7:14 PM
    c0bra
    $50 for the harness! PN 82219-34010
    Do they normally break at a certain point I can inspect? It looks fine to me but.. don't really want to tear this apart again especially with the cost of those gaskets.
  16. Aug 23, 2023 at 9:22 PM
    c0bra
    Two things:
    1. While removing the knock sensor harness it broke in my hands. Both connectors broke and the wires were rigid and brittle. Easy decision there...
    2. Upon closer inspection, it was not the bypass pipe after all. It appears to be the intake manifold gasket. I was really worried it was the head gasket, but you can clearly see the stream of coolant from up above. I just hope it's not both the intake AND head gasket.
  17. Aug 23, 2023 at 10:24 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Was it the original gasket?
  18. Aug 23, 2023 at 10:29 PM
    c0bra
    Yes, from 2003.
  19. Aug 24, 2023 at 7:30 PM
    c0bra
    I keep looking at my photos and second guessing. There is clearly a leak at the intake port that has been dripping down, but by golly there's a lot of buildup around that head gasket. Coincidence? What are the odds of it being the HG at the same time? I don't want to do that job if I don't have to, but it would suck to put it all back together and still have a leak.
    That said, this is probably the easiest type of leak that could be fixed with *gasp* stop leak *gasp* because it's just an external leak and not going into the cylinder.
  20. Aug 24, 2023 at 9:41 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Do a compression test while you've got your engine apart. O'Reilly's rents the tools as well as other parts stores for free.
