help cv axles stuck in spindles
Discussion in 'Technical Chat' started by bluewaters182, Jun 19, 2014.
  1. Jun 19, 2014 at 11:17 PM
    bluewaters182
    bluewaters182 [OP] Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    So im doing my clamshell swap to install my new 4.56 gears. I have everything off I should, tie rod ends, sway bar, lower a arm knuckle, and axle nut. I have been beating on the end of the axle and it wont budge. Any advice on how to get these axles out of the spindle?
  2. Jun 19, 2014 at 11:34 PM
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    It sounds like you disconnected the lower ball joint? Bolt it back up so the spindle is fully supported by both control arms and try it again. You may need to use a bigger BFH. I'm sure your already doing this but turn the nut around backwards and thread it most of the way on the axle shaft before you hit it.
  3. Jun 19, 2014 at 11:40 PM
    bluewaters182
    Greg
    Ohio
    I will try that. Man ive been beating the crap out of it now for like an hour and it wont budge. Arghh. Thanks for the reply
  4. Jun 20, 2014 at 12:24 AM
    bluewaters182
    Greg
    Ohio
    Thanks man that helped. I got one side out with a sledge. Although I messed up the threads on the axle from bashing it. Probably gonna have to get a new axle. It was a bear to undo the nut.
  5. Jun 20, 2014 at 12:28 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    hm i barely had to pull the spindle to seperate spindle and cv
  6. Jun 20, 2014 at 12:43 AM
    bluewaters182
    Greg
    Ohio
    I wish dude, this has been epic!
  7. Jun 21, 2014 at 11:02 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Mine came off real easy. No hammers. 277,000 miles and 1st time since 1995.6 went I bought new.:D
  8. Jun 21, 2014 at 11:24 PM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    Grab a knife file and start cleaning the threads
  9. Jun 21, 2014 at 11:27 PM
    bluewaters182
    Greg
    Ohio
    Yeah, it shouldnt have been so hard. I had wheel bearings replaced by the dealer under warranty, and I'm thinking either they didn't put grease on the splines or water got in or something. I just know it was super stuck.
  10. Jun 21, 2014 at 11:43 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    file the threads!
  11. Jun 21, 2014 at 11:55 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    On my 04, I unbolted the LBJ (4 bolts). Dicso the end links. Removed axle nut. It seemed like it didn't want to budge for a bit, but I lifted the spindle up, and the axle slid right out. The UCA pivoted up and voila. Both sides.
    Use a dead blow hammer when you get rough with something. It's a plastic striking surface and won't damage threads. Also won't bounce back at ya and really puts a hit on something. Or use a block of wood.
  12. Jun 21, 2014 at 11:57 PM
    bluewaters182
    Greg
    Ohio
    I was going to send it to cvj, and they said they would clean up the threads, and polish the other end where the needle bearing scored it. Should be less than the price of a reman. I'll swap it back out and I'll have a spare for the trail, at least the drivers side anyway. Probably wouldn't hurt to buy a passenger side from cvj to have a spare for both sides.
  13. Jun 22, 2014 at 12:03 AM
    bluewaters182
    Greg
    Ohio
    I did all of that. My dead blow didn't have enough oomph to knock em loose. Trust me I'm 235lbs and was unleashing the fury and it was just not enough. Same with wood. It absorbed enough and was just denting in. I was able to get the passenger side out without damaging it. I think I just may have not hit the drivers side square and it dented the corner of the threads. I greased em up good this time so we will see next time they have to come out.
  14. Jun 22, 2014 at 3:17 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I've never changed an axle on a 2nd gen, but on my 99 if I needed to drop the diff but didn't need to change an axle I would just leave the spindle side of the CV in the spindle.
    Once you have the LBJ un-bolted from the spindle, pop the CV out of the diff and swing the spindle/ axle out and away so you can drop the diff.
    Never had a problem doing it that way.
    I had manual hubs on IFS so it was more of a bitch to remove the CV than simply pulling one axle nut.
  15. Jun 22, 2014 at 9:05 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Wow... Sorry for the troubles man. That sounds like a PITA! If a dead blow with your 235 behind it didn't do it... :eek:
    CVJ supplied my half shafts, they have great customer service.
  16. Jun 22, 2014 at 3:35 PM
    bluewaters182
    Greg
    Ohio
    Thanks man, it was tough but I finally got it done.
