HELP! Fail. Can't loosen the bolt on the swaybar.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by genequit, Jun 25, 2015.
  1. Jun 25, 2015 at 9:36 AM
    genequit
    genequit [OP] Well-Known Member
    Gene
    Goodyear Arizona
    white
    Trying to pull my coilovers out to put new ones in and I can't loosen the bolt on the swaybar. The screw where the allen wrench goes into is stripped. Any way around this? Help! :goingcrazy:
  2. Jun 25, 2015 at 9:39 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Propane torch. Heat it til red hot, nut will turn off with ease.
    That or hacksaw the bolt and replace.
  3. Jun 25, 2015 at 9:42 AM
    Rhyno
    Rhyno Well-Known Member
    Shane
    2008 Tacoma DCSB TRD Sport
    Try a pair of vise grips on the bolt between the spindle and the sway bar.
  4. Jun 25, 2015 at 9:45 AM
    genequit
    Gene
    Goodyear Arizona
    white
    Argh Im out of propane!
  5. Jun 25, 2015 at 9:47 AM
    Rhyno
    Shane
    Try the vise grips, no propane required! :bananadance: And use an impact gun on the nut if you have one available to you.
    Iggy likes this.
  6. Jun 25, 2015 at 9:50 AM
    genequit
    Gene
    Goodyear Arizona
    white
    OK I'll try that thanks.
  7. Jun 25, 2015 at 10:44 AM
    justrynarip
    justrynarip Well-Known Member
    Bryan
    Detroit, MI
    09 TRD Sport
    OME lift, AAL, 17" ultra phantom wheels, 32" goodyear wrangler tires, OEM running boards, custom grille, doug thorley long tube headers, URD mark III exhaust with magnaflow muffler, TRD CAI, on demand backup camera switch
    I found that as long as you are able to disconnect at least one of the sway bar links, and remove both of the mounts on the frame, the sway bar will swing enough to get at the coilover on the side that is still connected. Lots of penetrating oil on the links before hand will help of course. I guess this info could be useful for anybody, just to save time...only one link has to be disconnected to remove the coilovers. If it comes down to it, you can always cut out the sway bar links, and and put in new ones once you get them. In the mean time, there shouldn't be any harm in driving around without a sway bar until you have the new links. You may experience a little more body roll is all.
  8. Jun 25, 2015 at 10:52 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    good ideas above.
  9. Jun 25, 2015 at 11:15 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    cut the bitch of..... remove the whole assembly.... never put it back on.
    Thank me later. :D
    doyouevenprerun likes this.
  10. Jun 25, 2015 at 11:18 AM
    scocar
    scocar hypotenoper
    Vise grips: when you think wow, I'm fucked, but not fucked hard enough.
    DoorDing likes this.
  11. Jun 25, 2015 at 11:25 AM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    As stated vice grips and impact wrench works every time. then replace bolt so it will be easy next time.
  12. Jun 25, 2015 at 12:12 PM
    Pigpen
    Northwest Montana
    I do most of my wrenching in my dirt driveway. In a situation like this, I often just spit in the dirt then pick up a glob of mud with the allen key and jam that bitch in. The dirt usually provides the required grip. I know, I'm a heathen...
    ramonortiz55, 95 taco and Rhyno like this.
  13. Jun 25, 2015 at 12:23 PM
    Rhyno
    Shane
    Lol! That's ingenuity and McGyvership at its finest right there!:thumbsup:
    ramonortiz55 likes this.
  14. Jun 25, 2015 at 12:48 PM
    nd4spdbh
    SoCal
    gawd damn sumbitch stripped bolt..... ill show that sucker whos boss... BILLY BOB!!! GRAB THE MUD ALLEN!
    ramonortiz55, a.smo, 95 taco and 2 others like this.
  15. Jun 25, 2015 at 1:02 PM
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    :rofl:
  16. Jun 25, 2015 at 1:23 PM
    genequit
    Gene
    Goodyear Arizona
    white
    Vice Grips for the win!!! Whew thanks for the input guys I was ready to take a fucking hammer to that thing. So delete the swaybar eh?
  17. Jun 25, 2015 at 1:24 PM
    Mademan925
    Nick
    Discovery Bay, CA
    Im not running one. Took it off and it felt wierd for about a week. now I love it.
  18. Jun 25, 2015 at 1:26 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    i recommend no sway bar if running upgraded coilovers. if running stock coilovers with a spacer lift or something, leave the sway bar.
  19. Jun 25, 2015 at 1:34 PM
    Pigpen
    Northwest Montana
    You'll forget there ever was a sway bar before you know it. High(er) speed curves, relatively low speed (for safety) swerving, etc... I haven't noticed any negative driving characteristics. The front end simply absorbs bumps more smoothly.
  20. Jun 25, 2015 at 1:37 PM
    scocar
    scocar hypotenoper
    60% of the time they work every time.
    Yes, try it without. Mine is still haning in the garage rafters.
