Help, can't get lower control arm to bolt back up to spindle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by presta24, Oct 23, 2016.
  1. Oct 23, 2016 at 5:59 PM
    presta24
    presta24 [OP] Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    I have the lower control arm bolts loose. I can't not get the lower control arm close enough to the spindle to start the threads. I am jacking the lower control arm up with the jack. Please help.
  2. Oct 23, 2016 at 6:11 PM
    presta24
    chris
    Cincinnati
    Well, I got the drivers side. Passenger side is being a bitch
  3. Oct 23, 2016 at 6:26 PM
    Pigpen
    Northwest Montana
    If they aren't lined up perfectly, it's a bitch. I usually let the LCA hover just a fraction of an inch below the spindle, so I can move all the pieces around more freely to get the bolts to line up. Once you get the first one started, the second is easier.
  4. Oct 23, 2016 at 6:30 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Stock UCA? might be the loaded bushings fighting by holding up the spindle a bit? Try loosening the long UCA bolt if you're still using stock UCA. Aftermarket with poly bushings shouldnt have this trouble, so I assume you've got the stock ones still and they're whats leading to your fight
  5. Oct 23, 2016 at 6:33 PM
    Pigpen
    Northwest Montana
    I had the same thing happen once. The plate that the bolts go in was pivoted up and all I had to do was move it down. I felt like a dumb ass.
  6. Oct 23, 2016 at 6:35 PM
    PangTRD
    PangTRD Well-Known Member
    Nick
    Phoenix, AZ
    2016 TRD O/R
    Maybe loosen up the lower control arm more
  7. Oct 23, 2016 at 8:51 PM
    presta24
    chris
    Cincinnati
    I got em. Man what a pita. They have to be lined up fricken perfect or nothing. Got the front done, hope to do the rear tomorrow.
    Sandman614 likes this.
  8. Oct 23, 2016 at 8:56 PM
    presta24
    chris
    Cincinnati
  9. Oct 24, 2016 at 4:30 AM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    good to hear. I was in that same position a few weeks back. Shit added like an extra hour as I furiously tried to get it to work, which it eventually lined up. You thought the front was bad.. it's a nightmare in the rear.. especially when you're doing a dakar set by yourself. Hope you got some dog bone wrenches, makes it a lot easier back there!
